Originally Posted by Zephod_beeblebrox2
Thus far I have been unable to find any hazard light noir even a mention of it in the manual
My bus is a Thomas, it did not have hazard lights as what would be on a car.
The tip lights were the only lights that would flash.
I removed my top lights but this was going to leave me with no 4 way flashers. I looked at the wiring diagram on the inside of the door where the fuses and all of the wiring is, I then disconnected the wires from the flasher control unit that operated the top red and yellow lights. I then found the wires that operated my turn signals and connect these to my controller for the top lights.
now I have 4 way flashers when I hit the switch for my top lights.
All/most?of the rewiring that would be necessary for your change of lights would be easily accomplished inside the access panel.
