Old 06-21-2016, 05:10 AM   #51
I forgot to post but will have pictures tomorrow, but back side emergency hatch has been removed and patched up. Roof has been made water proof with tape and roofing tar over the rivets and plenty of paint.
carneiro1292 is offline   Reply With Quote
Old 07-12-2016, 06:01 PM   #52
Ok, so I was at home Depot to by 2x4 for the ceiling studs, and it hit me, could I instead of installing 2x4 in order to have something to screw the ceiling into, just screw the oak plywood ceiling into the already installed ceiling ribs? I want to avoid woods as much as possible in case of a leak and the possibility of mold and crap in the future.
Theres the actual steel ribs, then there's are these screwed in not as heavy duty little sectional ribs the cut in between the actual ribs. There's enough of them spread out enough tht I would theoretically be able to have enough support for the ceiling I think. I've never seen anyone do it like this on this site which is why I ask. I'll let u pros decide. Thx
Old 07-17-2016, 01:04 PM   #53
Chassis: IC CE
Engine: T444
You can totally screw into the steel ribs. That is what i have seen done the most. Just remember to install the insulation first lol
Azuleslight is offline   Reply With Quote
Old 07-25-2016, 06:22 PM   #54
Should I just skip putting wood studs into the ceiling?
Old 08-02-2016, 06:59 PM   #55
Are you talking about putting up 4X8 sheets of oak paneling? What thickness?
How far apart is it between the centerline of two ceiling ribs? More than 16"?
The ribs look up to the task, if you use sufficient screws there shouldn't be a problem with the weight.
If the ribs are too far apart, there is a chance that eventually your ceiling panels might sag a bit.
The only reason I see for putting up 2x4 (or even 1x2) nailers would be if you were fussy about how straight and flat you wanted your ceiling.
I don't mix religion and skoolies
Insulation Fanatics Suck
Bye.
Tedd is offline   Reply With Quote
Old 08-02-2016, 07:04 PM   #56
After reading all the reports of metal fasteners sweating during cold weather, might he be looking at possible moisture damage to the oak paneling?
BusFiend is offline   Reply With Quote
Old 09-29-2016, 03:32 AM   #57
finaly some progress. Took two months off to deal with life and craziness but things have finally progressed. DOnt have pics but rear flood lights and back up camera. Also finally got the spray foam insulation completed which looks super sweet.
Old 09-29-2016, 03:54 AM   #58
Ok, now i have a few questions on sub floor. This is my sprayfoam insulated floor
I was going to just do a reg plywood subfloor with nice birch ply(i think it has less glue, which means less off gassing, i think
But then thought, hmmm.... what if i used soft wood boards instead? No glue, no chemicals, no dangerous off gassing, since even small amounts can be dangerous in such a small space. It way more expensive but worth it to me. Well i went to home depot with the bus and fitted half the bus with boards and realized it was gonna cost $375 to fit the whole floor with this stuff. . F*#k! Well then i went back to get more and came upon the aisle with foam boards and realized hmm what if i throw 1'' foam board insulation on top of the spray foam instead of ply or wood board, then just ad a floating finished floor over it, itll be a 60% saving. No wood means i dont need to coat it with any sealant which means less off gassing, i have a thing with off gassing u see. Less worry on mold and water damage, plus extra insulation, its a win win. heres the thing, if it were up to me id put the thinnest plywood i could over the spray foam and call it a day. I'm 5'11'', i dont have much head space left and adding yet another inch of subfloor, plus another inch for the finshed floor leaves me with one inch of head room. Not good. So i was wondering if i used 1/4 or 1/8(does tht exist?) plywood over 1 inch of spray foam insolation, then finished with 1 inch cork flooring, will that be enough to spread the weight around and avoid breaking down the insulation over time?
Here are my options. I dont think i will use 3/4 ply since it uses to much glue. Ill either use 1/4 ply or thinner, or foam board, pref the ply. SO my question is will the really thin ply hold or should i just go with foam boards instead
Old 12-27-2016, 07:18 PM   #59
update
ITS BEEN WAAAAAY TO LONG SINCE IVE UPDATED. Anyways, had a car accident(4 months now with no car) and money complications so work has seriously slowed down mostly due to the fact the trip to the bus consists of 2 ubers rides, and 2 trains, a lovely total of almost 4.5 hours. ALso the inability to just run to lowes or homedepot and constantly relying on the good gracious of my hosts(who are amazing btw) to help with rides def slows down progress.
But anyways i managed to put in a quick but pretty efficient super thin and cheap plywood subfloor just keep from digging into the spray foam.
The under window walls are up(found leaks, thx to all the rain) but hopefully ive fixed the issue.
the ceiling pannels are all in
We will finished them with a dark coffee collored trim going inbetween on the joints
Old 12-27-2016, 07:38 PM   #60
Update #2
ALSO i huge milestone is the rear bed. Its done. It crazy when i look back and remeber how i use to draw the bed and drawers on scrap paper at work a year ago, and how after so much dreaming, and and all the plans i have in my head, it ended up turning out exactly as i had imagined, hell it came out better.
How did i do it? hell if i know, i have ZERO experience with this stuff, ive never really built anything but someone how it worked. Putting the drawer slides were rough, the whole thing i was told was WAY over engineered but whatever, i works and function how i want it to, and better yet, i built it myself. If i had to do it again, i would be F%$Ked cause it was all trial and errors; and loads of errors... loads of errors.
So this is the front face, with our dinning room table pulled out. We didnt want to ad a table, or a fold \up table attached to walls only cause we really do have very little space, again its only a 25' bus, so wedecided a long time ago this is how we would do it, and somehow it worked.
Still need to cleans and add the finishing touches on the interiors
Obviously it still needs to be stained and sanded, but well save tht for later.
The drawers only take up half the space under the bed, which gave us a lot of room for extra storage, accessible from the rear emergency door, and the rear side emergecy door on the passenger side. We call this is our garage which will hold all of our camp/hiking gear, skis/ skateboards, etc, all the things we need but dont necessarily use every day
This is from the rear side emergency door, here you can see all the space we have
with the back door in view. the side door will be usefull for things like skis, or anything long tht wouldt fit in the back door.
This is the rear door
