Old 03-24-2016, 04:50 PM   #11
Coachwork: GMC
Chassis: Bluebird
Engine: CAT 3116
Rated Cap: 71
Yes but don't know how much
herb_woof2 is offline   Reply With Quote
Old 03-24-2016, 05:26 PM   #12
CaptSquid's Avatar
Chassis: HDX
Engine: Cat C7
Rated Cap: 84 passenger
20 years? HA! I had Jurassic Dust Bunnies on my forward heater. Rinsing that out clogged the deep sink.
I'm thinking of cutting those out of the coolant loop and installing a hydronic heater instead, because they rely on the big engine running in order to heat the joint.
Old 03-24-2016, 05:34 PM   #13
Chassis: TC2000 RE
Engine: 8.3l Cummins
What about defrosting the windshield?
aaronsb is offline   Reply With Quote
Old 03-24-2016, 06:18 PM   #14
CaptSquid's Avatar
Chassis: HDX
Engine: Cat C7
I think you're misunderstanding what I meant. I have THREE heaters in the cabin: one in the driver's area, two in the kid's department. I'm thinking of cutting out the two in the kid's department and installing a hydronic heater for the rear, because those heaters require the BIG engine running in order to heat the joint.
Old 03-24-2016, 06:27 PM   #15
Coachwork: IC
Chassis: CE300
Rated Cap: 32
Who needs an engine to heat a joint?
Roll Your Own Build Thread
Old 03-24-2016, 06:56 PM   #16
opus's Avatar
Chassis: All-American R/E
Webasto.....
Old 03-24-2016, 08:01 PM   #17
Coachwork: GMC
Chassis: Bluebird
Engine: CAT 3116
Rated Cap: 71
hydronic heating
Now I'm confused, isn't what I have in the kids compartment hydronic heating, it circulates hot liquid from the engine compartment. What do you have in the kids department, electric heating ? what kind of power you pulling to run that.
Do busses have two different ways to heat a moving bus?
Old 03-24-2016, 08:03 PM   #18
Coachwork: GMC
Chassis: Bluebird
Engine: CAT 3116
Rated Cap: 71
Old 03-25-2016, 08:59 AM   #19
RHOMBUS's Avatar
Chassis: Freightliner HDX
Engine: CAT 3126B250
I'll be going with a webasto. Will have to get creative with the duct work for defogger.
My project: The Cruel Bus
RHOMBUS is offline   Reply With Quote
Old 03-25-2016, 01:16 PM   #20
Robin97396's Avatar
I think you're all misunderstanding each other. Removing the rear heaters or moving them to the passenger area doesn't affect the defrost system. This conversation is going like a drop of mercury hitting the floor.
« Qwerbus | seats out »
