Old 04-09-2011, 08:49 AM   #11
Seeria's Avatar
Re: Fran (Sinclair) skoolie
Will have to get more shots later. This is one side of engine and I found one that shows the dampness I mentioned on that thingymagigajig.
Old 04-09-2011, 10:04 AM   #12
RevBill's Avatar
Coachwork: - Still Shopping -
Chassis: - Going Medium/Large -
Engine: - DT466 Desired -
.. hey .. you got a free kid on your hood .. pretty kewl ..
... edit .. btw .. looks/reads like you already have started your project and your education on YOUR skewlie .. very kewl Seera .. now go knock 'em dead and make her the envy of us all ..
Chance favors the prepared mind. - L Pasteur
Luck is the residue of good planning. - B. Rickey
Travel is fatal to prejudice, bigotry, and narrow-mindedness ... - M. Twain
RevBill is offline   Reply With Quote
Old 04-09-2011, 03:45 PM   #13
Diesel Dan's Avatar
Engine: DT466/AT545
Congratulations on finally getting your bus! I think your most expensive repair will be buying the new front tires. That is assuming the transmission is okay. You will definitely want to get the temp gauge fixed though. The DT466 has a tendency to overheat so you need to watch it. Your battery may be dead, but then again your alternator may also be dead. Try charging the battery with a battery charger and see if it takes a charge. If so, I would suspect the alternator. A new alternator is fairly cheap for the DT466, I just got one for...can't remember...it's in my thread somewhere recent.
Good luck with the bus, and happy converting!
Gallery:
Conversion Thread:
viewtopic.php?t=4959
Old 04-10-2011, 10:04 AM   #14
Seeria's Avatar
Thanks Dan
We have a chance to paint in good conditions Tuesday so are working fast to get rust, lettering and other tidbits done in order to paint. Having bit of trouble getting that dang stopsign arm off.
I get it.... crow bar
Old 04-10-2011, 06:05 PM   #15
Seeria's Avatar
Anyone have suggestions for removing these buggers?
Old 04-10-2011, 07:51 PM   #16
bus-bro's Avatar
Engine: 3208 na boat anchor
May I suggest an angle grinder directed against the rivet head. Then, hammer and chisel.
I'm such a simple guy. That's all I know.
Old 04-10-2011, 08:07 PM   #17
Coachwork: THOMAS
Chassis: SAFE-T-LINER
Engine: CAT 3116
Rated Cap: 83
Regarding the gauge cluster. The entire cluster almost always goes bad on those Internationals. Do all the other gauges work ok? You might just have a couple isolated problems. (Alternator, bad temp sensor etc..)
BUSBOZO is offline   Reply With Quote
Old 04-11-2011, 07:17 AM   #18
Seeria's Avatar
Just the temp gauge.
We've managed to get her scrubbed, leaks plugged, de-rusted, primed, and everything required off minus the flashing lights. Wisconsin is a bit strick on those dang lights. Figure work on them today and set her up to paint tomorrow, granting the weather continues to hold. Then just have to wait for the state patrol to get here to approve her as a RV or truck (haven't decided yet). Last time I called about the topic they said it could be a week before they showed up Figure that will give me time to get more inside demo done
Once we get her lincesed (looking for 20th or so) I'll get started on the tires, that darn battery prob and the temp guage.
Have to say OMG my body hurts lol
10 weeks to go
Old 04-11-2011, 10:13 AM   #19
Diesel Dan's Avatar
Engine: DT466/AT545
It's hard to tell what surface those are attached to. Is there a nut backing up those bolts, or are they lag bolts? If it's on a horizontal surface, I'd use penetrating fluid and an impact wrench or a breaker bar with an extension bar. You could just use an angle grinder of course, but I suspect you would have to cut each bolt twice: once to get the head off and remove the plate underneath, and then again to eliminate the protruding shaft of the bolt.
Gallery:
Conversion Thread:
Old 04-12-2011, 06:41 PM   #20
Seeria's Avatar
Work progressed on Fran today-- lots of seam filling, holes plugged, rust removed and taping up precious parts of her body in prep to give her a foundation layer ....
Caught her with her makeup half done!
New Skoolie Conversion and Old Skoolie Remodel jlhollowx13 Skoolie Conversion Projects 0 01-22-2013 01:41 PM
Sinclair Seeria Skoolie Conversion Projects 35 03-15-2011 12:54 PM
