Old 12-13-2004, 07:19 PM   #81
lapeer20m's Avatar
yes...at this time i plan to attend Burningman 05......but we'll have to see what happens between now and then.
Old 12-13-2004, 08:06 PM   #82
glock17's Avatar
Send a message via MSN to glock17
windshield wipers on the inside, i love that.
glock17 is offline   Reply With Quote
Old 01-03-2005, 10:44 PM   #83
lapeer20m's Avatar
Winter is my off season as far as skoolie usage. I (we, I have a roomate now,and he's almost as crazy as me) decided that now is a great time for the bus to undergo a complete reconstruction. I've made up my mind that I don't need a new bus, and 57mph top speed isn't so bad. I felt much differently immediately after i spent a month crusing the country....but at this time I just dont' think it's worth the time effort money and hassel to make the bus go faster, or find a different bus. I've had a serious problem with mixing diesel fuel into my crankase thus diluting the engine oil. ONe good thing is that it doens't add diesel fuel much faster than i already loose oil, so it doesn't get overfull. I've tracked the problem to my injector pump. Next week I take the bus into the shop for a new (nearly free) injector pump. Hopefully that goes well.
Today we pulled out all of the couches, furniture, stereo,.....pretty much everything, including the original stock rubber floor. Water had gotten between the rubber and the marine grade plywood from the jacuzzi project. We removed all of the rubber flooring....this was less than fun! I let the original plywood floor dry for most of a day with the furnace and other fans running. She dried out nicely. Then i put some osb overtop so the flooring guy will havea good surface to work with.
It took 2 guys a total of about 16 hours of hard work to get to this point!
Inside is still the jacuzzi If all goes as planned, the new floor will be installed this Saturday. The new floor is really cool. It's made of two materials. Part 1 is chopped up rubber that feels much like soft pencil erasers. Part 2 is a glue. The two are mixed together and applied with a trowell. The flooring guy approached me some time ago and wanted to do the bus for free....so i'm finally taking him up on his offer. I"m not sure what color it's going to be yet, i can't recall if we had a conversation about that or not.
Old 01-03-2005, 10:58 PM   #84
lapeer20m's Avatar
depending on how long it takes to get the injector pump replaced, we hope to have the bus back together in a month or less.
You can ask steve, skoolie admin, Nearly everything on the bus was only done half right to begin with. One of my biggest faults when i built the bus was my electrical wireing. I"m not the kind of guy to do really maticulous finish work....i really just like to make things work, then i seem to move on to the next adventure leaving wires in a rather disorderly fashion. After the Floor, and the IP, the next thing i want to do is Re-wire all the stuff that i did in the bus. I bought lots of wire, connectors, and a junction box today.
Next step is the cieling. The paint is peeling, especially over the jacuzzi. Perhaps i should have scuffed the original paint and applied some primer before i painted the cieleing the first time. There are lots of rivets! Sanding isn't going to be much fun. I think a wire wheel in the angle grinder is the ticket! With two of us grinding away (pun intended) we should be able to do the entire cieling in one day. Then i want to prep the surface properly, paint it black with florecent orange flames. Then cover the entire ceiling in shiny chain link fence.
Then there's the wall between the jacuzzi and the living quarters. I've always needed some steps, and the original wall was errected in about an hour with mateials that i happened to have on hand. The new idea is to build a wall and steps out of glass block 8"x8"x3".
It'll cost about 200 bucks....but since nearly everything else in the bus was free or cheap, I think it's ok. Then i can have colored lights shine through the glass block...it should give a pretty cool effect.
I"ll keep ya posted....and i'll try to upload some photo's of the process.
I love a good adventure!
Old 01-06-2005, 11:54 PM   #85
Sounds like a lot of work but a lot of fun at the same time. It sounds like you will have a really awsome rig when you are done. Can't wait to see the pictures.
busone is offline   Reply With Quote
Old 01-11-2005, 03:37 PM   #86
lapeer20m's Avatar
Nothing seems to move at my speed. The floor and the injector pump projects are on hold...I guess beggars can't be choosers. it's ok though, thre's lots of other sub-projects to work on
yeserday we scraped the paint off the cieling.....That was less than fun! It took about 5 or 6 hours for two of us working pretty much nonstop with an angle grinder/wire wheel and an electric sander. After we were about half done, i tried some "aircraft remover" paint stripper. Then i let it dry for a couple hours. That made it much much easier to remove the old paint with the wire wheel.
This trumps removing the seats as the most miserable part of the bus project so far. Hopefully tomorrow i'll get all the taping completed, and start the priming/painting process.
once the ceiling is complete, i plan to install the glass block wall
Then hopefully i can get the floor finished, and the new injector pump put on before spring. Spring really is just around the corner. Once spring gets here, i'll use the bus non-stop untill october. Not much time for major projects once the rush is on.
Old 01-13-2005, 09:14 PM   #87
lapeer20m's Avatar
Today we finished scraping paint....then spent the next couple hours getting everything primed. (after i spent a couple hours installing our new used 220 volt 5hp air compressor) I applied one coat of black, then I ran out of material to spray! UGGGGGG. It would have been so easy to pick up an extra gallon while i was at the store. I work 24 hours tomorrow, so the rest of the painting process will have to wait until saturday.
The gloss black looks really good inside the bus. I can't wait to get it finished.
Old 01-30-2005, 08:27 AM   #88
lapeer20m's Avatar
Got her all painted inside. It looks sharp. I'll post pic's soon.
Got the glass block wall installed....mostly. I built it in two sections in the house, then carried it out to the bus. That was far easier said than done! Glass block is heavy and awkward !
One thing i noticed after i got the wall in the bus is how unlevel the jacuzzi is. One side of the hot tub sits much lower than the other. I'll put a 2x4 under one side of the jacuzzi in an attempt to level it out.
I plan to use diamond plate alluminum for the steps on the way into the bus, and the steps built into the glass block wall leading to the jacuzzi.
The newest idea is to use mirrors on the walls of the bus...............I'll have to check into prices for and the availablity of mirrors that are made from safety glass or something similair. The approx dimensions will be about 2 feet x 16 feet. This might prove to be cost prohibitive.....but it sure would look nice.
I'm also considering a waterfall in the rear of the bus. Not a real waterfall, but one of those that is actually a piece of glass with water flowing over it. It's not necessary, but seems like a fun cheap simple idea that will add an awsome effect. I'll light the waterWall the same color as the glass block wall.
She's coming together quite well. I'm a little over on the time frame however. I had originally planned to finish by the end of january. It's hard to get motivated some mornings during the winter!
Old 01-30-2005, 10:38 AM   #89
rather than glass mioor check into the plasic stuff..we used it at a carnavel ride place and its tough stuff... outside of a plastic shopI wouldn't know where to look..glass shops "MIGHT" be able to come up with it.
*edit..found you a link http://www.americanacrylics.com/mirror.htm
Demonknight is offline   Reply With Quote
Old 01-31-2005, 08:14 PM   #90
lapeer20m's Avatar
Thanks for the link! Glass mirror here at my local glass shop is 2.50 per square foot.
the plastic mirror from that link is only 2.00 per square foot.....plus shipping. I think i'm going to go this route. I'm basically going to cover the windows on the inside with mirror. The wall below the windows isn't visible due to the seating arrangement. The first 16 feet on both sides of th bus (from the very front up to the jacuzzi) will have mirrored walls. Should give a cool effect, and make lighting more efficient.
Thanks again for the link.
Jacuzzi Bus V lapeer20m Skoolie Conversion Projects 153 09-19-2012 09:21 AM
I put a Jacuzzi in my bus! bus-bro Skoolie Conversion Projects 6 12-14-2011 11:24 AM
Jacuzzi Bus VI lapeer20m Skoolie Conversion Projects 4 09-29-2011 06:16 PM
Jacuzzi Bus III lapeer20m Skoolie Conversion Projects 43 12-05-2008 07:31 PM
another jacuzzi bus??? lapeer20m Skoolie Conversion Projects 3 06-27-2007 04:11 AM
