That looks like the exact set up the I had. It was a lot easier than I thought it would be.
I took over the covers for the front heater (to the left of the Driver's seat) - the coolant lines from the engine come in from the front left. One line goes into your driver's heater - and comes out of there to the back of the bus... loops back and goes back to the engine. I shut the valves - used claps on the lines I was cutting - and just went from the coolant out line from the driver's heater back to the engine - and didn't need to buy anything - I did buy a new hose clamp.
I can't tell if these pictures help.
I am trying to up load the video I did - I hope that helps. I hope these upload - I am so bad at Youtube uploading stuff...
Anyway. This was me reasoning with myself... It can be done.
This was what I did - I would clamp the hose before cutting it - but otherwise, I really only lost a little coolant - just have a bucket or two handy.
Let me know if that works for you!
Originally Posted by Marvin
Do you have any more pics from the rear heater removal? More importantly the looping process you did and any parts you may have purchased? Can you essentially rip out the whole bottom section on the driver side? I was reading where some mentioned that there is a shut off switch in the engine section too. I have some pics of that, but don't want to start turning knobs in there.
I was going to keep it originally, but today I decided to take it out but it's just sitting there pulled away from the wall at this point (see video) until I find out what to do with the hoses and wires. I have the guy coming out tomorrow to take measurements of the floor for the diamond plating, so that's another reason why I wanted to get it out of there.
https://youtu.be/J4U4LociV7A
