10-09-2017, 11:00 AM
Coachwork: Crown Supercoach Series II
Engine: Detroit 6V92TAC
Epoxy Wood Ceiling etc
For my 91 Crown I have decide to gut most of it. The ceiling walls and probably the floor. I want to live full time in it and it will be in desert heat and Colorado winters, so tin can thing won't cut it. I need insulation and wood.
My concern atm is epoxy types. I have been looking at boat builders for ideas here. West system 105/207 epoxy for cabinets, ceiling furring and shower walls. Floor I'm considering same epoxy on some wood that I have not chosen. My main concern is joining and vibration.
West systems has something called g flex but at $55 shipped per 32ozs that might be overkill. I want to join wood that can handle condensation and vibration. Anyone that has wisdom or ideas to share is welcome .
Part of my overall plan is to keep it light and moisture resistant... using epoxy and wood.
Sent from my Coolpad 3632A using Tapatalk
10-09-2017, 11:39 AM
As a carpenter I would think epoxy on an entire interior is a bit of overkill regular varnish would be fine epoxy is used more on boat hulls which are actually in the water constantly.
I've made picnic tables that lasted for years outdoors through winters and all sorts of abuse made out of pine and covered with spar varnish which is a boatbuilders varnish but even that I think is overkill for an interior. The only source of water should be condensation from the metal and an air gap would take care of that.
Alternatively you could just use a stain and let the wood evaporate whatever moisture it takes on.
10-09-2017, 12:13 PM
Traveling
Engine: 5.9L Cummins
Rated Cap: '00
Def overkill, in my opinion. I'd go to big box and get Titebond II for $18/gallon. I make cutting boards out of this stuff.
Great for handling outdoor woodworking projects, the Titebond II 128 fl. oz. Premium Wood Glue offers ANSI-Type II water-resistance and is FDA approved for indirect food contact, and is also ideal for radio frequency gluing systems. The glue is ideal for fixing outdoor furniture, mailboxes, birdhouses, planters and more with its strong initial tack, fast set time and superior strength.
Weatherproof one-part wood glue ideal for exterior projects
Easy clean up with water
Sets in 60 minutes and cures in 24 hrs
Great for use with outdoor furniture, mailboxes, bird houses and more
Meets ANSI Type-II water-resistance standards
Conforms to ASTM D-4236
Ideal for radio frequency (R-F) and hot press gluing systems
Unaffected by finishes
Excellent sandability
UV-resistant wood glue
10-09-2017, 01:20 PM
Chassis: Bluebird
Engine: 5.9 Cummins 24v
Rated Cap: 72 pax
Attachment 16355
I use tite-bond, but had no idea it was that versatile. You should get a commission from them. Awesome info
10-09-2017, 02:11 PM
Traveling
Rated Cap: '00
There are actually 2 formulas- Original in blue isn't waterproof, so it cleans-up easier for regular cabinetry.
10-09-2017, 02:25 PM
Remember that moisture can and will collect on both sides of the wood simply due to condensation. Personally, I'd opt for a more "breathable" finish on a ceiling. As Hex noted, that way minor moisture can evaporate. If you have or get a roof leak...well, that's a whole 'nuther matter.
10-09-2017, 03:24 PM
Chassis: Saf-T-Liner MVP ER
I've used Titebond II for years.
It is stronger than the wood you are joining. Properly cured, the wood will break before the joint fails.
It is also water-soluble before it cures, so even the waterproof stuff can be cleaned up with a damp cloth after a joint is clamped.
However, generally you would simply let it "bead" up from the joint and leave it to harden, then remove the excess with a chisel or sandpaper. Trying to wipe it off can lead to the adjacent wood becoming reluctant to take a stain.
10-09-2017, 03:36 PM
Traveling
Rated Cap: '00
One step further is use the blue tape to protect the adjacent wood if new to gluing wood, or like Twigg says- you get splotchy joints, and nobody like splotchy joints.
10-09-2017, 04:45 PM
Year: 93
Engine: 7.3 idi
To avoid splotchy joints just wet the entire peice of wood then the stain will be uniform. Or sand the area you got wet problem solved.
10-09-2017, 04:48 PM
Year: 93
Engine: 7.3 idi
If you use wood like hard maple, white oak, cedar, teak and other weather resistant wood. Then a simple coat of mineral oil will protect it. To take that up a notch, melt beeswax and mix with mineral oil wipe on. Waterproof finish. Example butcherblock countertops are done this way.
10-09-2017, 05:11 PM
I can see your point about overkill. I'm glad that I was wrong since my idea was probably more difficult and more expensive. I was thinking of something lighter for ceiling and now maybe a hard wood floor. Going to seal that roof tight first. It's not awful but I don't want all the work undone by a roof oversight. Ty!
10-09-2017, 05:38 PM
Actually, there's 3. III is waterproof, II is water resistant.
10-09-2017, 06:23 PM
Not trying to hi jack but.
What you guys do about the 1/4 round on the sides here.
I would like to leave it as natural as possible.
