Originally Posted by Sojakai
I spend several hours looking around for it last night, and will probably spend several more today. Looks great in place. Model of the Hood, and or Manufacturer? Or, Online store you got it from? I want to add it to my list of "Collectables" pictures for my planning.
This hood is manufactured in Italy by Baraldi.
Here is the manufactures description:
Sophistication that is characterized by aerodynamics and elegant lines. When inserted into the cabinet, the discrete low profile versions reveal less than 2" of height while concealing Baraldi's fast and powerful Jet-flo ventilation technology.
Residential style, multi-layer aluminum filters that utilize the entire perimeter of the range hood are combined with a powerful motor and centrifugal fan wheel to more effectively extract heat, grease, and smoke from the cooking area. Centrifugal fans can generate higher pressure at lower sound levels when compared to axial fan blades commonly used in recreational vehicle vents.
Fast and Powerful Jet-flo Ventilation:
* 194 CFM completely exhausts an average 25' trailer in under 7 min
* 2,150 RPM creating 4.6 lb/sq ft.
* 20 watts 12VDC
Whisper Performance: 56db (normal voice conversation at 3-5ft = 60db)
Halogen Lights: Two at 10 watts (140 lumens each)
"Easy-Clean" large, residential-style, removable grease filter
