Originally Posted by Hvbuzz
I don't see why a fuel cell wouldn't work. I have a onan CCK 5.0. I have ran a boat tank the last couple years. The primer bulb is handy to get it started quicker. But don't have to use it, because I can start it from inside the bus too. I have thought about adding a more permanent tank over by the buses main tank. Would make filling up easier.
20150614_151848 by Hvbuzz, on Flickr
I also see that your batteries are in the same location as the generator. is that right?
I was thinking of doing the same, since i have the storage under the bus at the back.
I have the same two cargo spots, front and back on both sides of the bus.
Should the generator go in the middle parts or is it ok at the back?
