Old 01-08-2017, 09:07 AM   #1
Doghouse gasket seal
Didn't know which forum to use, so I dropped it in here.
Where can I get a doghouse gasket seal?
I can feel the fan blowing cold air into the bus when it's running and there's quite a bit of seal torn away.
Old 01-08-2017, 09:48 AM   #2
Tootalltechie's Avatar
Year: 1974
Chassis: CHEVROLET C60 just under 19700 lbs body#B10353
Engine: 350 ci on propane
Rated Cap: 48
Try these fokes out
http://www.busparts.com/index.html
Tootalltechie is offline   Reply With Quote
Old 01-08-2017, 10:12 AM   #3
Originally Posted by Tootalltechie View Post
Try these fokes out
School Bus Parts
Thanks for the link!
Digging around their page reminded me I needed to get my Air Windshield Wipers working again
And they've got my door hinge seals!
Old 01-08-2017, 11:01 AM   #4
Year: 1974
Rated Cap: 48
Your very welcome, glad it helped
Gordon
Old 01-08-2017, 12:27 PM   #5
Clayton's Avatar
Coachwork: Thomas 72 passenger
Engine: 230HP DT466 engine MD3060 transmission
I used butyl caulking. Originally it had butyl caulk or tape.
Clayton is offline   Reply With Quote
Old 01-08-2017, 12:57 PM   #6
Won't work for mine, it's a rubber neoprene gasket that compresses down when I buckle the straps.
Similar to this
Old 01-08-2017, 02:49 PM   #7
Year: 1974
Rated Cap: 48
That is a fairly common weather stripping. Have you checked your local auto parts store?
Old 01-08-2017, 04:49 PM   #8
Stu & Filo. T's Avatar
Coachwork: Crown / Pusher
You can also go to. LMC Truck they have all kinds of seals
Old 01-08-2017, 05:05 PM   #9
warewolff's Avatar
I'm having trouble visualizing where the doghouse gasket is. Can anyone clarify?
warewolff is offline   Reply With Quote
Old 01-08-2017, 05:15 PM   #10
It's where the doghouse seals against the floor... On mine, there's a galvanized steel channel in the floor, you set the doghouse in the channel and clamp it down with those rubber hood clamp looking things
