Old 07-04-2017, 09:36 PM   #1
It has begun
Well, the project, has started. It's a bit daunting seeing how much there is still to come, but it's licensed, and insured, and all but one of the seats are removed. I did a sketchup drawing of my planned layout, and taped it out to see how it flows, and am pretty happy, although I'm sure there will be changes. One question if you happen to have any ideas, I have a light on my panel that flashes constantly, and don't have a clue why.
Sent from my SM-G950U using Tapatalk
dispatier is offline   Reply With Quote
Old 07-04-2017, 09:38 PM   #2
oricha1984's Avatar
Engine: gasser probably
That shorty looks good. What year is it ?
Sent from my Life One X using Tapatalk
oricha1984 is offline   Reply With Quote
Old 07-04-2017, 09:39 PM   #3
It's a 1992
Old 07-04-2017, 09:42 PM   #4
Rated Cap: 65 pax
It's adorable! Looking forward to your build!
WanderWoman is offline   Reply With Quote
Old 07-04-2017, 10:42 PM   #5
bus looks like its in awesome shape!!!
love the old style chevy vans!!
Old 07-07-2017, 07:52 AM   #6
tobeamiss's Avatar
For a 92 it looks great!
Welcome!!
oh yes she did!
https://www.skoolie.net/forums/f11/to...-it-16557.html
Old 07-07-2017, 09:29 AM   #7
The red light is for one of a couple of things.
First it might be a pilot light for your crossover lights. If the master switch is activated your crossover lights will turn on every time the service door is opened.
Second, it might be a warning light that one of the emergency exits is open. If it is it usually is paired with a buzzer but not every time.
If it isn't one of those two things I will have to ponder what it might be indicating.
It appears as if you have found a pretty nice bus.
Good luck and happy trails!
Old 07-07-2017, 09:40 AM   #8
Thanks! I'll definitely follow up on those ideas, might be an emergency exit that has a bad switch, hadn't thought of that.. now back to pulling up rubber flooring haha
Old 07-07-2017, 03:17 PM   #9
So I have begun pulling up the floor, and it seems that I don't have any metal, just plywood on the frame. It's pretty soft, so I'm going to replace it and spray seal the bottom again the way it was originally, but I was wondering about the rest of the floor. 3/4 ply on the bottom, 1" foam, then flooring sound like enough insulation?
Old 07-07-2017, 05:53 PM   #10
Old 07-12-2017, 03:32 AM   #11
tobeamiss's Avatar
I was looking at foamboard yesterday at HD and I've decided to go with 1"which has an R value of 5...if I go any thicker I'm afraid I'll lose valuable height. Another option I'm contemplating is to spray foam under the bus....just covering all the areas I can get to.
oh yes she did!
Old 07-16-2017, 08:04 PM   #12
Been working alot recently so just got to start tearing out side panels. All the rivets along the top and sides of the wall panels drill out in seconds but the ones on the bottom seem like they're made of adamantly. Any neat tricks I don't know? The ones that suck are not hollow and the pin will not punch out.
Old 07-17-2017, 04:54 PM   #13
tobeamiss's Avatar
I had to use the angle grinder and make an 'X' in the center and tap it out with a cold chisel and hammer. I also found those along the bottom really tough!
Good luck.
oh yes she did!
Old 07-17-2017, 05:05 PM   #14
most will use their 8 inch grinder to grind the face off...
