Old 07-27-2008, 09:34 PM   #21
Year: 1987
Coachwork: blue bird
Chassis: Conventional
Engine: Gas
Re: How to lock them doors!
does anyone know where to get one of these super strong magnets and if they are strong enough to keep someone from pushing hard on the door and it opening?
-Scott
"Sotally Tober"
http://i246.photobucket.com/albums/g...98502_5384.jpg
bigballsbus is offline   Reply With Quote
Old 08-05-2008, 11:19 AM   #22
Hex
Hex's Avatar
Coachwork: Bluebird, Model 3800
Rated Cap: 42
I'm not sure about an electromagnet, but for regular magnets, I've found Gaussboys to be cheap and fast delivery-wise.
If you have any questions as to how powerful these magnets can be, check out their 'crazy pics' page!
Hex is offline   Reply With Quote
Old 08-09-2008, 09:23 AM   #23
Awhile back someone posted a pic. of their electric back door lock, does anyone remember who that was or where the pictures may be found? The pic I am looking for is of a solenoid mounted inside the bus on the back wall.
Abbott is offline   Reply With Quote
Old 08-09-2008, 09:05 PM   #24
GoneCamping's Avatar
The problem with padlocks is, they ony work on the outside, so if you stop at a truck stop or Wallies for the night, you can't really lock the inside... unless you put another hasp on the inside. And then you've got the added problem of a fast exit in case of fire or other emergency. I just don't think padlocks are the best idea. The very first thing I did on my Bus was to remove the double swing doors and replace it with something else...
*Cliff*
...Your home has brake lights
1994 Jeep Grand Cherokee
Chesapeake, Virginia
GoneCamping is offline   Reply With Quote
Old 08-10-2008, 01:15 AM   #25
phillbus914's Avatar
Originally Posted by GoneCamping
The problem with padlocks is, they ony work on the outside, so if you stop at a truck stop or Wallies for the night, you can't really lock the inside... unless you put another hasp on the inside. And then you've got the added problem of a fast exit in case of fire or other emergency. I just don't think padlocks are the best idea...
Humm... Not with my paddle lock setup
Someone else mentioned the "how do i get out in a hurry" issue with a paddlelock a while ago, that's why I made the video.
My Old Bus :(
Old 08-11-2008, 01:23 PM   #26
Hex
Hex's Avatar
Rated Cap: 42
Well, the average 'house' door is 1 1/2 to 2" in thickness ...
If the bus door is -thinner- than this it could be an issue ... Unless you could just install the lock in the body and run the bolt into the door instead?
I'm still in negotiations for my bus, so I'm not sure how these measurements coincide with the bus reality ...
Old 08-11-2008, 02:19 PM   #27
Hex
Hex's Avatar
Rated Cap: 42
Yep! Well ... So long as you can fit the slide bolt and 'works' inside the door ...
Old 08-11-2008, 06:02 PM   #28
Originally Posted by ThatJustHappened
Philbus, I love the duel purpose locking system, I will definitely steel the inside usage of the lock, great stuff! My only question with the padlock is aren't you worried about someone just taking some lock cutters to it and gaining entry?
That thought crossed my mind, but if someone wants into a bus bad enough no lock will stop them... after all my bus has 48 side windows, 2 windshields, and 4 back windows that could be "access points" if someone wanted in bad enough. Like the saying goes "locks only keep honest people honest"
Originally Posted by Smitty
Couldn't a person remove the handle/latch assy. completely from the door & the jamb, patch the holes, then install a commercial quality (which are usually stainless) lockset like the one on the door to your house? Keyed entry outside, and lock release inside? Smitty
Great idea! I hate that big bar opener on the back door anyway.
My Old Bus :(
Old 08-11-2008, 09:40 PM   #29
Another fellow posted these pics of his back door lock a few months ago.
Old 08-11-2008, 09:54 PM   #30
Here's the pic I have been looking for of another guy's lock here.
Way to lock doors cosis Conversion General Discussions 6 09-13-2017 01:08 PM
this is how I lock my door on the bus lornaschinske Conversion General Discussions 5 12-26-2010 02:20 PM
door lock needed keith Classifieds | Buy, Sell, Swap 0 01-04-2009 11:23 AM
Rear door lock Kirbystud Conversion General Discussions 22 08-16-2005 03:47 AM
Door lock ideas Branden Conversion General Discussions 12 05-02-2005 06:47 PM
