Old 12-24-2011, 04:03 AM   #11
Chassis: Genesis
Engine: Dt40
Re: Fear Fair Prison Party Bus
We also decided to freshen up the driver's area a bit with a coat of black paint. We just couldn't stand how 'stock' this area was going to look with the passenger compartment remodeled.
I had been thinking about a way to control some of the audio and lighting we are installing. Since the audio system in the rear is running independent of the driver area, we needed to use a switch to simulate the key being turned on and off. Plus, I have to be able to switch all of the accent lighting. I stopped by a boat shop and picked up a switch panel. We'll install this in the bar next to the head unit.
The components for the audio system have also been finalized and are on hand, as well. The head unit is a Kenwood DDX-516, the components are Alpine S610's, the subs are two Dual BP1204 illuminite boxes (we really liked the look of these, if the actual subs don't hold up, we will replace them in the boxes) and the amps are all old Rockford Fosgates. We can't wait to get the system installed and see how it sounds.
bhays is offline   Reply With Quote
Old 12-24-2011, 09:00 AM   #12
Chassis: Genesis
Engine: Cornbinder 466
Rated Cap: 71
WOW!
I want air red seats...Your gonna love that bus. I am interested in how you set up your sound system as far as speaker placement. Keep the pictures coming
Tracy
Newfiedogs is offline   Reply With Quote
Old 12-26-2011, 07:47 PM   #13
Chassis: Genesis
Engine: Dt40
Day Nine - December 26, 2011
Today we finally finished the inside painting. Now on to flooring and getting the new seats installed!!
We went with a low gloss black on the frames and high gloss red on the mesh. It really makes for a dramatic contrast!
Old 12-27-2011, 07:30 AM   #14
Coachwork: ElDorado
Chassis: Chevy P30
Engine: 7.4 liter 454 Chevy
Rated Cap: 24
If your going to use this bus for "commercial or a "private" party bus?
Your going to run into a problem with leaving that mesh covering the escape hatch and the bars on the windows.
Bullwhacker007 is offline   Reply With Quote
Old 12-28-2011, 04:46 AM   #15
Chassis: Genesis
Engine: Dt40
Day Ten - December 27 - December 28, 2011
Today (into the wee hours) we completed the flooring install and got the mesh inserts for the seat frames and bar prepped and painted...
Old 12-29-2011, 10:59 PM   #16
Chassis: Genesis
Engine: Dt40
Day Eleven - December 29, 2011
Today we got the wire mesh installed into the seat frames and bar pieces and got those into the bus. We also dyed the new seats black with Duplicolor Fabric Spray which will make those fit in so much nicer!
There are a lot of details to finish up, but it's coming together!
The top of the bar still needs carpeted, etc. but it's definitely coming together.
The seats will look so much nicer in black. I am really impressed with the Duplicolor Product!
Old 12-29-2011, 11:03 PM   #17
Chassis: Genesis
Engine: Dt40
When we carried the seat frames in to install them, we realized we had a slight problem....
The cupholders hit the wheel wells... ugh.. But this is a party bus, let's keep our priorities straight here folks.. there is 16" from the top of the tire to the wheel well, though.. So we drilled and inserted the cup holders... they stick about 2" into the wheel well, but we will silicone them well and they are very snug in their holes.
Old 12-30-2011, 07:12 AM   #18
Wow...you all are busy!
Old 01-06-2012, 10:39 AM   #19
Chassis: Genesis
Engine: Dt40
I will have another update in a day or two, we're about done...
Old 01-06-2012, 07:03 PM   #20
Engine: DTA360
Rated Cap: 16
Looking good, I really like the mesh... Might have to incorporate that into my bus, would go well with the materials I'm using...
I used upholstery spray years ago that started to bleed onto peoples cloths in the summer when they started to sweat... Just an FYI...
dirtygoat is offline   Reply With Quote
our weird little prison windows pictureLOVE Conversion General Discussions 15 09-19-2014 02:44 PM
Prison bus perks Butnerbus Short-Bus Conversion Projects 10 02-07-2013 09:26 PM
2 Prison transport busses for auction -with bars on windows! Abbott Classifieds | Buy, Sell, Swap 10 02-25-2009 02:39 PM
Our New Prison Bus, Blue Bird, International 9.0l letz4wheel Skoolie Conversion Projects 6 01-22-2009 10:26 PM
It's not fair! There should be a law against it!! crazycal Everything Else | General Skoolie Discussions 11 09-17-2008 01:51 PM
