Old 07-08-2011, 02:17 PM   #61
GreyEagle's Avatar
Re: Great White Buffalo - 92 BB All American RE
To keep the weight down why not use the thin 1/8 sheets over sterofoam on the inner walls?
just keep on thinking outloud
GreyEagle
Roll - On...
GreyEagle is offline   Reply With Quote
Old 07-08-2011, 04:07 PM   #62
syke's Avatar
Chassis: All American RE
Originally Posted by 100MPG
Originally Posted by syke
Yes 20 ga studs/track. I have not decided 100% on what/where/how in regards to the plywood but I'm thinking 1/4 will be the thinnest I will use and most likely 3/4 on the important structural items like the rear bed and the couch. For the bathroom walls and closet I might do 1/4 on both sides.
Do they make a diagonal or brace to put between the metal studs for strength? That would really stiffen them up and allow a thinner covering material for the inside walls. And I mean inner walls, not the inside of the outer wall. I would use something thicker for the sound deadening properties.
I really have not thought it out to much yet. Too many other things to think about and research.... remember I'm not a framer or carpenter; I'm just making half this **** up as I go.
Gotcha. I was a carpenter and mess around from time to time but given enough time, I could do anything.
[quote:1isiudk4]
FYI, the studs are not 2x4, I am using 2-1/4 x 1-1/2 for the framing and 1-5/8 x 1-1/2 for the wall cabinet framing which has not started yet.
I will be happy to have a bus to sit in and stare at the walls. I can start the planing in my head, it is easier for me to picture it and see how it fits together then looking at a piece of paper.[/quote:1isiudk4]
I'm not sure if they make something specifically for bracing but I do know that scrap studs make for great bracing. I will show a few pictures this weekend of that exact thing. Even though the framing is a little flimsy without sheeting, it sure becomes strong a hell once you brace it strategically.
The wife and I have spent countless hours sitting in the bus just brainstorming, plus we have laid out 3 different floor plans on the floor before settling on a final design. Which of course is never really final. I have an idea this bus will always have something, somewhere to tinker on.
Ryan
Bluebird All American RE: Great White Buffalo (gone but not forgotten)
Our build thread: viewtopic.php?f=9&t=10065
syke is offline   Reply With Quote
Old 07-08-2011, 06:04 PM   #63
willem's Avatar
Coachwork: Thomas MVP
Chassis: Thomas
Engine: Cummins8.3 Allison MD3060
Your project got me to thinking about steel framing... I'll be looking into it although I would like to find nominal 2X2's and corresponding track.
For skinning those walls, you might look into MDO, (medium density overlay,) which is a faced plywood which, when painted, does not "telegraph" the grain beneath the paint. It's used in signs, storefronts, and exhibits and can actually be found at Home Depot. I would use 1/2" and a local lumberyard may have it faced one side which may be less expensive than HD's faced two sides.
You'll need to figure out whether to trim out the edges where they're seen or a viable option is to use Bondo, (yes! Bondo,) on the edges to make a clean paintable surface.
Will
Vashon Autonomous Zone, Cascadia
http://www.the88.org
http://thesuper8.bandcamp.com/
willem is offline   Reply With Quote
Old 07-08-2011, 07:52 PM   #64
syke's Avatar
Thanks for the heads up. I will definitely look into. MDO, not to be confused with MDF.
I know from looking around at my framing, it is going to be a fun challenge to sheet the walls and make it look good. I figured I was going to have to trim it out but you mentioning bondo has me thinking....
Ryan
Old 07-17-2011, 01:30 PM   #65
syke's Avatar
Another update....
Ryan
Old 07-17-2011, 01:54 PM   #66
syke's Avatar
Changed up the desk/cabinet area a bit.
Pictures are getting a little bit busy. In all of those metal studs a second chest freezer, floor to ceiling cabinet, desk and more cabinets will emerge.
Mocking everything up so I can finish planning out the plumbing.
Drivers side middle and rear boxes.
Opposite side.
The mascot.
Ryan
Old 07-17-2011, 04:19 PM   #67
willem's Avatar
Chassis: Thomas
That is sooooo exciting! I'm having vicarious thrills, and I can see my future clearly. Thanks for the great update.
Will
Old 07-19-2011, 05:58 PM   #68
syke's Avatar
Glad you enjoyed it Will.
Have you had any luck finding 2x2 metal studs?
Ryan
Old 08-27-2011, 08:39 PM   #69
syke's Avatar
Just a few updates.
Still some more work needed on the rear cabinets
I've been side tracked for a few days with this:
Ryan
Old 08-28-2011, 10:18 AM   #70
Engine: 190hp 5.9 Cummins
I like the choice you made using steel studs rather than wood. It will weigh far less in the end.
Great pics.
Subscribed.
Great site great info sources frank-id Everything Else | General Skoolie Discussions 1 06-09-2014 10:26 PM
48 White Bus somewhereinusa Classifieds | Buy, Sell, Swap 1 04-14-2013 10:05 AM
Atomic Buffalo Turds.... timbuk Everything Else | General Skoolie Discussions 0 01-23-2011 07:08 PM
White stuff...... lornaschinske Everything Else | General Skoolie Discussions 5 12-20-2010 12:25 PM
Great White Buffalo For Sale Mark&Steph Classifieds | Buy, Sell, Swap 0 11-02-2005 09:11 AM
