Old 02-10-2015, 07:43 PM   #1
Chassis: Thomas MVP
Engine: 5.9l Cummins 6bt, 12 valve
First Conversion
Hey all, this is my first post here! Just acquiring a 1990 Thomas MVP with the 6bt 12 valve in it. I'm 19 and decided to take a break from college, so not a whole lot of funding is available for this project. so if it comes across a little redneck.... bear with me
Anyways, the conversion was already started by the person I'm purchasing it from, but I'm going to be improving and cleaning up on some of the stuff he started. The bus already has a solar and charge control system in it, with extra deep cycle batteries and a 1000w inverter. A bunch of framing for shelving and the bed is done, and a kitchen sink and propane RV oven are installed. I plan on putting carpet and laminate wood flooring in to start the conversion off. As of right now, there is no plumbing installed. Planning on putting a fresh water tank under the bed in the rear, and hanging black and gray water tanks under the skirting on the outside, dumping an RV toilet straight into the black tank. For a shower, I'll install a shower pan (actually a feed tub that's 24x36 inches I got for a steal at Tractor Supply...) and I'm looking at the ecotemp L5 propane tankless water heater/ shower combo. I have a friend who did a bus, and this heater is what he used, but he retrofitted it slightly so that he has another outlet to run hot water from the shower unit into other places in his rig. Attached are some current pictures, and a CAD drawing of the original/ current floor plan.
comtb is offline   Reply With Quote
Old 02-13-2015, 06:02 AM   #2
Coachwork: IC
Chassis: CE300
Rated Cap: 32
try uploading the pics again
Old 02-13-2015, 09:40 AM   #3
Chassis: Amtran
Rated Cap: 71
Hi, welcome to the madness. I'm also in the process of converting, but at a stand still due to cold weather. I'm going with potable water and grey only and a nature's head composting toilet (toilets that separate 1 from 2 appear to work best). Sounds like you have a nice start to the conversion. I'm frustrated by the cold weather but I guess its been a blessing of sorts because I've been able to do a bunch of research and purchases. To check on the solar work that you've inherited, I would recommend going to Handybobs solar page, he really understands RV solar.
Good luck and enjoy the ride.
"This is my ship...the Nebuchadnezzar, it's a hovercraft."
~Morpheus
The Nebuchadnezzar is offline   Reply With Quote
Old 02-13-2015, 04:58 PM   #4
somewhereinusa's Avatar
Chassis: AARE
Engine: 3116 Cat 250hp
Rated Cap: Her, me and Molly
Pictures? We need pictures!!!!
Old 02-13-2015, 05:59 PM   #5
bapos's Avatar
That or the links you took them from or broken
Here is my school bus conversion thread http://www.skoolie.net/forum/viewtopic.php?f=9&t=10282
Pics of my conversion @ photobucket http://s18.photobucket.com/albums/b1.../School%20Bus/
Old 02-16-2015, 06:46 PM   #6
Chassis: Thomas MVP
Sorry, its been a few days. Been busy on the project. First off, here's the photos I tried to upload in that first post...
All "before"
Now, on to the last few days.... I've remodeled to include the sink next to the stove, and make the counter into an L shape to better divide the kitchen and living area. Fridge is now under the counter. Sheeted in the bathroom and cut out overhead shelving where headroom was needed. Got a Coleman furnace and wired it in to a simple thermostat, and gave it a nice little box home. Put a freshwater tank under the bed with a pump and piped in the sink and toilet with pex. Still waiting on the tankless heater. Also built a couch with storage space underneath and ran some rope lighting. Also put in a wardrobe cabinet and computer area. Next up is insulating the floor with 1" Dow foam board (tuff-r w/ foil backing) and 1/2" OSB on top. Then I'll varnish the OSB with 3 coats, and lay down carpet on top, excluding the bathroom and kitchen area. The big job will be hanging black and Gray water tanks here when it gets a bit warmer.
"After" pictures. Sorry about some of the mess!
Old 02-17-2015, 10:28 AM   #7
Chassis: Thomas MVP
So apparently my flickr links are still broken
.. Here's direct uploads.
After/ in progress
Old 02-17-2015, 10:32 AM   #8
Engine: 190hp 5.9 Cummins
That worked.
Thx for the pics.
Old 02-17-2015, 01:42 PM   #9
Coachwork: IC
Chassis: CE300
Rated Cap: 32
Cozy looking.
Old 03-02-2015, 11:41 AM   #10
Chassis: Thomas MVP
Sorry it's been so long. Since last update, floor insulation and sheeting has been finished, and it makes a huge difference! Carpet in the back bedroom and wood floor from the kitchen forward. Toilet is plumbed in and cushions have been found and resewed to fit the couch. Added a table and seats, as well as curtains are being sewed. I think I'm going to sew mylar emergency blankets to the back of the curtains to help with insulation. I also need to figure out which windows I'm going to be blocking out permanently. Also, does anyone have suggestions on tank hanging? The black water tank is hung via all thread and straps of steel... But it doesn't feel as beefy as I would like.
