Old 05-05-2010, 12:44 AM   #71
Coachwork: International Harvester
Chassis: Carpenter
Engine: 7.3L Diesel
Re: Finally Moliska is joining skoolie.net!
cheese thanks for the welcome....ell, gosh i don't like the looks of that picture....man o man... about the thread sealant, i got some pipe sealant in a tube that is supposed to be able to withstand hi temps.. yes it is the correct size and yes to the hose clamps.. how hot do ya think this piping will get? should i take any extra precautions building around it? thanx for all the groovy input all!!
moliskaIH is offline   Reply With Quote
Old 05-05-2010, 06:26 AM   #72
The same as or just slightly less than the "engine temperature" on the gauge. Water boils over at 212F/100C, plus with proper anti-freeze and a pressure cap, the temps can safely run higher. I would guess no more than 240F maximum under pressure when climbing hills.
Old 05-05-2010, 12:24 PM   #73
Elliot Naess's Avatar
Engine: 5,9 Cummins
Right, and the sealant in a tube will be fine also.
This same hot water circulated in that area since the bus was new, so it's not going to set anything on fire.
Elliot
Old 06-15-2010, 12:39 PM   #74
Year: 88
Engine: 7.3 international
your latest setup for the coolant is perfect.
for more advice on your engine problems i would head over to oilburners.net forums. the engine you have is 6.9 or 7.3L international (ford used them too). will the engine turn over? do you get a click from the solenoid? if you touch a screwdriver to the two large posts of the solenoid will it turn over? spark? (make sure it's in neutral for that test!!!!)
if it turns over but doesn't fire 90% of the time it's the glow plug system. see above site for more help there.
joining the u-haul club.
jam0o0 is offline   Reply With Quote
Old 06-21-2010, 07:29 PM   #75
Chassis: Carpenter
Engine: 7.3L Diesel
geez,.. a lot has been going on with my little world.. I had to move about a 3.5 hour drive from the bus. I have not even had a chance to finish cleaning all those rusty tools OR been able to put my new set up for my 90's on. Very bummed about leaving all my projects. I am now going back to school. But I do have an awesome landlord so maybe the break between summer school and the fall semester I could get her going and park it up here. that would be cool. I dunno.......
I FINALLY GOT MY FIRST BUS! HELLO FRIENDS! BuffaloStampede81 Conversion General Discussions 13 04-23-2012 09:44 AM
We finally picked up our skoolie frank-id Mechanical and Drivetrains 7 07-01-2011 11:35 PM
Finally freakn Skoolie Conversion Projects 1 05-28-2011 07:16 AM
Finally- We're bus owners Duckf00t Skoolie Conversion Projects 12 06-15-2009 08:59 PM
Finally got a bus dieselman69 Conversion General Discussions 3 03-24-2009 09:11 AM
