02-13-2017, 07:48 PM
#221
Originally Posted by plfking
Hope you don't mind, but your pic is my new screensaver.
I'll try not to drool on your windows.
There's probably been a good bit of drool on them already. Hard to tell, as they've been licked clean!
02-13-2017, 08:15 PM
#222
after all it *IS* a short bus......
02-13-2017, 11:07 PM
#223
Coachwork: Fisher Body
Chassis: GM "B" Platform
Engine: 350 TBI Chevrolet
Rated Cap: 8
Flashing Ed sounds like a fun name, better than peeping Tom. To Hell with it, this one should be Casey Jones.
Closest I have to a Bus would be my '92 Oldsmobile Custom Cruiser Station Wagon 1 of 4,347 built.
02-14-2017, 06:48 AM
#224
Wasted no time today. Got the stickers all off except a few I decided to leave.
The handicapped decals had to go, as well as "school bus". That's just for legality.
I got a lil bit of the reflective tape off, but that stuff is formidable.
Found a good use for a hair dryer.
You done f'ed up. Should have left those on there... STOP on Beer".
02-14-2017, 06:52 AM
#225
Re-rating can only be done at an IHC dealer and they are reluctant to do it... I didnt think to hook the computer programmer up to yours, it will tell us what the ECM rated horsepower is.. its possible an ECM from another engine was installed.. thats where the magic sauce is..
my 'Butt dyno' says that one is a 170 (or does it say 175, I cant remember).. mine seems a tad faster and its a 190.. but our weights could be different, your bus seems heavier duty than mine.
(Kubla and I think we got 190s because of the Air-condtioning).
next time im up there we can hook the computer to it and see what it is.
the fuel pressure regulator update helped with a nasty 'Knock' people complained about at hot idle and after I did it on mine it gave the bus a little more spunk off the line...
yours has it already installed. it looks like the schools did a decent job of maintenance on that bus.
makes sense in colorado.. with hills and cold weather.. getting stranded isnt an option
Interestingly, my bus originally came with 19.5's. I wonder if its common for school districts to up the tire size?
Starting to see that they've done some nice tweaks to the bus already. Love the brand new 10R's.
02-14-2017, 09:42 AM
#226
I'm $300 lighter but she's titled and tagged now.
Daily driving shall commence!
Can't wait to hang out with Christopher some time and let him do his voodoo ninja magic on it.
Starts right up and runs real good. The short rear overhang makes it really easy to get around in parking lots and stuff.
Feels so nice to have one I can actually enjoy on a daily basis.
02-14-2017, 09:50 AM
#227
that rocks!!! its fun using a Skoolie as a daily driver!!!
im not sure how lomng yours is, i measured mine and its only about a foot and a half longer than a crew-cab dualie pickup like all the horse peoiple run around central florida.. it will fit in 2 parking spaces .. though I usually park mine out at the end and use 4 just so its easy to get out
02-14-2017, 10:01 AM
#228
Engine: Navistar 7.6L
Maybe the bus garage only wants to keep one size tire in stock so they change the 19.5's out after the first set wears out?
02-14-2017, 10:03 AM
#229
how do you up a 19.5? are there larger rims that fit the same hubs as 19.5's?
02-14-2017, 10:06 AM
#230
IDK, seems like they'd just order the size they wanted. Would be more expensive to order with the 19.5's and buy new wheels, right?
02-14-2017, 10:07 AM
#231
No idea but the AmTran info sticker says it came with 19.5's. I'll try and snap a pic...
02-14-2017, 10:10 AM
#232
im interested to look closer at your hubs and the numbers off of the wheels..
it could be they ordered that bus as an in-town route bus.. 19.5's and 4.10 gears would make for a slow top speed.. (mine is 3.54 and 19.5s).. so maybe they wanted it run faster.. and maybe cheaper to take wheels from another bus or buy used and then add tires, than re-gearing?
might explain the 175 HP vs 190 HP...
02-14-2017, 10:15 AM
#233
02-14-2017, 10:17 AM
#234
I have no idea, but I am confident that they make 22.5 rims that will replace the 19.5 rims.
Once that expense is made, the stock 22.5 tires used for the fleet are used there after.
We all know that the selection of 19.5 tires is very small compared to the selection of 22.5's.
02-14-2017, 10:20 AM
#235
could be.
some pics for you
02-14-2017, 10:39 AM
#236
you are 10 lug vs my 8, your bus was built with a heavier duty hub already. good stuff
makes sense since your GVWR is 20k, mine is 17.5k.
I think AmTran always built on a heavier chassis than Bluebird did.
at least until they re-named to IC and went cheap.
02-14-2017, 11:23 AM
#237
I've always been impressed when I buy an AmTran.
I'm making decent progress on the reflective tape.
Once its off, I'll start assessing the few spots of rust and get that taken care of. Can't wait to get this thing painted some color other than yellow. I know I'm probably in the minority when I say that I hate national school bus yellow, but I do.
Thinking of a baby/sky blue. With dark blue trim. Sorta like a blue collar work uniform. I remember when I was a kid the special ed buses were light blue short buses. They looked nice.
02-14-2017, 11:26 AM
#238
Better keep your keys in your pocket. I think he's going to try to swap his bus for yours when you aren't looking.
02-14-2017, 11:27 AM
#239
Engine: TE 444
Rated Cap: 12
They have the wrong lug nuts on it, it should have the ones with washers, that is a hub piloted wheel
02-14-2017, 11:32 AM
#240
I'll get some nice chrome ones from the truck stop sometime soon. Good lookin out, Kubla! I actually was looking at them this morning thinking they didn't look like the ones I'd seen on a video recently. The ones on the vid looked like they had a washer built onto em, like a flanged nut maybe?
