Old 01-14-2017, 07:43 PM   #1
Chassis: Collins
Engine: 7.3 powerstroke
Hitch for a Ford E-350 Collins short bus
Hi all, Anyone know what kind of hitch we can get for the bus? As we found out, the frame is different from the regular econoline van. Would it need to be custom fabricated or is there a hitch for another vehicle that can work? By the way, ideally we would like to have a class five hitch. Any help would be greatly appreciated.
SweetSpot is offline   Reply With Quote
Old 01-14-2017, 08:20 PM   #2
I have a 99 E450 shuttle bus and I found a hitch that will fit. I did ask the seller which sold all kinds of hitches if it will fit, google is your friend.
Bluespoet is offline   Reply With Quote
Old 01-14-2017, 08:22 PM   #3
Chassis: Collins
What type of hitch did you get and what model was it originally built for? Or what is the maker and model of the hitch? Thanks!
Old 01-14-2017, 09:05 PM   #4
none of what I have will help you, do a google search, find someone who sells hitches and ask them about your bus, that is what I did and what I recommend for you. Getting a hitch installed properly is a safety issue and you need to get it right.
Old 01-14-2017, 09:50 PM   #5
Chassis: Collins
Ok, that's what we've been doing. We'll keep searching.
Old 01-17-2017, 07:00 PM   #6
Everything I've found so far has been weld on/multi fit. After measuring my frame (42" from the outide), I believe this would be a perfect/inexpensive fit for my bus (98 ford E450). Just thought I'd share since we were in a similar situation.
https://www.etrailer.com/Heavy-Duty-.../41990-16.html
disneysdarkside is offline   Reply With Quote
