Old 04-15-2014, 10:48 AM   #11
Re: Jeremy's conversion project
Nice work! I like how you did the wall insulation and have been considering a similar method myself!
Follow our conversion:
Two Birds - 1992 Bluebird TC2000
WVO Powered!
viewtopic.php?f=9&t=467346
www.LiveLoveTravelDream.com
White99z is offline   Reply With Quote
Old 04-15-2014, 11:02 AM   #12
juliol's Avatar
Engine: 3208 turbo Cat
Thank you for the pics, you got a jewel, my playwood floor is in good shape, so I willd do the same as you are doing, and again, thank you for taking the time to post your work in detail it helps., BTW, did you remove the side panels or just cover them with insulation board?
J
juliol is offline   Reply With Quote
Old 04-15-2014, 11:20 AM   #13
Diesel Dan's Avatar
Engine: DT466/AT545
I like the wood framing around the windows! So what are you going to use as your final flooring?
Gallery:
Conversion Thread:
viewtopic.php?t=4959
Old 04-15-2014, 11:40 AM   #14
Chassis: Crown
Rated Cap: 54
J
The insulation was super easy. I didn't remove the side panels. I measured how much the lip the seats mounted to protruded from the side walls and then ripped some cedar to the same width. Screwed that at the floor and flush with the window lip. I had about 1 1/4" of space to work with. My HD only had 1/2" and 3/4" rigid foam insulation. Sandwiched together it was perfect. I made sure not to undercut them so they'd fit tight. Each set of 4'x8' was perfect to do 16' of wall. For the wheel wells I measured to the edge then matched up the sheet on the inside of the wheel well to draw the radius to cut. I put vertical cedar supports at 8' centers (or anywhere else a seam would be) to attach the paneling. I was going to go with 1/4" oak paneling but decided to go with luan since it is more moisture resistant, cheaper, and most of it will be covered. Besides, you can actually find some pretty nice grain if you are selective.
swaflyer is offline   Reply With Quote
Old 04-15-2014, 12:37 PM   #15
Chassis: Crown
Rated Cap: 54
Final flooring is vinyl composition tile (VCT) same as used in schools and retailers. It's available in any color you can imagine (special order) from HD for $.79/sq ft. We finally decided on "Kickin Kiwi."
Old 04-15-2014, 11:41 PM   #16
Chassis: Crown
Rated Cap: 54
Started to lay things out to make sure the floor plan is going to work. It looked like it was going to be fine when I taped it out but I wanted to double check. The bed will actually be on the other side so the build out will cover the fuel filler cover. I already removed it and cut it down quite a bit before reinstalling it.
Old 04-19-2014, 03:41 AM   #17
Chassis: Crown
Rated Cap: 54
Decided on this rolling work bench (without the wheels) for the kitchen cabinets. Might do 2-4 more matching cabinets from this same series for other areas of the bus. There are a bunch of different cabinets some of which are available at Sam's Club (where I bought this).
Installed a sink and faucet from IKEA and a cooktop from Amazon.
Old 04-19-2014, 03:51 AM   #18
Chassis: Crown
Rated Cap: 54
I had been looking for a stove that wasn't too big for quite a while. This one is about 32" tall and 16 inches at the widest point. Bought it eBay but it was "pickup only." It was in L.A. and I live outside Tampa. Seller agreed to drop it off to my hotel while I was in Burbank on a business trip. I took it back to Tampa with me on the plane. It weighs about 100lbs. It went smoother than I would have thought.
Old 04-19-2014, 09:02 AM   #19
browncrown's Avatar
Rated Cap: 79 at Birth
Love the workbench counter! You're making great progress and the bus is looking good
BC
Old 04-19-2014, 11:11 AM   #20
Killer Cabinets!!! --- And a great looking little heater/stove. It's all coming together really nicely, keep the pix coming.
The Camel Conversion Project PDBreske Skoolie Conversion Projects 564 01-11-2018 10:02 AM
Good News Bus Conversion Project Bus Project Skoolie Conversion Projects 271 11-18-2017 10:55 AM
1991 Thomas RE Conversion project tfdfyrman Classifieds | Buy, Sell, Swap 3 10-03-2010 07:04 PM
RyanS's Bus Conversion Project RyanS Skoolie Conversion Projects 11 07-07-2010 08:00 PM
3rd bus, first conversion project Homeskooled Skoolie Conversion Projects 4 11-11-2009 08:43 PM
