Old 09-22-2014, 06:29 PM   #41
Re: Family Tardis
One more consideration regarding large fresh water tanks......
In addition to requiring very secure mounting, they must also have ample baffling inside. Buses move...the water moves independently. The result can produce a remarkably powerful tsunami that easily can rip a large tank apart if there is nothing to limit the water movement.
Many of the plastic tanks I have seen had zero baffling. Fuel tanks have them...water tanks, not always.
Old 09-22-2014, 07:56 PM   #42
r_w
Re: Family Tardis
VERY good point on baffling. You may want separate tanks if you can't get baffles, because that can allow you to isolate one if it leaks or stuff them in various places--but it will increase the complexity and probably (but not necessarily) cost more.
Buses have enough strength if you should be able to run E track (like semi trailers use) above the windows as long as you get a good attachment to every rib. Bottom track (like airplane and handicap buses use) looks better but costs a lot more and isn't as strong by itself.
r_w is offline   Reply With Quote
Old 09-22-2014, 10:33 PM   #43
serpent's Avatar
Year: 198x
Coachwork: Crown & MCI
Chassis: 40ft Tandem/40ft MC-9 Tag
Engine: Cummins 855 BCT/6V92TA, RTO-910/HT-740
Rated Cap: 47,000lb/38,000lb GVWR
Re: Family Tardis
I have used an Air Head composting toilet in my GMC for 4 years now and I'll never put a black tank in an 'RV' ever again. (BTW- It's the same thing/idea as the Nature's Head.)
I'm not sure 8 people will be able to use it comfortably for long, but with 2 people you can generally use it day-to-day (empty the pisser daily) for 4 weeks straight before worrying about filling up the **** tank.
They don't stink if you ventilate them properly and in a weird way actually smell kinda pleasant after the decomposition process starts to take place. In any event, much better than a black tank that's been sitting in >90F temperature for a while; I won't do it again.
I've already made accommodations to put another similar unit in my bus.
P.S. the only complaint I've had is from the girl's side of the house; these composting toilets aren't as convenient to use for a female when you have to separate urine from the feces. I guess taking a **** and pissing at the same time requires certain types of plumbing to make it work easier?
serpent is offline   Reply With Quote
Old 09-23-2014, 08:36 AM   #44
r_w
Re: Family Tardis
Originally Posted by PDBreske
Originally Posted by orangepeel91
I don't care how slightly built you are your keister is still wider than the commode.
Not mine.
But your elbows are.
But back to a serious note: What is the best option for a big family? Even the biggest black tanks are under a week capacity for 8. Nature's Head is down to a week or less. I am thinking the old 5 gallon bucket toilet is the winner for a big family. I mean, if you have to empty it within a week, why mess with the composter?
Old 09-23-2014, 08:57 AM   #45
Re: Family Tardis
Not mine.
okay if you are boondocked in your private home, just dig a big azz hole and put dump valved sewer tube into it like an out house
this way black tank stays empty for trips???
the family wagon family wagon Skoolie Conversion Projects 124 12-23-2018 10:45 AM
Family looking for long bus bansil Classifieds | Buy, Sell, Swap 9 02-28-2013 06:56 PM
why dont family believe?? bansil Everything Else | General Skoolie Discussions 2 11-25-2012 03:44 PM
Our First Bus... family Skoolie vwdude Skoolie Conversion Projects 14 06-13-2012 08:33 AM
legault family legault83 Skoolie Conversion Projects 27 04-10-2012 08:18 AM
