Originally Posted by milkmania
I know you only used it one season... But how'd the dual 13k a/c's work out for you? Wish you'd have gone bigger? Only used one mostly?
How'd you insulate?
I know you're in AZ, and I'm in OK...
Did you invite Derek & his girlfriend to Skoolie.net?
The 13k units worked just fine... for the climate that we found ourselves in over the last season. If you closed the bedroom door the single a/c unit in there would freeze you out. No reason to go bigger in our application.
We would use both espically during the peak heat of the day.
We were up in Northern AZ, so 5000 ft elevation, in the pondorosa pines. Very much cooler than the desert Phoenix/Tucson area. I'm not sure the a/c would keep up in Phx heat.
Derek and his girlfriend are familar with Skoolie.net. I'm sure they'll introduce themselvs when they see fit. Gotta ease into these kinda things.
