Old 02-24-2015, 07:29 AM   #1
Chassis: I.H.
HolyBus transformation
Until now, I only had the first two pics to post. This morning, I ran out and took a few to show off the progress.
Yes, that is apple green:
Old 02-24-2015, 08:01 AM   #2
Chassis: I.H.
Yep, that is granny smith - apple green. We were sitting in the local "Tijuanna Flats" and my wife saw the ceiling color and said, "what about that color?" I let her make the decisions about the bus. Its our next home and anything can be changed so why not. We put a sample strip next to the curtain color and it is not bad. The curtains will be burgundy color. The floors will be wood grain single sheet vinyl unless we find something better. That way, it is easy clean up and area rugs will separate room areas.
Old 02-24-2015, 08:47 AM   #3
Cool its nice to have a picture to go with "holy bus".
You and the misses should take a nice pic smiling in the front of the bus!
Old 02-24-2015, 08:56 AM   #4
Chassis: I.H.
All the letters are gone from the outside. It was a church bus at one time. Hence the name.
Old 02-24-2015, 09:09 AM   #5
I figured that out from the pictures!
Old 02-25-2015, 07:04 PM   #6
That color is wild, me likey..
The whole ceiling might be a lot....only 1 way to tell
You can always repaint say kitchen or bath or???
That is what is great about a skoolie.....drive on
Old 02-26-2015, 06:42 AM   #7
Chassis: I.H.
Its been cool and misty here since the day I took the pics of the paint so I haven't finished. I want it to dry properly before a second coat.
Old 02-26-2015, 06:59 AM   #8
Yeah its been misty for a few days now.
Old 02-26-2015, 10:19 AM   #9
lornaschinske's Avatar
Rated Cap: 89
If the green is too much and you find that you can't live with it, you can sponge another colour on top of it (like yellow or white). Unlike what many indicate, you can sponge paint oil based paint. It's just a sticky mess and you REALLY need to wear gloves and long sleeved shirts to keep the stuff off your skin.
Fulltime since 2006
Old 02-26-2015, 01:34 PM   #10
I've been covered in Rustoleum Rusty Metal primer for weeks now!
Old 02-26-2015, 06:29 PM   #11
Coachwork: ward
Chassis: international
Engine: dt360a
dude, you want me to sponge ya with some green? roflmao
Old 02-26-2015, 07:15 PM   #12
Might make some nice contrast!
Old 02-26-2015, 07:41 PM   #13
schoolmarm's Avatar
Year: 1985
Coachwork: Wayne Chaperone
Chassis: chevy
Engine: 350
I am partial to pin stripping and flames!
schoolmarm is offline   Reply With Quote
Old 02-28-2015, 08:23 PM   #14
Chassis: I.H.
Dang rain has kept me from finishing the paint. Drat! Plan to sleep in it tonight and hopefully finish paint Monday if it dries up around here.
Old 03-01-2015, 07:35 AM   #15
Chassis: I.H.
After heavy rains last night, I found only one leak. What is that little round vent thing in the ceiling between the steps and the driver's seat? I found a small puddle on the floor under it this morning.
I also have dew to deal with. The ceiling is damp all over.
Old 03-01-2015, 07:45 AM   #16
I have a round "vent thing" right there too. doesn't seem to do much other than leak, so I'm planning on putting a 14" roof vent up there.
Why are these roof vents so damned expensive though?
Old 03-01-2015, 07:50 AM   #17
Chassis: I.H.
My son stood on the area just in front of the windshield and said there are two small holes on the roof in that area. Maybe antenna?
Old 03-01-2015, 07:59 AM   #18
Rated Cap: 89
... What is that little round vent thing in the ceiling between the steps and the driver's seat? I found a small puddle on the floor under it this morning... The ceiling is damp all over.
The round thingy is a passive vent. I ended up shooting a bit of Elastomeric sealant and placing a bit of flashing in the opening to seal the outside and placing a piece of sheet metal cut to fit behind the metal screen (which I cleaned and painted with spray paint as it looked bad). We found we were losing too much of our air conditioning out it (it's directly above the vent of the A/C unit).
As for your ceiling, we had that problem before the bus windows were pulled and rebuilt (only when it rained otherwise too dry in NM for condensation). Once we got things more finished (insulated and the exhaust vent on the range), the ceiling stopped condensating. Except in the bathroom when I take super hot showers. Cracking the window a tiny bit allows the moisture out without letting out all my lovely heat. Turning on the vent over the range hood sucks everything out in a matter of minutes (like about 5-10 minutes) I do need to install some solar powered fan-forced deck vents in the ceiling (on/off switched kind). Particularly in the bathroom hallway (for the shower moisture), the rear bedroom and the salon (to pull hot air off the ceiling in the summer so I don't have to run the A/C).
Fulltime since 2006
Old 03-01-2015, 02:28 PM   #19
Chassis: I.H.
Having fun today. We just bought a one piece fiberglass shower stall. 36x48 w/ hand rail and two seats. New slightly damaged from Home Depot. They have marked down their one piece stalls for clearance. This thing is solid and not very flexible at all.
I just have to measure twice and cut it for the curved ceiling.
What do you all do about the ceiling where the top of the walls meet it. I am sure it is not going to be a perfect seal. I also have to figure out the ceiling and how to coat it against the shower water, maybe Kilz paint?
Old 03-06-2015, 06:59 AM   #20
Chassis: I.H.
Update - Daughter in law came by and helped my wife with another coat of paint on the ceiling while my son and I worked on the shower stall. It was a tight fit. We got the curve cut. Standing it up meant cutting off the step-in trim. Pictures to follow.
