Old 03-22-2016, 04:59 PM   #1
Coachwork: GMC
Chassis: Bluebird
Engine: CAT 3116
Rated Cap: 71
Finally she's home
So I finally got her home, not a bad ride infact she took the short ride pretty well, about a hour drive, I was concerned because the bird was blowing white smoke and a lot of it in the first 5/10 min of running. But it stopped after she really warmed up. 225,000 miles on the odometer on a cat 3116 diesel, hoping this is normal for one that was sitting around.
Took out the first twelve seats today, my grinder is my best friend let me tell you. only used 3 metal pads on those bolts felt lucky.
http://www.skoolie.net/forums/member...cture12870.jpg
herb_woof2 is offline   Reply With Quote
Old 03-22-2016, 05:04 PM   #2
Coachwork: GMC
Chassis: Bluebird
Engine: CAT 3116
Rated Cap: 71
http://www.skoolie.net/forums/member...cture12871.jpg
Old 03-22-2016, 05:09 PM   #3
Coachwork: GMC
Chassis: Bluebird
Engine: CAT 3116
Rated Cap: 71
big bird
Old 03-22-2016, 05:13 PM   #4
Coachwork: GMC
Chassis: Bluebird
Engine: CAT 3116
Rated Cap: 71
Seat frames
Has anybody tried using the bottom section of the seat frame to secure the water tanks and black water tanks as a frame. ?
Old 03-22-2016, 05:14 PM   #5
I was thinking along those lines, if I get a bus with square tubing for the seat frames.
Old 03-22-2016, 05:25 PM   #6
Coachwork: GMC
Chassis: Bluebird
Engine: CAT 3116
Rated Cap: 71
They are square and look tone the right width for a tank to fit in between when turned upside down. Just a thought
Old 03-22-2016, 05:41 PM   #7
Docsgsxr's Avatar
Engine: Cat 3126b 250 HP
Rated Cap: Only 1 seat
Awesome, another build to watch and ideas to borrow!
My build thread - viewtopic.php?f=9&t=467197
Old 03-22-2016, 05:59 PM   #8
Roadrunner's Avatar
Chassis: TC 2000
Engine: 5.9
Rated Cap: 83
Don't borrow them, steal them. That's how I roll. LOL!
Hopeless Busaholic!
Roadrunner is offline   Reply With Quote
Old 03-22-2016, 06:06 PM   #9
Roadrunner's Avatar
Chassis: TC 2000
Engine: 5.9
Rated Cap: 83
Its a good feeling getting your bus home, good for you. Now let the work begin.
Hopeless Busaholic!
