Old 03-07-2010, 09:42 PM   #121
Chassis: Amtran Genisis
Engine: International DT-466
50 AMP Plug Installed
Today I installed the 50 Amp plug and did a few other things.
More on the blog!
For the latest on the "Good News Bus" visit our blog. https://www.goodnewsbus.com
Bus Project is offline   Reply With Quote
Old 03-08-2010, 10:29 AM   #122
Re: Good News Bus Conversion Project
I like that 50A power hookup. Is that a spring loaded cap on it? Where did you source it?
Thanks,
jim
baadpuppy is offline   Reply With Quote
Old 03-09-2010, 09:41 AM   #123
Thanks,
jim
The cap is not spring loaded. It is a Marinco 50 Amp Easy Lock RV / Marine Shore Power Inlet. Very nice and heavy duty! They can be found online for about $60 - $80.
Old 03-09-2010, 09:46 AM   #124
Ok...I now have the Inverter set into place. The first test was a success.
More of the install on the blog.
Old 03-10-2010, 09:54 PM   #125
Battery Combiner & Transfer Switch
Today I was able to get the battery combiner and transfer switch installed:
More details and pics on the blog.
Old 03-11-2010, 11:14 AM   #126
dennis's Avatar
Originally Posted by Bus Project
Thats the point that they were trying to make... You have your wires going through what appears to be a couple of rough holes. You should have some grommets to keep the wires from rubbing against the metal and causing a short.
Ok...I see what you are talking about. I made the holes big enough to fit Great Stuff Gap filler around them. This should provide sufficent protection for the wires. These are car audio cable and have a tuff outer skin on them.
Ummm.... ......NO.
Sorry, but I'm an aircraft mechanic. Foaming insulation won't do the job. When the bus moves, so will those cables. The rubbing action will wear thru the foam insulation almost immediately and start rubbing against the metal of the hole. The sharp metal edge of that hole will chew thru the "tuff outer skin" of the cable before you know anything is wrong and cause a massive short. Someone could even get hurt if all the amperage in those batteries shunts to the bus frame and someone is touching metal.
Go to a hardware store and get some appropriately sized gaskets. Using a couple of loop clamps (aka "adel clamps") to support those cables right next to the holes will help as well. Personally, I'd at least double the diameter of those holes as well - or just make it one big hole.
It's only a couple of bucks worth of hardware and a few minutes worth of work. Don't try to cut a corner here. It'll come back to bite you...
dennis is offline   Reply With Quote
Old 03-11-2010, 06:24 PM   #127
Chassis: C60
Engine: Chevy 7.4l 454 FI
Rated Cap: 59
I would agree with the above as well, expanda-foam aint gonna cut it. conduit is best, easily done and cheap. at the very minimum you need thick rubber grommets but I have seen those wear thru as well if your cables arent supported well on both sides. I am going to use pvc conduit for mine. I hate to see someone cut a corner and their hard work and money go up in a ball of flames on the road somewhere.
Not to mention that would be one more case why the insurance companies wont insure conversions. They never mention the success stories but a fireball on the highway will grab some headlines..........
ramairws601 is offline   Reply With Quote
Old 03-11-2010, 06:47 PM   #128
hahahahaha...yes a fire ball would not be good accept for those watching.
I will have these main feed wires fused so that should eliminate the fireball scenario. I do like the PVC idea and will probably go that rout. Thanks for the input.
Old 03-11-2010, 07:09 PM   #129
Coachwork: THOMAS
Chassis: SAFE-T-LINER
Engine: CAT 3116
Rated Cap: 83
BP, I was wondering what the purpose of the "combiner" is for. I'm using a lot of your idea's for my conversion because I really like the way you are doing it.
I was planning on just running a positive cable from the starting batteries to a battery cut off switch and from the switch to the house batteries. So when you are dry camping the switch would be off not allowing the starting batteries to drain.
Then when you are in transit, you can turn the switch on and the alternator will charge the starting batteries and house batteries. AND, when you are hooked to shore power you can also have the switch on and the inverter will charge the house and starting batteries.
Also, I pretty much have your electrical system figured out. But I was wondering what the transfer switch is for that you mounted? I know the inverter has a built in one.
Dan
BUSBOZO is offline   Reply With Quote
Old 03-12-2010, 01:05 AM   #130
I was thinking of a small piece of PVC that is just long enough to fit through the floor and put PVC Caps on both sides to prevent it from sliding. Drill a hole just big enough for the cable to fit through in the cap without letting bugs/moisture/air through. Maybe add some of those PVC Nuts to hold the pipe piece in place if you ever need to change the wire.
Good news for data starved bussters? mightybus Everything Else | General Skoolie Discussions 0 03-30-2012 05:49 PM
Some good school bus news! Diesel Dan School Bus News 1 12-18-2011 11:53 PM
RyanS's Bus Conversion Project RyanS Skoolie Conversion Projects 11 07-07-2010 08:00 PM
3rd bus, first conversion project Homeskooled Skoolie Conversion Projects 4 11-11-2009 08:43 PM
S-caper Conversion News Les Lampman Skoolie Conversion Projects 20 11-09-2004 09:30 AM
