08-25-2015, 11:41 PM
From Bluebird to Phoenix
This is our bus, The Phoenix, a 40' 1996 Bluebird TC 2000 with a 6BT Cummins engine, Alison AT 643 trans, and around 167k miles.
She's everything we wanted in a bus: flat front, 40', with five large storage bays. She came home from Colorado last week, and we’ve been removing seats, decals, and a whole lot of screws bit by bit.
This is the interior. We were happy to discover an interior ceiling height of at least 6'3". It was a handicapped bus, which sounded great (yay, fewer seats!), but we quickly realized that removing the wheelchair rails makes up for any work saved removing seats. There’s also a Ricon chair lift, which we’re hoping to sell.
With every emergency exit sign (we had 6 of them), an existential saying.
We assembled a bench out of the bus seats. I’m hoping to incorporate these into the build, because some of them have 5-point children’s harnesses, and we have kids.
Can anyone recommend a way to remove the wheelchair rails over the windows? They’re secured with bolts, and I can’t get a socket wrench in there to remove them. I’d rather not grind them out if there’s a better way.
Thanks for reading, and I look forward to sharing our build here.
08-26-2015, 12:25 AM
Engine: 190hp 5.9 Cummins
Cool.
I have never seen a wheel chair tie down rail over the window before.
Most are only on the floor.
Take a socket of the right size to a grinder and make the walls of the socket thin enough to fit into the opening.
Or try a different brand of socket. Cheaper brand socket tend to be thicker walled than better brands.
I have a few trimmed down sockets in my tool box.
08-26-2015, 09:02 AM
Welcome Phoenix --- what a great find! That engine /tranny combo and the underbelly storage make for a terrific starter platform. Best of luck with the build out and please do keep the pix coming.
08-26-2015, 09:27 AM
Rated Cap: 40 Prisoners
Depending on the size of the bolts I would use a good impact
wrench and as the bolt starts to come out I would put a small
pry bar under the bolt head or bracket to keep friction on the
nut as you remove the bolt. I removed all my seat bolts with
a 1/4" drive Lithium Ion impact that would go to 55 ft/lbs.
But they were all 1/4" bolts. You could also lube the underside
of the bolt head to decrease the friction on the bolt just don't
get the lube on the face of the nut.
08-26-2015, 08:26 PM
Maybe you can utilize the wheelchair rail by putting rope lights down it and covering them up with a strip of opaque plastic.
08-26-2015, 09:02 PM
Chassis: Blue Bird
Engine: ISC 8.3
Harbor freight and pawn shops are good sources for one-off tools destined to be "customized" like this.
08-26-2015, 09:30 PM
Our TC has the WC belt rail also.
Don and Mary
08-27-2015, 12:19 AM
Thank you for all the recommendations and info. I lubed the underside of the bolt heads, found a thinner walled socket, and went to work. The sun was shining on one side of the bus, and I think that gave the metal just enough expansion to remove the rail on that side. I wasn't so lucky with the other rail, but I'll try again in the morning when that side is exposed to the sun. If that doesn't do it, I'll grind down the socket. Only a few more bolts to go.
08-27-2015, 12:45 AM
I agree.
I sometimes go to pawn shops and buy 5 or 10 sockets at a time in the most common sizes I use.
Like 10mm, 12 mm, and 15mm. Those are the sizes that my Honda car uses.
That way if I loose one, no big deal.
08-27-2015, 12:58 AM
Yeah, we've been making twice-weekly trips to Harbor Freight lately. About to get more familiar with the local pawn shops, too.
08-27-2015, 02:29 AM
Here in my town, the pawn shops typically charge FULL retail. As though their merchandise wasn't crappy AND stolen.
I've never understood how they sell anything. Especially ladders!
08-27-2015, 05:17 PM
Grinding down the socket worked like a charm. Upper rails are out.
08-29-2015, 01:20 AM
We're removing the seats and floor rails, which is going to be a long process. Just thinking about the ceiling. I had hoped to 1) use closed cell spray foam in the ceiling and walls (I don't have an estimate for this yet, but several local companies do it), and 2) replace the metal ceiling panels with 3/4" plywood held in place by compression. But now that I see it, if I ignore all the speaker and lighting holes, I really like the shine and the rivets.
I'm also wondering how necessary that level of insulation is given our climate. It was 94F outside today, and working in the bus with the windows down and vents open was completely comfortable. We have a white roof, and it was least 10 degrees cooler inside (85 is comfortable for me). My dude was parked in the bus on the way home in Southern Nevada, and said it was tolerable with outside temperatures up to 110F (he bailed and found AC when it hit 115). If I lived in Canada or the Northern US, I wouldn't hesitate to invest in the spray foam. But we'll be in exclusively warm, dry places, and plan to keep a lot of ventilation going through the bus rather than closing it up (we're keeping the original windows, which aren't great for insulation, but I'm okay with that). I also don't want to lose much headroom, since I'm living with someone who's 6'3".
Has anyone who enjoys warm climates spray foamed your interior, and what was your experience? I know the foam is also useful for reinforcing the structure and preventing water and insect issues, so it might be worth it even if we're not doing it exclusively for insulation purposes. Is it possible to do a thinner layer to preserve headroom? Are there any other factors I need to consider?
08-29-2015, 08:08 AM
spray foam is nice, it will help cool the bus as well as heat it, also helps with noise.
I left my ceiling alone, and I'm happy with the way it is, a lot less work, less money and it looks fine. Also if you go to all the trouble to remove the ceiling and spray foam, you should up grade the windows as well.
08-29-2015, 10:21 AM
Chassis: Blue Bird
Engine: ISC 8.3
On using compression to hold 3/4" plywood ceiling panels: do you mean to just lift panels in the middle so that they arch upward and become wedged up? Plywood in that thickness isn't going to bend much; if it's wide enough to span the whole bus then I don't think it'll be going up near the ceiling at all. Something thinner like 1/4" luan plywood might be worth consideration.
I haven't lived with spray foam yet but it's on the road map for when my bus has sides again. I feel like insulation is the one thing that you have only one chance to install, and except for a very narrow band of climates, insulation adds value and comfort.
Shedding the interior metal definitely has upside for comfort, too. Heat conducts through it very well, so when it's hot outside the interior radiates heat at you (sounds like you've found this acceptable). Likewise when it's cold out, the metal skin radiates a chilling cold at you. Brrr!
08-29-2015, 12:12 PM
This is really good to hear in case we leave it intact. The two front ceiling panels are perforated for sound reduction, so we'll probably pull those down to see the fiberglass underneath, and maybe replace them.
Thanks for catching that. I meant 1/4" plywood, as done here:
I have a bunch of 1/8" that's definitely too thin to maintain any shape, so the 1/4" should work, even if I need to soak or spray it briefly.
Yeah, I am not looking forward to that. Hopefully we won't encounter cold too often!
08-29-2015, 03:48 PM
Honestly you could look into getting boat plywood you can get it with loads of different veneers and it is usually super thin and fairly strong. If you are really looking to do something crazy. You can always form your own laminate by creating two molds getting thin cheap wood veneers putting one down the glue then another thin sheet then glue... then clamp the top form on the bottom form let it cook and bam DIY shaped plywood that will never loose its shape. Would I do that, NOPE, I would just marine epoxy the 1/8in stuff to together in place to make my lazy version of doing it correctly.
09-05-2015, 06:55 PM
Bummer. Fortunately we haven't had to deal with this yet, as Harbor Freight and the Habitat ReStore are right around the corner. My dad just loaned us a bunch of tools too, so that's been a big help.
I think I'm even lazier, and would probably just buy regular 1/4" plywood, and then paint it in place. I like the cozy wood look on other builds, just not my style.
Seats are out:
The easiest way for us was me using a pneumatic impact wrench while mr. phoenix held a crescent wrench underneath the bus. I removed the seats bolted to the chair rail in the same way, using an extender and holding the crescent wrench underneath. I think he only ground out 1 or 2 bolts, and it went pretty quickly.
More bus carnage:
I also removed the rubber flooring, which was easy using a pry bar and box cutter.
Most builds I've read look nice and sequential, but ours just hasn't gone that way. The heaters, floor rails, and wheelchair lift still need to come out, but we got anxious and pried up some of the plywood. The metal sub floor (in this area, at least) is in great shape, except for some glue residue.
This was surprising considering all the holes from the wheelchair floor rails. But even if the rest of the floor is in great shape, that gallon of Ospho I ordered will be put to good use on some flaky exterior spots.
It has really taken some effort to get the floor rails out; I think we've removed 2 of the 10. For some of the bolts, I held an allen wrench while mr. phoenix used the pneumatic wrench under the bus. That worked okay, but not all the bolts were accessible from underneath. Then he tried this bit to drill through the bolts, but it was nearly useless:
Mr. phoenix is now doing a combination of cutting, grinding, and prying out the floor rails, God bless him. If you're thinking of buying a handicap-accessible bus, get ready for a lot of time spent removing the rails. Our one consolation is that the bus was a great price, and I'm telling myself it's worth it for the extra work.
09-05-2015, 11:49 PM
One suggestion, those step drill bits make terrible drills, I
would start by drilling a small hole with a good split point
1/8 in drill bit and go deeper than the bolt head and then
follow up with the step bit it will go much faster and you
can put some one drilling the pilot hole while some one does
follow up with the step bit. Keep bit speed where it produces
a nice curl of metal and it will last a long time. Cutting oil also helps.
09-05-2015, 11:53 PM
Wood type blades in saws work much better with aluminum than abrasive type blades do.
In short, any wood blade will cut aluminum well.
Abrasive blades only work with ferrous metals, like steel, iron, ect.
Drill bits like the step bit you show in the pic are made for soft metals. That one is just coated steel.
They do make cobalt step bits, but they start at around $100 each.
The more hardened a ferrous metal is, the better a abrasive blade works.
I would have had all those aluminum rails out in a few hours.
