Old 02-14-2018, 09:15 PM   #1
Green Caterpillar
Hi y’all this is my build. Welcome hope this is enjoyable.
1992 Thomas bus full size
The idea is to be able to sleep 4
Solar 1000 watts at 24 volts
Fridge
Stereo
Wood stove
Really want a catwalk shower out the drivers side emergency exit
No bathroom for pooping. That’s what an outhouse is for I don’t want dookie in my bus!
Sink
propane stovetop
Cork floor
Pine interior
Open floor plan
It’s gotta be really cozy and funky, have great attention to detail and have lots of unique usable simple things.
The bus will be my full time off grid living rig. I’m a single dad with 2 young teens and we can have some rad adventures!!
Here’s the photos I have so far:
3E58CEF9-05AF-4E46-8DA0-C6590A19203A.jpg   E3EDEFF7-FDBA-49B1-9EFA-00B0C4A5BEBF.jpg   92DD5BA8-12D1-416B-9960-BAF536EFEBAC.jpg   6A92F7FD-77B1-4B28-B732-05B36A40A046.jpg   ED1A544F-8BDB-40BC-9AD9-283C06A5A31B.jpg
308E96B5-CDAE-407F-AD5D-5EADEBB212F8.jpg   A3001239-7DE0-4BA9-8281-D6B28E0C1A16.jpg   E9AA6A8B-CDA9-4207-B57A-EEA53882EAA3.jpg
GreenCaterpillar is offline   Reply With Quote
Old 02-14-2018, 09:29 PM   #2
Chassis: Saf-T-Liner MVP ER
Did you just leave the inner walls in and bury them and the chair rail behind the foam board?
Steve Bracken
Build Thread
Old 02-14-2018, 09:32 PM   #3
At first I was planning on removing them, but after looking inside 1 wall I decided to keep it in tact. The idea is less work and more r value I hope. There was no mold inside overall not really any water damage anywhere. This model seems to be pretty water right by design.
Old 02-15-2018, 07:51 AM   #4
Chassis: MVP Saf-T-Liner
Engine: CAT 3126
Rated Cap: 78 Pax
Thumbs up Awesome Build!
Awesome build so far! And I love the color, may I ask what color that is? And where did you get it? Keep up the great work!
RuskiBruski is offline   Reply With Quote
Old 02-15-2018, 08:24 AM   #5
jjhwick119's Avatar
Engine: Dt466e
Rated Cap: 71
Is it Kelly green?
jjhwick119 is offline   Reply With Quote
Old 02-15-2018, 09:17 AM   #6
It’s rust oleum from Home Depot
1 gallon white
3 gallons hunter green
1 quart brown
Lots of acetone to thin
Shot with hplv gun in the yard
Get that masking tape off quick folks I learned a tough lesson about baked on goo!
Also a little white goes s long way!!!
Cheers
GC
Old 02-16-2018, 08:48 AM   #7
Engine: CAT 3126
Rated Cap: 78 Pax
Thank you for the info! Will definitely have to "borrow" that color for when I get my bus.
Old 02-16-2018, 11:20 AM   #8
Robin97396's Avatar
I thought I was pushing it when I put a gallon and a half on my bus last summer. I went monotone though.
1 gallon white
1 quart brown
Cheers
GC
Robin
Nobody's Business
Old 02-17-2018, 02:52 PM   #9
After adding 1:1 of green to white I was freaking out because it was so light. I ended up with a couple gallons left over for touch ups too. You really have to thin this paint out to get it to run through a gun well!
Old 02-17-2018, 04:10 PM   #10
Robin97396's Avatar
You got to thin that paint out just to roll it.
Robin
Nobody's Business
Old 02-18-2018, 08:27 PM   #11
Cork floor going into today, it’s laminate that’s pretty cheap hopefully it holds up
Old 02-25-2018, 02:45 PM   #12
Today’s progress
Today I learned some things. First I learned to chose a better flooring material next time. Cork laminate is sexy but not moisture resistant at all. It’s okay nothings perfect. Next I learned that wall studs should be closer than mine. 16 or 24 inches would be better. 1 x 4 or 1x3 could work well to save weight and money. Also, plan out where your electrical is going to be and don’t stab your wires with brad nails in your excitement folks
E84D4A50-B285-47E1-BB2F-CA013FEEA2DC.jpg   ECBEB634-DAF2-4965-9368-A97FCA8735B9.jpg   8CDF6506-4D11-4074-9E30-8432C1C83B8F.jpg
Old 02-25-2018, 04:08 PM   #13
Robin97396's Avatar
All good advice.
The choir.
Robin
Nobody's Business
