Old 03-14-2010, 08:58 PM   #11
Coachwork: International Harvester
Chassis: Carpenter
Engine: 7.3L Diesel
Re: Finally Moliska is joining skoolie.net!
Originally Posted by baadpuppy
Welcome to skoolie.net.
As for your engine not starting, one thing I ran into about a dozen times before I finally started to keep it straight in my head... I would often leave the transmission in gear after setting the brake, and forget to return it to neutral. The bus just won't start with it in gear. First time it happened, I thought "oh crap, I broke it". After that, I just kept thinking "you dummy, you left it in gear again". Now, I don't forget. lol
Hopefully it is something as simple as that. There are often other safety circuits that can cause an engine not to start, such as a door open, or something similar.
Can't wait to see your future progress. Good luck!
jim
no no..I know all about having a manual tranny. I thank god for being raised with a carb on the coffee table, now i am no way a mechanical engineer like my father, however most of my buddies call me for car trouble... this is my first time ever with a diesel... and Ive been trying to learn and research the air brakes... I'm guessing i am having two problems...(I need to see)starter not getting power....brakes not getting pressure....oh. out here on 40acres with no cat, I seem to have a mouse and rat attraction to under the hoods of all the vehicles.... so i just seem to need a cat and a helping hand...ie. its hard to turn the key and listen for solenoid over brake pressure alarm
moliskaIH is offline   Reply With Quote
Old 03-14-2010, 09:04 PM   #12
Chassis: Carpenter
Engine: 7.3L Diesel
Originally Posted by mightybus
The tank is galvanized. It is a great tank. Better then plastic. No out gassing. Even if it is slightly rusty, which I doubt, the iron is good for women folk. Also crusty is good because of the calcium content. Alge is not so good and interestingly grows better in plastic tanks. When the tank is empty it is slightly heavier than the plastic one. So... good old dad might have to figure in to move it around.
I use my one set of panels to charge three batteries for my house. I use the batteries for my laptop and a light with power to spare.
whats out gassing? i like calcium and iron....i get lots from the 280ft well we just had dug, a few years ago now, leaves a stain in the bottom of my water jugs, and i guess sediment, the white flaky-ness... seems like this bus is a solo mission... Just me and the dog ... have a few friends i hope to trade work for help on stuff that's damn impossible to do by yourself..
Old 03-14-2010, 09:14 PM   #13
Chassis: Carpenter
Engine: 7.3L Diesel
is the brake pressure not letting the starter get power? and Ive read that the pressure alarm is frequent in these models to go off when your cruzin and you are supposed to pull over and turn off the bus and back on again? lame...
Old 03-14-2010, 09:22 PM   #14
Chassis: Carpenter
Engine: 7.3L Diesel
[quote="mightybus"]Micro plastic particles leach into the water and end up embedded in your tissue. On the galvanized tank and on your well just use a sediment filter. 280 ft is pretty good. Mine is 530ft deep. I use a 1000 gallon storage tank to let the hydrogen sulfide percolate out.
Here is your air-brake training resource.
I like it.
oh, when u put it like that, yuck... half as deep.. i think I'm at 1400 elevation here on the Ozark plateau
Old 03-14-2010, 09:38 PM   #15
Chassis: Carpenter
Engine: 7.3L Diesel
okay so happy to hear that its not necessarily a brake problem...yet. home-cooked meals are easy to come by around here.... i would have to say i cook great from a box as well(normally a ramen and pees kind of eater)... yup i really want to get the bus going...hope to get to travel again soon... truly need to focus on that more so than converting...its just not as much fun and I'm scared to know the cost of any major repairs... also not to mention the 6 crap tires...thinking about taking it to this diesel repair and welding place right down the road...gonna need the battery box/frame part welded(its rusted off almost) and inspection/tune up?... will take pics tomorrow of awesome stellar progress...hopefully
Old 03-14-2010, 09:56 PM   #16
Chassis: Carpenter
Engine: 7.3L Diesel
24 min long....gonna have to view when i can get on a faster internet, its just taking too long.... 167 army training video, cool, I'm very interested
Old 03-14-2010, 09:58 PM   #17
Elliot Naess's Avatar
Engine: 5,9 Cummins
Welcome aboard, Moliska!
An other fact of nature is that when a single lady bus-owner shows up on this predominantly male forum, there will be two pages of helpful posts from single men in three hours flat.
I'm worried about your heater hose fittings. They seem to be the kind that is intended for soldering, and they have no ridges to bite into the rubber hose and keep it secure. I fear that the pressure in the hose will eventually blow the fittings off. The oil you applied only makes it worse.
This happened to me a few months ago. And my fittings had ridges! But they were plastic and deformed from the heat, so same problem.
What you need is metal fittings with at least one raised ridge that the hose clamp cannot slide over. If you look at the heater you removed, I bet you will find such a ridge on each pipe.
If you were not 2000 miles away, I'd trade you a herd of stray "mousers" for one of those home-cooked meals.
Elliot
Old 03-14-2010, 10:04 PM   #18
Chassis: Carpenter
Engine: 7.3L Diesel
Is that whats going on....trying to keep it all on the bus... really that's what I'm here for....NO don't say its true!! your right, huh? again, now three times...what if i left it like that with that valve in the drivers area closed and didn't use heat for the summer?? is there still pressure?
Old 03-14-2010, 10:09 PM   #19
Chassis: Carpenter
Engine: 7.3L Diesel
It seems that everyone is very hungry? I shall cook a feast for all...(but not the mice)
Old 03-14-2010, 10:10 PM   #20
Chassis: Carpenter
Engine: 7.3L Diesel
lots of snakes would solve my mice problem.....
I FINALLY GOT MY FIRST BUS! HELLO FRIENDS! BuffaloStampede81 Conversion General Discussions 13 04-23-2012 09:44 AM
We finally picked up our skoolie frank-id Mechanical and Drivetrains 7 07-01-2011 11:35 PM
Finally freakn Skoolie Conversion Projects 1 05-28-2011 07:16 AM
Finally- We're bus owners Duckf00t Skoolie Conversion Projects 12 06-15-2009 08:59 PM
Finally got a bus dieselman69 Conversion General Discussions 3 03-24-2009 09:11 AM
