08-28-2009, 11:50 PM
#61
Chassis: Amtran Genisis
Engine: International DT-466
Water Heater Done!
Well today I finished the install on the water heater.
Here is a pic:
More on the blog.
08-29-2009, 08:49 AM
#62
Chassis: C60
Engine: Chevy 7.4l 454 FI
Rated Cap: 59
Re: Good News Bus Conversion Project
Originally Posted by Smitty
If there was a "thumbs-up" smiley.....I'd use it
Smitty
you mean like this one?
http://www.myemoticons.com
Slick install on that heater!
08-29-2009, 12:52 PM
#63
Coachwork: international
Chassis: thomas
Engine: 7.3
Rated Cap: 22
Smitty
Cool tank and 'thumbs up' .
08-31-2009, 11:09 PM
#64
Kitchen Counter
Today I tiled the kitchen counter.
See the blog
09-04-2009, 09:58 PM
#65
The stove is in.
Yesterday I set the stove in place to see how she looks.
More pics on the blog
09-04-2009, 10:49 PM
#66
Coachwork: Thomas Transit Liner
Engine: CAT 3208 Turbo
Wow...just keeps getting better!!! Just fantastic.
09-12-2009, 10:37 PM
#67
Today I worked on the Plumbing!
09-14-2009, 11:05 PM
#68
Outdoor Shower Installed
The outdoor shower is now installed.
09-17-2009, 11:36 PM
#69
The fridge is installed!
09-21-2009, 12:32 AM
#70
Today I got the water tanks installed.
We now have running water powered by the 12 Volt pump!
09-21-2009, 08:04 AM
#71
Year: 96
Coachwork: Carpenter Crown
Chassis: Unknown
Engine: ISB Cummins
We're still working on our running water (I guess we've been to complacent with our 5 gallon buckets and watering can). Is that a Shurflo and a Shurflo Accumulator tank? Any filtering?
You're making great, fast and steady progress on your bus!
09-21-2009, 08:10 AM
#72
Year: 96
Chassis: Unknown
Engine: ISB Cummins
When I click on the link in your signature, http://www.goodnewsbus.com/ it redirects me to http://www.busconversionproject.blogspot.com/ which gets me in an endless cycle... FYI
How's that RV500 working, are you happy with it? I just ran my propane lines last week and will be installing ours this week. Any installation tips that weren't in the instruction sheet?
09-21-2009, 06:28 PM
#73
The link should be working now.
Let me know if it still does not. Make sure and refresh your page.
I am almost ready to test the RV-500.
09-21-2009, 06:30 PM
#74
It is a Flo-Jet pump and a Surflo accumulator. I have not installed a filter yet. I may just filter all the water that comes in.
09-22-2009, 08:26 PM
#75
What model Flojet is that? I tried looking for it on their site, but none of the pictures matched.
09-22-2009, 09:20 PM
#76
FloJet Pump Model 03526144. I do know that it pumps 2.9 GPM.
he triplex diaphragm series features models that deliver 2.9 gpm (11 lpm) flow and up to 50 psi (3.4 bar) of pressure. Pumps are self-priming and can safely run dry if necessary. Soft noise absorbing mounts reduce annoying background noise while running. Utilizes 1/2" (13mm) snap-in port fittings and the built-in pulsation eliminator reduces frequent pressure surges. Flojet offers a complete line of switch and VSD water pressure system pumps ranging from 1.1 to 6 gpm (4 to 23 lpm) models.
Volts
12 VDC
Amp Draw @ 10 psi (0.7 bar)
4.4
Flow Rate GPM (LPM)
2.9 (11)
Pressure Switch Max psi (bar)
50 (3.4)
Bypass
Yes
Weight Lb (Kg)
3.50 (1.59)
* Self-Priming
* Dry Running
* Soft Noise Absorbing Mounts
* Snap-in Port Fittings
* Built-in Bypass: Less Pulsation
* Reduces need for accumulator tank
* Corrosion Resistant Materials
* Meets ISO 8846 (Ignition Protection)
Warranty: 2-year limited manufacturer's warranty
Ebay has them for around $50
09-22-2009, 09:21 PM
#77
Today we installed the bunk trim and lights.
09-22-2009, 09:31 PM
#78
Year: 1982
Chassis: IH S1723
Engine: IH V345 Gas V8
That is one sharp looking bus, tip to tail!
Keep up the great work!
09-23-2009, 08:42 AM
#79
The whole bottom of the bunk is storage.
Here is a pic I took when I built it. I may end up putting some dividers in or something.
09-25-2009, 10:27 PM
#80
Part of the wood floor is down:
More pics on the blog.
