Old 11-08-2018, 03:29 PM   #1
Electric Door
Hi
My bus door opens electronically and they open just fine but sometimes they don’t close. Do you think it’s a loose connection or what ?
Any Thoughts ?
Thank You
MABus87 is offline   Reply With Quote
Old 11-08-2018, 06:03 PM   #2
Pizote's Avatar
Coachwork: ICCORP
Chassis: CE300
Rated Cap: 16
Knowing the make and model of your bus would help the discussion with clarity.
However, on a 2006 IC CE300, the easiest way to test the door mechanism is to access the key switch to open the door from the outside. To access the switch and wiring, take the right side of the dash off (6 screws). On my switch, there are four leads, three white and one black. I can open and close the door by shorting one of the side whites (yellow and blue in the picture) with the top white (white in the picture).
You can figure your own out, but that's how I ended up replacing my key switch with pushbuttons inside a Masterlock lockbox typically used for spare keys.
Follow my build - and adventures at https://www.facebook.com/pizote.adventures
Pizote is offline   Reply With Quote
Old 11-08-2018, 06:30 PM   #3
Hi
Thanks for the response.
It’s a 2008 Chevy Express 3500 Girardin G5. There is a button next to the cup holder that opens and closes the door and I don’t think there is any key switch for this door because it is all automatic.
bus doors, door, door opener, elect
