Old 08-16-2010, 08:14 PM   #21
ceccles3's Avatar
Year: 1985
Engine: 366 Big Block with A/T
Re: Haulin' Toyz - '85 GMC Skoolie in NJ
It's been a long time since I've updated this post>>> The floor is covered with herculiner truck bed covering, floor plates/tie down points are recessed into subfloor to install/remove motorcycle wheel chocks, and interior walls are insulated/covered. Believe it or not, I can fit five dirt bikes and one quad - from the wheel wells to the rear doors!
ceccles3 is offline   Reply With Quote
Old 08-16-2010, 08:19 PM   #22
ceccles3's Avatar
Year: 1985
Saturday and Sunday were spent painting the exterior FINALLY. Time off and perfect weather - that doesn't happen very often... I still need to refinish the front/rear bumpers and wheels, and I'm not quite sure on the sides - I may want to add a bit more red. It's more gray than I thought!
Old 08-19-2010, 07:46 AM   #23
ceccles3's Avatar
Year: 1985
LuLu - thanks, that was my first outdoor paint job on something too big to fit under cover - no small task! As for the double doors, I first cut the new (smaller) door out, leaving the original jamb and latch side alone. For the hinge, I used angle iron on both sides to create a new jamb (bent to fit curvature of door), and to that tacked on a stainless steel piano hinge (added the screws later). The new door stays put with a barrel latch inside, and the original latch works as it did before. Today I am going to try to get the door locks done...
Old 08-19-2010, 07:51 AM   #24
ceccles3's Avatar
Year: 1985
Folks, give me your opinion - The more I look at it, the more I think it's too gray. This picture isn't great, but it gives you an idea of what I think I might do to fix that - what do you think? Appreciate the help...
Chad
Old 08-19-2010, 10:49 AM   #25
newtoskool's Avatar
I don't think theres to much grey. Maybe repaint the spot upfront grey is fading through. Get the family together and come up with a family symbol and put it up back there in back.
newtoskool is offline   Reply With Quote
Old 08-19-2010, 01:00 PM   #26
ceccles3's Avatar
Year: 1985
Just to clarify, the last picture on page 2 of the thread was an idea (done poorly on Microsoft Paint). The bus currently still has only a single uniform stripe down the sides. I was thinking about making the stripe wider up front, to curve into the thinner stripe.
Chad
Old 08-22-2010, 12:22 AM   #27
Engine: DTA360
Rated Cap: 16
I like the photochop look with more red...
dirtygoat is offline   Reply With Quote
Old 08-24-2010, 12:35 PM   #28
Diesel Dan's Avatar
Engine: DT466/AT545
Paint Idea...
How about this:
Sorry I didn't take the time to match the color very well...
Gallery:
Conversion Thread:
viewtopic.php?t=4959
Old 08-24-2010, 09:48 PM   #29
Cygnusaa's Avatar
im in nj as well...
mind if i ask how the process went from purchase, transport, title/reg and insurance?
looks good..i like the paint jobs layout...
...what...am I about to get myself into?
Cygnusaa is offline   Reply With Quote
Old 08-24-2010, 10:33 PM   #30
Engine: DTA360
Rated Cap: 16
I like the lines of the first one better...
Old 08-25-2010, 06:14 AM   #31
Cygnusaa's Avatar
yeah thats the one i was referring to. i dont think its too much gray...i will probably wind up with something similar except a light blue metallic instead of red and perhaps a slightly lighter shade of gray/silver...
the other layout isnt bad either...i think the scallop would look nice if it were re-oriented somehow
i really like the paint scheme on the santa fe trains...the silver and red with yellow accent....
i think i saw a bus painted like that on one of these forums...i really like that a lot.
Old 08-25-2010, 10:09 AM   #32
Coachwork: Chevy
Chassis: Bluebird
Rated Cap: 16
I also live in NJ & documented my Rutgers bus conversion. It's in my signature. Regarding your questions, I transported it with dealer plates and insured it as a motorhome. I told them on the title it said Chevy Bluebird Motorhome. It's a van body so perhaps I could've insured it as such. Then I went through all the requirements of making it a motorhome. Painting it, removing seats, stop sign and top warning lights. Building a bed, sink and installing a microwave (or stove). I took a picture of all that plus the vin number, got a certified weight slip from a truck weight station ,copied my drivers license and sent it to the Foreign Titles Dpt. in Trenton. I had to do that to change the bus title to motorhome. I sent it Friday so I'm hoping for a quick turn around.
Rutgers tailgating bus https://www.skoolie.net/forum/viewtopic.php?f=36&t=5545
RUskoolietailgater is offline   Reply With Quote
Old 08-25-2010, 05:05 PM   #33
Cygnusaa's Avatar
ah ok...
foreign titles sounds funny lol...only in nj would a bus from another state require you to go to "foreign titles"
i might run into a prob because i need it reg and insured while i work on it...the lot that is allowing me to do this requires it and i also want to be able to drive it to have certain work done on it...
pickle....
sorry for the highjack op..
Old 08-26-2010, 09:49 AM   #34
Coachwork: Chevy
Chassis: Bluebird
Rated Cap: 16
It's probably already registered as a bus. Just insure it as a motorhome. That's what I did as I worked on it.
New Skoolie Conversion and Old Skoolie Remodel jlhollowx13 Skoolie Conversion Projects 0 01-22-2013 01:41 PM
