Old 03-03-2008, 12:27 PM   #1
Year: 1987
Coachwork: blue bird
Chassis: Conventional
Engine: Gas
good deal or no?
My friends and I are going to buy a school bus to convert into a party bus to go to concerts, softball games, road trips, ect. We are looking at a bus that is currently in service by a school corp. it is a 1991 blue bird transit F/E diesle 71 pass. they are asking 2900 firm for it. Is this a good deal? It is still in service so I wont be able to go look at it, but what are some good questions to ask? we have a lot of ideas for it including 2 couches big screen tv, bathroom small kitchen area, and leaving the last 8 ft or so for motorcycle and 4 wheelers and such. we need ideas on how to do things as well. i have looked at some of the threds about electrical and plumbing, but don't understand a lot of the technical talk. we are a handy group of people but just aren't sure about doing a lot of things on a mobile unit. any tips suggestions things of this nature would be great.
Thanks,
Big Balls Softball team
-Scott
"Sotally Tober"
https://i246.photobucket.com/albums/g...98502_5384.jpg
bigballsbus is offline   Reply With Quote
Old 03-03-2008, 01:22 PM   #2
lapeer20m's Avatar
Re: good deal or no?
if it has a cummins 5.9 liter engine and mt643 trans along with a good rear end ratio like 4.44 or better i'd say go for it....how many miles?
with the above combination you can get 10 mpg. With other less desirable engine/trans/rear end combo's you might get as bad as 6 mpg. Just a couple of big trips can save ya quite a bit of $$ over the life of the vehicle.
the price is a little high for a used skoolie, but if you have the correct powertrain it's worth a little extra up front.
Old 03-03-2008, 08:33 PM   #3
Year: 1987
Engine: Gas
this is all the information it gives me...
1991 - Blue Bird - Blue Bird - Capacity 72
Bus Type: School Bus
Bus Category: Transit/FE
Mileage: 140,000
Capacity: 72
Availability: 5/08
Chassis Selection
Chassis Make: Blue Bird
Body Make: Blue Bird
Transmission Type: Auto
Fuel Type: Diesel
Transmission Model: AT545
Brakes Type: Air
is this still good?
-Scott
"Sotally Tober"
Old 03-03-2008, 09:20 PM   #4
the_experience03's Avatar
The AT545 isn't as desirable as the MT643, but it is still nothing to laugh at in terms of strength or dependability. It is safe to assume that the engine is a 6BT Cummins, the same engine used in thousands upon thousands of Dodge pickups. That is a huge benefit when it comes to finding parts and competent mechanics should the needs arise.
I'd like to say the price is a little high, but given the mileage it is still a decent price, especially if it is rust-free.
Check Indiana regulations on what is required to become registered as an RV and whether or not air brakes will be an issue on an RV without an additional license endorsement.
Beyond that, get some pictures and some more information if you want more advice. If you are serious and present yourself as such you should be able to get pictures from the seller and some information on the maintenance history of the vehicle. If not I would look the other way.
Old 03-03-2008, 10:29 PM   #5
Year: 1987
Engine: Gas
Well the thing is the bus is still in service by a local school district, the seller doesn't have any pictures or anything until the first of May. another reason that this bus gets my attention, its still in service it is being checked annually by state troopers and being worked on regularly, not just sitting in someone’s driveway until they plan to go camping. Here is my dilemma... to make sure I get it I need to put $500 down on it now, but that is hard to do not even seeing it. But once again being still in service I know it is going to be a reliable bus.
-Scott
"Sotally Tober"
Old 03-04-2008, 12:49 AM   #6
I would want pictures at the least. In service or not, that much should be possible from the seller. If not they are not very motivated to sell. It's hard to get past the excitement of that first bus, but as many will tell you "your" bus will come along. Perhaps this is it. Perhaps it is not. You want the best possible foundation to start from. All the work on the most beautiful conversion imaginable is futile if the shell falls apart around it or the engine up and chokes. There is a risk in buying a used bus just as there is in buying any other used vehicle. We typically benefit from exactly what you talked about...strict inspections and top notch maintenance. This is not a guarantee that you are not receiving someone else's junk, however. Still being in service does not mean the bus does not suffer from mechanical and age related ailments. Heck, my bus as a student suffered from a failed transmission and a wheelwell actually falling through the floor (rust), both times within eyeshot of my stop, but before I got on.
Basically, I'm suggesting that you take your time and do your homework now so that you won't be disappointed later. Get all the information you need to make an informed decision and go from there. If that means you have to pass on this bus, so be it. If you can get all the pertinent information and truly think and research it out and this bus is still at the top of the list, by all mean jump on it.
For what it's worth, even after I found "my bus" and did all the research to back up the immediate attachment I felt I still went on two separate test drives and inspections two weeks apart. Knock on wood, it also hasn't failed me yet.
Old 03-04-2008, 08:10 AM   #7
lapeer20m's Avatar
why not drive to the school district where the bus is being used and talk to the mechanic's that work on it. I'm sure they'll give ya some good info, and if you go around the time buses are returning back to the garage you can prob even check out the machine and possible get to talk to the person who drives the bus.
Old 03-04-2008, 11:08 AM   #8
Year: 90
I owned a very similar bus for about a year and was very happy with it. I only sold it because we needed money bad. However I drove the bus twice for a total of about 1 1/2 hours before commiting to buying it. I liked the powertrain combination and the price isn't too bad. That's about what I paid for mine and it was worth it. However after test driving it and crawling all around and under it I had a fair idea of the condition of the suspension, brakes, transmission engine and overall handling so I had enough info to make the decission. There is no way I would buy a vehicle like this sight unseen despite the fact that it is still in service. Bus parts arent cheap, tires alone will run ya about $300 each more or less. Transmissions and engines will cost you as much as 3 times the cost of that bus, each. At first it may seem like this is the only good deal in the area but look around a bit. At any given time I bet there are 40 of these or more within 500 miles of your home. Buy smart. You can experiment with your conversion and learn along the way but 1st spend your money on a good foundation. I learned the hard way. My first bus, although unfinished, died on it's maiden voyage. I had spent more on the conversion than on the shell, not to mention many hours of hard work. A lot of time and money waisted. Good luck . . .
Excalibrate is offline   Reply With Quote
Old 03-04-2008, 03:08 PM   #9
Year: 1987
Engine: Gas
thank you to all that have replied i have the day off school and work tomorrow and i plan to head up to the seller and ask them some questions face to face maybe try to find out what school corp actully has it as well, and if its close go to the school and see if i can't check it out. thanks for your help everyone and hopefully i can get some pictures or some more information at least!! talk to you all tomorrow!
-Scott
"Sotally Tober"
Old 03-05-2008, 08:31 PM   #10
Year: 1987
Engine: Gas
Ok so here is the deal. I went to the place that is selling the bus today, the one that I spoke about above sold over the weekend. But, the guy that I talk to today was much more knowledgeable than the guy that I spoke with on the phone. He also has 6 more coming in between April to June and the are all from the same school district. They are all 1991 transit/ FE blue bird 5.9 Cummins diesel auto transmission and with hydraulic brakes they are all 72 passengers and are ranging between 175000 to 220000. He said “I know this might sound weird but I would suggest that you guys get the one with the most miles because that means that this is the bus that they use the most and probably take on field trips and sporting events therefore being the more reliable bus” what do you guys think? They are asking 2700 for all of them and all I have to do is put down a $100 deposit and he will hold my check until I can come look at it when they come in. and if I don’t like it then I can get my deposit back.
-Scott
"Sotally Tober"
Old 03-05-2008, 08:34 PM   #11
Year: 1987
Engine: Gas
I also went to the school cooperation and tried to talk to someone about seeing the buses and the lady said that they are working on a skeleton crew right now because a lot of people got called up to serve. And she said that I would have to set up an appointment with the big cheese which she said is hard to get time with…
-Scott
"Sotally Tober"
Old 03-05-2008, 08:47 PM   #12
phillbus914's Avatar
For comparison I bought a 91 TC2000 (sounds like what these are) 4 years ago with 158K miles for $1850. Now these bus's are 4 years older (17 years old now, mine was 13 years old when I bought it) and they want 1,000 more than I paid. Based on that I wouldn't say they're a great deal. If it's the "perfect bus" it may be worth the extra money.
How are the tires? A new set can be $2000+
What gear ratio does it have? I have a 4.33 gears and average 10mpg if I drive it right. A bus that gets 6 mpg has to be refueled almost twice as often - thus costing 2x the fuel. Very important on a long trip, you could save hundreds of dollars in fuel with a bus that gets better fuel mileage.
Thats cool they will give you your deposit back if you don't buy the bus. I say have them hold it for ya, and keep looking for "your bus" if a better deal comes along get it, if not consider one of those buses.
My Old Bus :(
Old 03-05-2008, 11:41 PM   #13
Year: 1987
Engine: Gas
yes i would love to find one at that price, but i've looked and looked and looked here for a while now and i just can't seem to find anything at a reasonable price and location... i just can't find it practical to drive it home across the coutry, this one is at an ok price and less than 20 miles away. another thing is getting it home i don't have a cdl and so i can't drive it until it is "skoolied", my friend who has a class A will be bringing it home until i can get it stripped and have a state trooper come out and check it out.. this just seems to be the most practicle right now, and i still think its a huge bonus coming directly from a school. i don't know tho you guys probably know 100 times more than i do
-Scott
"Sotally Tober"
Old 03-06-2008, 08:47 AM   #14
Originally Posted by bigballsbus
yes i would love to find one at that price, but i've looked and looked and looked here for a while now and i just can't seem to find anything at a reasonable price and location... i just can't find it practical to drive it home across the country, this one is at an ok price and less than 20 miles away.
Keep looking... there's good deals out there, even close to home. You're right though a long trip can get expensive real quick, especially with diesel at 3.70/gallon. Might be a good idea to put down the $100 and have them hold it but keep looking for a great deal. If you find one get your $100 bucks back.
Where do you live? Maybe someone nearby knows a good source of buses.
I got my straight from the school district also... well from the bus dealer that took it on trade. I was able to talk to the bus mechanics before I picked out my bus. As soon as the dealer got the bus on they're lot I picked it up a few hours later. I had a great experience, and I'd recommend anyone looking for a bus to check with their local bus dealer and ask if they have any coming in on trade.
My Old Bus :(
Old 03-06-2008, 12:44 PM   #15
Year: 1987
Engine: Gas
im in the same boat as you phil. that is what i plan on doing i am going to put the 100 deposit and continue to look and the dealer also said that if something else cheaper that he thinks i might be interested in comes in he would call me.. i live in the indianapolis metro area if anyone knows of anyother place to look right now i dealing with midwest transit equipment
-Scott
"Sotally Tober"
Old 03-06-2008, 01:55 PM   #16
check with greg at florida church bus, I have never heard anyone say anything negative about him,bnusis that he has a storage yard in ohio,lima i think.
Old 03-06-2008, 02:39 PM   #17
Year: 1987
Engine: Gas
i checked his website, he didn't have anything in my price range i'll have to call him and see if he has anything else on hand that isn't listed what do you guys think about the whole "more mileage the better"?
-Scott
"Sotally Tober"
Old 03-06-2008, 03:00 PM   #18
Did you look on craigslist at all?
I'm looking and found a few good deals..
http://indianapolis.craigslist.org/car/593636904.html - 87 bluebird for $1200
http://indianapolis.craigslist.org/car/566985083.html - 88 chevy/international for $1100
http://indianapolis.craigslist.org/car/567706688.html - 79 international for $1200
http://indianapolis.craigslist.org/car/547580358.html - 87 short bus for $1260
http://indianapolis.craigslist.org/car/556311274.html - 91 GMC for $2000
All appear to be gas, but keep looking... Something will pop up.
My Old Bus :(
Old 03-06-2008, 08:22 PM   #19
Shoot...that first one is a steal. Offer them $1000...take out the 454 and sell it on Craigslist for $500. Sell the AT545 for $400 (and it would sell fast at that price). Sell the tires and wheels for $200. Scrap the rest of the bus for $900 (that's 10 tons at $90 per ton). Sit back and enjoy your $800 worth of beverage money. Of course that's a sad end for a bus and I can't condone those actions...
Old 03-06-2008, 09:29 PM   #20
Year: 1987
Engine: Gas
phill thanks for looking that up for me, i didn't even know about that site, i am going on a spring break trip to daytona beach tomorrow and i wont return until next sunday and i will check those out for sure. i am taking my laptop with me on the trip so if anyone else has anything to post i'll be able to respond with in a couple of days, and when i get back i'll keep you posted on what turns up from those listings thanks again for all of your help.
-Scott
"Sotally Tober"
Good deal for a bus? jmar896 Conversion General Discussions 135 11-14-2014 12:22 PM
Good Deal? Bus(ted) Classifieds | Buy, Sell, Swap 8 12-03-2007 03:23 PM
Blood Bus - Good deal? or Let it go! Freedomhauler Conversion General Discussions 22 10-28-2007 08:22 PM
my new bus - did I get a good deal? LCD Everything Else | General Skoolie Discussions 5 09-27-2007 08:12 AM
Is this bus a good deal? KC10Chief Conversion General Discussions 7 07-01-2006 09:37 AM
