Old 03-24-2009, 08:08 PM   #21
lapeer20m's Avatar
Re: Jacuzzi Bus V
Worked less than 8 hours on the bus but we made good progress today.
Removed the remaining seats
removed the 14,283 screws to allow the removal of a couple of interior ceiling panels (ok, not really that many screws, but a lot!)
started grinding off rivets on the exterior
and ended up removing a section of the roof.
and we also mounted some speakers, 12 inch perhaps?, in the front of the bus. My camera ate those photos.
I work another 24 hours tomorrow(wed). Hopefully we can get the jacuzzi in and plumbed on thursday and get started building the seating. I have four days in a row off starting saturday which should allow me to accomplish quite a bit.
i'm tired! goodnite
Old 03-26-2009, 08:28 AM   #22
Re: Jacuzzi Bus V
gotta luv the pictures, a certified EMT using a skillsaw with abrasive blade for a grinder,
sure hope that nyou had the "don't hurt me" safty meeting befor you started :P :P
Old 03-26-2009, 07:58 PM   #23
lapeer20m's Avatar
Re: Jacuzzi Bus V
Safety 3rd! And that's Mr. Paramedic to you lol
actually, a skill saw with abrasive blade seems quite safe compared to a grinder, and it has more power. The actual story is that i couldn't find my grinder.
had a productive day today, i'll let the photos tell most of the story.
also did some window tinting, and got the roof mostly put back together
once she is painted i don't think anyone will ever notice that we disassembled then reassembled the roof
Old 03-27-2009, 09:17 AM   #24
Re: Jacuzzi Bus V
mister paramedic; junior emt to me, lol
you just stole that bus out of my backyard, I'm at sibley between 75 and telegraph.
just remember the magic number is 911
seriously, it's looking good
Old 03-28-2009, 04:31 PM   #25
lapeer20m's Avatar
Re: Jacuzzi Bus V
I totally finished the roof today. Rivets are all in, and everything is sealed with very expensive uv resistant paintable silicone.
This is the 4th time i've removed a rear heater from a bus. here's my little tutorial on how to do it and not loose much coolant at all.
First, i shut off the valves, i don't know if this really helps when it comes to loosing fluid, but it makes me feel warm and fuzzy inside:
I don't think the unit was making much hot air, look at all the dirt stuck to the filter
I start by removing several feet of the tunnel that houses the coolant lines
then i move the heater and put it up higher than the engine/radiator. This is a really important step when it comes to minimizing coolant loss!
I simply cut off the hose with a razor knife, and put hose clamps on using a nut driver. i'm a big fan of a nut driver for hose clamps verses using a screw driver
This is the majority of the liquid that i lost...just a few cc's
and here's the nearly finish product. The plate heat exchanger/jacuzzi heater. The jacuzzi water flows through the unused ports
once the system is up to operating temperature, i like to go back and re-tighten the hose clamps.
Old 03-28-2009, 06:28 PM   #26
the_experience03's Avatar
Re: Jacuzzi Bus V
You can't beat these things if you have a lot of cooling system work to do. I also have some cheesy orange plastic Craftsman ones I got off eBay for like $2 per pair because the packaging had a typo on it. Having a bunch of pinch offs is especially handy on GM LSx V-8's anytime you need to do a t-stat, water pump, etc because of the way the housing is set up. I can usually do a waterpump on one of those trucks and need under a gallon of coolant to top them back off when I'm done.
Speaking of coolant...anyone noticed how grossly expensive it's getting?
Old 03-28-2009, 06:36 PM   #27
Year: 92
Re: Jacuzzi Bus V
I haven't looked at coolant prices in a long time but our distributor warned us last summer that there were some rule changes coming that were going to drive up prices drastically, I don't remember exactly what it was all about, but I know his company was looking for glycol alternatives to try and work around some new restrictions
bbbrt76 is offline   Reply With Quote
Old 03-28-2009, 09:31 PM   #28
Re: Jacuzzi Bus V
where ae you getting the plate heat exchangers, and is the cost reasonable?
Old 03-28-2009, 11:30 PM   #29
lapeer20m's Avatar
Re: Jacuzzi Bus V
ebay. i forget how much i paid for that one, but I think it was under 100 bucks. They are not cheap, but i have found no better alternative for that application. I bought this particular one a while back when i was working on a different project and ended up not using it.
Old 03-29-2009, 09:49 PM   #30
lapeer20m's Avatar
Re: Jacuzzi Bus V
one thing i am doing different on this project is trying to stay organized. Sometimes i feel that i spend more time searching for tools than i do working. I put my toolbox inside the bus so that i don't have to go far or spend much time looking when i need a tool. I also have a pile of power tools in the bus, a sawzall, pair of circular saws, a pair of jig saws, flashlights, electrical and plumbing tools etc. So far my organization seems to be paying off. I also keep a list of any tools/parts/supplies i think we may need so i can minimize trips to town. And i've been on top of the budget. So far we're about 20 percent UNDER budget. I'd like to keep i that way!
Now i just hope the toolbox fits out the front door when we're finished
I put a Jacuzzi in my bus! bus-bro Skoolie Conversion Projects 6 12-14-2011 11:24 AM
Jacuzzi Bus VI lapeer20m Skoolie Conversion Projects 4 09-29-2011 06:16 PM
Jacuzzi Bus III lapeer20m Skoolie Conversion Projects 43 12-05-2008 07:31 PM
another jacuzzi bus??? lapeer20m Skoolie Conversion Projects 3 06-27-2007 04:11 AM
Jacuzzi Bus Steve Skoolie Conversion Projects 201 07-27-2005 12:07 PM
