Old 05-14-2012, 04:50 PM   #1
Chassis: TE2000 FE
Engine: 5.9L Cummins
Floor repair
What gauge sheet metal has anyone used for floor repair. Did you pop rivit weld or screw down? I was thinking about screwing repair sheets down. Any experiance?
Thanks Chuck
cschlessman is offline   Reply With Quote
Old 05-15-2012, 01:25 AM   #2
Re: Floor repair
i havent checked, but its somewhere like 16ga. its easy to mig weld after ya grind it clean, i have done that, and also predrilled holes for things like the center of the walls and the dinette base. i used 18 ga when i was making up a couple of patch panels cause that is what i buy in sheets at the scrap yard. pop riveting with steel rivets would work fine as well, and be easier than screwing it together in my estimation...
i just put about 100 pop rivets in some panels on mine... on sunday.
Old 05-15-2012, 12:15 PM   #3
Chassis: TE2000 FE
Re: Floor repair
Thanks for the reply sounds like riets would be easier then screws. They look like they would lay flatter then a screw head. Thanks Chuck
Bus Engine Repair / Replacement in DC / MD Burning Hamm Skoolie Conversion Projects 1 11-16-2014 08:05 PM
Looking for any repair for an ABS fuel tank. frank-id Everything Else | General Skoolie Discussions 4 04-16-2012 12:41 PM
Repair window latches? dunstergirl Conversion General Discussions 1 05-25-2009 06:54 PM
Air-Ride seat repair? letz4wheel Conversion General Discussions 6 12-12-2008 07:31 PM
Emergency repair kit w1bmw Conversion General Discussions 11 08-02-2006 10:03 PM
