Old 12-08-2015, 03:24 PM   #1
Chassis: MVP SAF T LINER0
Engine: cat
fresh water tank install.
My question is there are two outlets on the bottom of the tank then a air vent on top. I know one goes to the water pump but not sure on the second? what does that second one do?
someguy is offline   Reply With Quote
Old 12-08-2015, 04:33 PM   #2
Water in? Unless there is some other way of doing it?
CaptainInsaneo is offline   Reply With Quote
Old 12-08-2015, 06:44 PM   #3
one line for the water pump, and the other maybe for a drain. that's the way mine is, then on the top there's the fill, then the vent.
Old 12-08-2015, 08:58 PM   #4
Engine: cat
thanks for the advice I will use it for a drain.
