01-08-2017, 09:07 AM
Doghouse gasket seal
Didn't know which forum to use, so I dropped it in here.
Where can I get a doghouse gasket seal?
I can feel the fan blowing cold air into the bus when it's running and there's quite a bit of seal torn away.
01-08-2017, 10:12 AM
Originally Posted by Tootalltechie
Thanks for the link!
Digging around their page reminded me I needed to get my Air Windshield Wipers working again
And they've got my door hinge seals!
01-08-2017, 11:01 AM
Your very welcome, glad it helped
Gordon
01-08-2017, 12:27 PM
Coachwork: Thomas 72 passenger
Engine: 230HP DT466 engine MD3060 transmission
I used butyl caulking. Originally it had butyl caulk or tape.
01-08-2017, 12:57 PM
Won't work for mine, it's a rubber neoprene gasket that compresses down when I buckle the straps.
Similar to this
01-08-2017, 02:49 PM
That is a fairly common weather stripping. Have you checked your local auto parts store?
01-08-2017, 04:49 PM
Coachwork: Crown / Pusher
You can also go to. LMC Truck they have all kinds of seals
01-08-2017, 05:05 PM
I'm having trouble visualizing where the doghouse gasket is. Can anyone clarify?
01-08-2017, 05:15 PM
It's where the doghouse seals against the floor... On mine, there's a galvanized steel channel in the floor, you set the doghouse in the channel and clamp it down with those rubber hood clamp looking things
01-09-2017, 04:51 PM
Excuse my ignorance, is this what a dog house is?
01-10-2017, 06:54 AM
Coachwork: Wayne Corp
Look at Mcmaster Carr that is where I ordered mine from. Also get the 3M black gasket adhesive if you intend on cutting and glueing corners.
Sent from my SAMSUNG-SM-G891A using Tapatalk
1990 International 3800 DT360 and AT545.
2007 Dodge 5.9 with a 6 speed.
6 Kids,1 Cool Ol Lady
Lots of life to live.
01-10-2017, 09:02 AM
in that application, yes of sorts.
In my application, my doghouse is a large black box that protrudes into the cab. You can see one identical to mine between the door and driver's seat.
this bus is the sister to mine
Air Force Ambulance Bus Build - Pirate4x4.Com : 4x4 and Off-Road Forum
01-10-2017, 02:05 PM
Aaah. I was envisioning a conventional style bus, not a flat nose. Guess the doghouse isn't an issue if you have a dog nose.
06-24-2021, 11:23 AM
Engine: 5.9 Cummins Diesel
https://midwestbusparts.com/index.ph...oducts_id=9170
Seal for the part of the Doghouse that touches the floor.
One Truth, Many Paths
