Old 09-08-2013, 05:17 PM   #11
roach711's Avatar
Rated Cap: 19
Re: Jacuzzi bus - a tribute
Photobucket seems to be the favorite, but any image hosting site will do. Here are instructions for linking to photobucket photos.
viewtopic.php?f=8&t=55593
The Roach Motel
Old 09-08-2013, 07:26 PM   #12
Turns out I just needed to resize them after I pulled them off the camera.
We finally got it back home!
Heres me cutting through the bolts in the floor. Now I just need to unload 18 or so seats on craigslist haha
Finally got all the seats out.
Heres the heater. We plan on taking it out and using the plate heat exchanger idea Lapeer had to heat the tub
whitey is offline   Reply With Quote
Old 09-09-2013, 05:51 AM   #13
that is something I would do
Old 09-09-2013, 12:05 PM   #14
The motorcycle helmets works great for a combination of eye protection and hearing protection!
Curiosity got the best of me when I removing the rubber linings around the inside edges of the bus. I wanted to just pull a little corner of the flooring up to have a look at the plywood. That turned into tearing up the entire linoleum type floor. Some of the plywood sheets are pretty wet. I was hoping to get straight into applying the wood laminate I bought, but we may have to pull up the wood, treat the metal floor, and put new wood first.
Oh well, can't win em all.
Old 09-09-2013, 02:01 PM   #15
JakeC's Avatar
I think that would be wise. If the floor is already wet, and your whole premise for the bus involves pumping hundreds of gallons into the bus at a time, you need to take good care of your floor. And I love the helmet. "Can't find safety glasses? No problem!"
Brutus
Old 09-09-2013, 04:28 PM   #16
Well we did a bit further inspection of the plywood sheets. They are not as bad as I thought they were with the exception of about two square feet behind the right rear wheel hub. We got heaters on it now hoping to dry it out in a couple days. If it looks like it will be good once it is nice and dry, we will throw a coat of sealant down and then install the flooring.
In the mean time we are going to look at a hot tub in about half an hour. Tomorrow will be an interior paint day. We already did a test spray and am going to pick up some more paint and a new spray gun on our way back from the hot tub place.
Here the final pic of the day.
Old 09-09-2013, 07:02 PM   #17
We got the Hot Tub! No clue if it works, well find out tomorrow. Been working on it all day and its time for beer and bonfires.
Old 09-09-2013, 08:53 PM   #18
Year: 87
Chassis: International s1700
Engine: 6.9 internatiional
good luck, i cant wait to see the results
proconsul100 is offline   Reply With Quote
Old 09-09-2013, 10:30 PM   #19
syke's Avatar
Chassis: All American RE
Sweet another jacuzzi bus. Awesome! Looking forward to more pictures.
Ryan
Bluebird All American RE: Great White Buffalo (gone but not forgotten)
Our build thread: viewtopic.php?f=9&t=10065
syke is offline   Reply With Quote
Old 09-10-2013, 05:09 AM   #20
Jacuzzi Bus V lapeer20m Skoolie Conversion Projects 153 09-19-2012 09:21 AM
I put a Jacuzzi in my bus! bus-bro Skoolie Conversion Projects 6 12-14-2011 11:24 AM
Jacuzzi Bus VI lapeer20m Skoolie Conversion Projects 4 09-29-2011 06:16 PM
A Tribute to Craigslist timbuk Everything Else | General Skoolie Discussions 1 09-15-2009 09:45 AM
jacuzzi Bus V?? lapeer20m Classifieds | Buy, Sell, Swap 2 01-29-2008 07:13 PM
