Old 07-27-2011, 12:33 PM   #1
Rated Cap: 47
Re: First Timer, 1983 GMC Conversion
Wow, that thing is awesome.
Motobus is offline   Reply With Quote
Old 07-27-2011, 12:43 PM   #2
Diesel Dan's Avatar
Engine: DT466/AT545
Looks like a Thomas high top body though a little hard to tell from the rear view. You'll be enjoying all that headroom. The wood powered water heater is awesome! I also like all the wood inside. Not sure I would have gone the corrugated tin route to skin the windows, but once you paint it that should blend in better. You might want to look out for leaks at the ends and/or add some extra caulk.
Gallery:
Conversion Thread:
viewtopic.php?t=4959
Old 07-27-2011, 01:45 PM   #3
pipopak's Avatar
"2. build a bed frame in the back with fresh water tanks underneath the bed"
I'd suggest to put the tanks into some sort of pan draining to the outside just in case....
pipopak is offline   Reply With Quote
Old 07-27-2011, 03:03 PM   #4
Hey WokeUp --- welcome to the Looney Bin. Looks like you have a big head start there. Best of luck with the work ahead and do keep us up on your progress. You'll find plenty of help, sympathy and opinions here.
Old 07-28-2011, 09:43 AM   #5
Hey Woke --- check out this paint additive. Can't vouch for all of them, but I have seen the results for this stuff and was amazed. A friend mixed it with cheap-o latex and used a long nap roller to put it on the inside of an old corrugated tin roof here in Houston. The results were nothing short of amazing. Took me up to the newly built second floor and I put my hand on the tin roof on a 100+ day...barely even warm! No other insulation on his 80 year old warehouse roof but the paint with the ceramics added. Yes...I am definitely doing the roof of my bus with it. Inside & out.
Note...there's a bunch of similar stuff out there but these are the folks who developed it for NASA...
http://www.hytechceramics.com/
Old 07-28-2011, 11:56 AM   #6
The stove is awesome. Looks like a ski lodge in there. Regarding the lack of fresh water and grey water tanks, I guess the original owner had it hooked up to a septic tank or sewer and some pressurized water source? After all the work they did on the interior I am a little surprised that the exterior bottom half of the bus was left the original color. You might be able to save yourself some work by just painting over the yellow with something that goes well with the existing grey and white. I also think you're safe parked by that pool. A rusty windowless van would be a real problem though.
Christopher
skoolz out is offline   Reply With Quote
Old 09-27-2011, 10:12 AM   #7
lornaschinske's Avatar
Rated Cap: 89
We are using a standard automotive battery to crank the bus, when we're not using it to power the 12vDc stuff in the food cart. Someone here told me that it won't crank the bus engine so we must be doing something wrong. We also used a single 12vDC auto battery to crank up the DD 8v71N65 diesel engine in the Eagle 05 as well. Over on the coach forums, that is what they use once they remove the huge OTR air conditioner unit. So we figured if it would crank the Eagle engine, an automotive battery would crank the BlueBird. So that is what we put in when we bought the bus to drive it home. Kept the same battery to move the bus from NC to NM (11 days of driving and the battery started it every time with no problem). But an "expert" here says it won't turn it over so we must have hooked it up wrong.
We full-timed in a 22 ft Class C with a 75 lb Borzoi/Husky Mix dog and 16 lb Maine Coon Mix cat (dog died and cat ran away looking for the dog). Dog and cat slept on our bed all day. We had A/C and furnace. They both liked the RV. Dog liked to sit in the rear bed while traveling and look out the window, sticking her tongue out at all the other dogs she saw. Both my pets were "couch potatoes" and into conserving personal energy.
Campgrounds don't take kindly to a dog barking all day while you are gone. Also, microchip your pet!
Fulltime since 2006
Old 09-27-2011, 11:30 AM   #8
syke's Avatar
Chassis: All American RE
We are not full timers yet but will be starting in March of 12. We have 3 cats and one dog. All of which hang out in the bus on a daily basis while we are working on it. As far as temps go, short of having an hvac system on a thermostat like in a house you are pretty much going to have to monitor it. Unfortunately living in a poorly insulated metal tube does present some issues.
As far as the starting battery goes, I can only share my personal experience with our bus. We have 2 starting batteries, both size 8D. That is more than enough to spin the 8.3 cummins. According to the records we received with this bus, the batteries were changed out in July of 2002. If I'm reading it correctly we are going on 10 years with the same batteries. All I do is put them on the float charger every month or so and they just keep on going.
I'm sure the bus could be started on a much smaller Walmart battery but at what cost? You could sting enough AAA batteries together to get it started also. It could even be turned over by hand if you had enough leverage, but why. I would recommend you run the battery spec'd by the manufacture. There is a reason the engineers decided on a certain size battery and I tend to rely on their R&D. In my opinion only of course.
Good luck and have fun.
By the way I dig the wood work and the iron stove. Way cool.
Ryan
Bluebird All American RE: Great White Buffalo (gone but not forgotten)
Our build thread: viewtopic.php?f=9&t=10065
syke is offline   Reply With Quote
Old 09-27-2011, 03:06 PM   #9
Rated Cap: 89
Originally Posted by syke
We are not full timers yet but will be starting in March of 12. We have 3 cats and one dog. All of which hang out in the bus on a daily basis while we are working on it. As far as temps go, short of having an hvac system on a thermostat like in a house you are pretty much going to have to monitor it. Unfortunately living in a poorly insulated metal tube does present some issues...
Lots of folks live full and part time in sticks-&-staples RVs with pets. These have only 2 inches or so of foam insulation in them. All the pets survive just fine. Go here and ask how they do. BTW, we do not have an HVAC system. We have a loud 1984(?) Coleman TSR rooftop air conditioner. Our furnace is roughly the same age and we have a White-Rodgers thermostat on it. One of these "high tech" ones...
Fulltime since 2006
Old 09-28-2011, 01:08 PM   #10
syke's Avatar
I think you may have misunderstood my post. I never said it was not possible. In fact quite the opposite, it's very doable and done all over the world. I understand the normal RV's lack of any discernable amount of insulation, just like our buses. Except they live in a fiberglass and plastic tube.
On the other hand you do have an HVAC system. You listed the rooftop AC, the old furnace which covers the H part and if you open a window you will have the V part covered. And it's on a thermostat to boot. Excellent. You have it covered just fine.
Woke_up_new, if you get a minute, let us know how the ceramic paint additive works out for ya. I'm reading about doing something along those lines on the roof.
Ryan
Old 09-28-2011, 04:30 PM   #11
Rated Cap: 89
... On the other hand you do have an HVAC system. You listed the rooftop AC, the old furnace which covers the H part and if you open a window you will have the V part covered. And it's on a thermostat to boot. Excellent. You have it covered just fine...
HVAC Systems are generally ducted systems in which the Heating, Ventilation and Air conditioning all uses the same ductwork system for delivery of the air. I used to be a K&B Designer. Part of my training was to study and understand the use and planning of a residential/commercial HVAC system. Rarely is a stand alone furnace, stand alone non-ducted air conditioner and an open window considered to be an HVAC system. The only reason our furnace is ducted is because we built the plenum and ducts for it. I also do not consider a cassette toilet to be a human waste system, although I guess you could call it that. But so is an out house.
sorry if this comes across as bitchy. I manged to hit my head, not once but twice today on the rear emergency door. I have to take two M&M's and watch TV in bed! Ouch!
Fulltime since 2006
Old 09-29-2011, 12:04 AM   #12
bus-bro's Avatar
Engine: 3208 na boat anchor
That ol' H-Vac. I remember, years ago, when I applied for a job and they asked about my experience with HVAC, and I said yes, I know how to work on high voltage AC (not!). Didn't get that job.
Anyway, about HVAC, just run a Heat Pump Mini-Split off an inverter. When you figure that out, let me know.
Old 11-03-2011, 04:42 PM   #13
Originally Posted by woke_up_new
**Is a marine battery enough to start the bus? From what I've read in the Boatowners Mech manual it seems like they're not really designed for turning over a motor necessarily.
"Cranking" batteries have lots of thin lead plates inside. They are designed to dump a lot of amperage in a hurry, but to only drain a small percentage of their overall capacity. I.e., you run them down 5% cranking an engine, and then they get immediately recharged. They'll do that for thousands of cycles.
"Deep Cycle" batteries have fewer, but thicker, lead plates. They are designed to dump a lesser amperage over a longer time. I.e., you run them down to 50% slowly, and then recharge them. They'll do that for thousands of cycles.
Either can be used for cranking, but when using deep cycle batteries for cranking, you sometimes need an extra battery to achieve the necessary "cranking amps", because those batteries have a bit lower cranking amps rating due to the thicker lead plates.
While you can use a deep cycle battery for cranking - you can't go the other way. I.e., cranking batteries should never be used for deep cycling. Draining a cranking battery much below 5% will reduce the number of cycles of its useful lifespan. Take it down by 50% instead of 5%, and you may only get a couple of hundred cycles out of it rather than a couple of thousand before it has reached the end of its useful life. Run it completely dead and you may only get a dozen cycles before it becomes useless.
"RV/Marine" batteries are a compromise between the two - fewer, thicker lead plates than a cranking battery, but not as few or as thick as a deep cycle. They'll do a little better at cranking than a deep cycle - though not as well as a true cranking battery; And they'll last more cycles than a cranking battery when heavily drained - though they won't do it for as many cycles as a deep cycle.
All the battery types do indeed have CA (cranking amps), CCA (cold cranking amps), RC (reserve capacity) and AH (amp*hours) ratings - but not all the numbers will be listed in the specs. For a cranking type battery, the manufacturer will generally refer to the CA, CCA and RC numbers, while for a deep cycle type battery, the manufacturer will generally refer to the AH numbers.
-=dwh=- is offline   Reply With Quote
Old 11-05-2011, 07:23 PM   #14
=dwh= is right about battery design. That does not mean that any particular battery might or might not start your particular engine.
But I would check all your wiring connections. Take them apart, clean them, and put them back together properly tight. Add anti-corrosion paste or vaseline if you are so inclined. I have seen people who though they needed new batteries when all they needed was to replace a wire . . .
The 2-year old battery in my work truck started it fine, but if l so much as left the key on while pumping gas to record the odometer reading, it would need a jump to get started. After cleaning up the battery terminals, it is 300% better. Even an ohm or two of extra resistance in the wiring not only prevents full draw on starting, it also prevents the battery from getting fully charged . . .
First timer questions/help caster Conversion General Discussions 3 01-22-2014 10:30 PM
First Timer, 92 Wayne 7.3 grnthmb55 Skoolie Conversion Projects 29 05-14-2012 10:22 PM
Full-timer ID Problems lornaschinske Everything Else | General Skoolie Discussions 3 02-22-2012 10:29 PM
Full-Timer + Broken Bus? gbstewart Conversion General Discussions 4 02-24-2011 08:56 PM
1st Timer - Lots of Questions tajones825 Conversion General Discussions 5 08-05-2008 02:45 PM
