Old 12-12-2009, 11:03 AM   #51
John's Avatar
Year: 96
Coachwork: Carpenter Crown
Chassis: Unknown
Engine: ISB Cummins
Re: Gustav
Originally Posted by Smitty
Not sure I follow (blame it on the beer....damn timbuk ) are you meaning an alarm? Or if an alarm is as important for one burning wood as say an LP furnace?
Smitty
My last couple of posts was meant to argue that if you are only using a wood stove / burning wood, then you wouldn't have to buy a low oxygen alarm, that a smoke detector would be good enough.
John is offline   Reply With Quote
Old 12-12-2009, 11:10 AM   #52
John's Avatar
Year: 96
Chassis: Unknown
Engine: ISB Cummins
Re: Gustav
CO is more a product of incomplete combustion, and it has to have a pathway to escape from the appliance (draft-hood, plugged heat exchanger, etc). This was why I've mentioned an Oxygen Depletion alarm would be more valuable than a CO Detector. A woodstove would deplete the breathable oxygen in a bus long before it would dump CO into it.
There's no opening for a woodstove to release CO into the bus.
Smitty
Goes back to this statement. But now I see you were talking about Carbon Monoxide rather than Carbon Dioxide.
So if the wood stove is burning and taking oxygen from the room, that will either be replaced by a leaky window / engine dashboard or door with fresh air, or it will cause down-drafting putting some smoke in the room for a smoke detector to detect. So you can see if you are running low on oxygen by detecting smoke.
Old 06-11-2010, 09:23 PM   #53
John's Avatar
Year: 96
Chassis: Unknown
Engine: ISB Cummins
Re: Gustav
I'm getting ready to mount my water tanks. I bought them un-customized and now I'm supposed to add a fittings. I'd like to add a simple barb fitting for a hose and hose clamp. I don't have access to the inside of the tank to screw on something to the back of the fitting. Does anyone have any pointers to websites or even search terms for looking up how to do this? I imagine there'd be some kind of adhesive or plastic solder that I drill and plug and epoxy?
