Old 07-02-2011, 04:40 PM   #41
syke's Avatar
Chassis: All American RE
Re: Great White Buffalo - 92 BB All American RE
Got a few things done this past week.
couch framed up.
Passenger seat base going in. Swivel, tilt, slide, everything except air ride. I might be redoing this design to incorporate air ride.
Ryan
Bluebird All American RE: Great White Buffalo (gone but not forgotten)
Our build thread: viewtopic.php?f=9&t=10065
syke is offline   Reply With Quote
Old 07-02-2011, 04:47 PM   #42
syke's Avatar
Added some backing
Ryan
Old 07-02-2011, 05:02 PM   #43
somewhereinusa's Avatar
Chassis: AARE
Engine: 3116 Cat 250hp
Rated Cap: Her, me and Molly
Really looking good
Old 07-02-2011, 06:42 PM   #44
Bus looks great! I really like the metal framework inside as opposed to wood. I don't feel like wood belongs in a vehicle like that, but obviously it's a little easier to work with for some people. I can't wait to see it all done. The exterior also looks very nice!
kshamrock12 is offline   Reply With Quote
Old 07-06-2011, 10:13 AM   #45
syke's Avatar
Thanks guys.
So far I am really happy with the progress and how the metal studs are working out. Getting the windows in was a big turning point for the wife and I.
The wife has been itching to get the window coverings started.
More pictures to come as I finish framing up the kitchen and desk/bunk area.
Ryan
Old 07-06-2011, 10:46 AM   #46
yankeflyer's Avatar
Chassis: Safe T Liner
Engine: 3208 turbo
I always wondered if the steel in the seats would have been enogh to do the framing. Anyway what a great job your doing. Definitly a how to - thanks for the pics.
yankeflyer is offline   Reply With Quote
Old 07-06-2011, 06:54 PM   #47
Originally Posted by syke
Thanks guys.
Do you know how much lighter the metal studs are compared to wood? Has anyone used the metal studs and had some time tested info? I am wondering about the flexing of the studs when they have the weight of the walls and other items while driving down the highway.
When (or if) I find the bus I am looking for I hope to be living full time within a few years of finishing the transformation...I have not figured out to financially do that yet, but that is the goal. Plan A is the lottery. I don't have a plan B.
I would be traveling to all the places I wanted to see in the US and Canada and would be doing quite a few miles. I know the "Sticks and staple" RV's do NOT hold up well. I had the use of a 30' Gulfstream on 3 trips across country and before I took the third trip, I had to rebuild the front over head bunk due to ROT! When I took it apart, it was so flimsy, I could not believe it did not just cave in (before the rot!) while driving at 70+mph in the western states. 1"x1" aluminum square tube as the frame, the width and height of the flat part of the RV with only the window as support in the center! STYROFOAM (yes, regular flaky Styrofoam) as insulation and pretty much nothing else. A solid RV is an illusion. There is nothing solid about them. The couch fell apart, with very little use. My 75Yo mom and Her husband had used it since 18,000 miles so it was not abused while they had it. Doors didn't close so well, things needed constant repair and just basically rattled it's way down the highway. The empty weight of the RV was already over the registered weight before anything was added!
I guess you all know this, which is why you went with a Skoolie!
So, I want to avoid the squeeky creeky syndrome. The shell of the SB is already sturdy but add a couple of thousand pounds of stuff to the inside walls and floor...will the metal studs still outlast wood?
100MPG is offline   Reply With Quote
Old 07-07-2011, 11:43 AM   #48
syke's Avatar
100mpg,
Let me start by saying.... I don't know!
I can almost guarantee the metal studs would be lighter than wood but by how much..... Not sure. To be honest the weight reduction was not a factor for me. (Although it's a welcome benefit) It was all about ease of installation.
Currently the studs do flex a whole bunch, but after the whole bus is sheeted I don't foresee any further movement.
It is crazy how the empty weight is right at gvw on a S&S rv. Our bus has about an 18,000 pound gap between the empty weight and registered weight. I like my 10 mpg so I really don't plan on using up all 18k pounds.
I plan to keep this build thread up to date so if anything changes for better or worse I will be sure to mention it.
Ryan
Old 07-07-2011, 02:15 PM   #49
100mpg,
I am sure they are lighter also...I had a carpenter friend that mentioned they were lighter and most commercial building were using it, at least 7-8 years ago. I dont even remember what he said the difference was.
Yeah, I am an MPG nut and drove on of those trips cross country at 52MPH, both ways just to get 7-9mpg...That was rough. Really, 52MPH for 11,000 miles. Not even 55. I would NOT do that again.
[/quote]
And I plan on reading it. Trying to get all the info I can even before I pick a bus out. I know it will cost me some MPG by wanting the longest bus I can find but it is worth it to me.
I am planning (or thinking since it is not on paper) on using the 8 to10' in front of the engine (RE of course) for a garage. I am thinking a door right in front of the engine compartment could be used to put in a lift of as yet undetermined style, to lift my very large motorcycle up and into the "Garage". Yep, it is going to be a challenge, but if I get it to work, it will be my rolling Castle. Oh boy, cannot wait for my first trip.
Old 07-07-2011, 03:24 PM   #50
GreyEagle's Avatar
100MPG
If you get a bus with the handicap Lift and big doors it might work for your garage ....... just thinking out loud
GreyEagle
Roll - On...
GreyEagle is offline   Reply With Quote
Great site great info sources frank-id Everything Else | General Skoolie Discussions 1 06-09-2014 10:26 PM
48 White Bus somewhereinusa Classifieds | Buy, Sell, Swap 1 04-14-2013 10:05 AM
Atomic Buffalo Turds.... timbuk Everything Else | General Skoolie Discussions 0 01-23-2011 07:08 PM
White stuff...... lornaschinske Everything Else | General Skoolie Discussions 5 12-20-2010 12:25 PM
Great White Buffalo For Sale Mark&Steph Classifieds | Buy, Sell, Swap 0 11-02-2005 09:11 AM
