04-05-2012, 02:51 PM
Year: 90
Chassis: Alister
Engine: Cummings
Joel and Brittney
04-05-2012, 02:58 PM
Year: 90
Chassis: Alister
Engine: Cummings
Re: Joel and Brittney
Got all the seats out. Got the materials to move the heater from the back to the front where it would benefit us most while travelling down the road.
Anyone have any suggestions on what to fill the holes with in the floor?
I plan on using some foam insulation with some plywood on top of it for flooring.
04-05-2012, 04:58 PM
Coachwork: - Still Shopping -
Chassis: - Going Medium/Large -
Engine: - DT466 Desired -
Congrats and Neat Bus .. enjoy .. that's just about exactly the size/design I am looking for .. looking forward to watching your build-up and conversion ..
Chance favors the prepared mind. - L Pasteur
Luck is the residue of good planning. - B. Rickey
Travel is fatal to prejudice, bigotry, and narrow-mindedness ... - M. Twain
04-05-2012, 05:21 PM
Chassis: All American RE
Wow! Great platform. Looking forward to more pictures.
Did I see a little grease in the background of one of those pictures?
Ryan
Bluebird All American RE: Great White Buffalo (gone but not forgotten)
Our build thread: viewtopic.php?f=9&t=10065
04-05-2012, 05:24 PM
Rated Cap: 89
Originally Posted by j12784
... Anyone have any suggestions on what to fill the holes with in the floor?...
How I patched the holes in the floor that were left behind by the various bolts and screws. First I used a small hole saw and cut thru the rubber flooring. The pilot bit made the screw holes nice and clean. A dot of clear elastometric roof seal (Henry's brand from Home Depot) was plopped over the hole. A thin piece of metal flashing was cut with a pair of kitchen shears and pressed into the wet elastometric caulk. The clear seems to be less messy than the black. I used both kinds because I had a partial tube of the black. And it was the last tube of the black I bought.
04-05-2012, 07:49 PM
Engine: 3208 na boat anchor
A blob of caulking?
04-05-2012, 11:05 PM
Weld'em.
04-05-2012, 11:10 PM
Year: 90
Chassis: Alister
Engine: Cummings
I think a few blobs of caulk will do nicely since i'm covering the floor with some water resistant foam.
04-05-2012, 11:11 PM
Year: 90
Chassis: Alister
Engine: Cummings
Originally Posted by Tango
Weld'em.
oh. how exactly would I go about welding them?
04-05-2012, 11:27 PM
Weld'em.
If you got to ask, you don't want to do it. First, you have to buy a wire feed welder, then learn to use it on sheet metal. I could forsee the holes getting larger, not smaller.
04-06-2012, 08:58 AM
Bus-Bro is correct --- if you have access to a little wire fed mig welder, that's the way to go. But they are very easy to learn, use and dial in for sheet metal. I must have filled in over a hundred various sized holes in my floor with one. Sealants and goo are gonna go away over time and the larger the hole, the more likely all the work you put on top of it will be exposed to water & road grime from below. To my mind, now is the time to do it right and forget it for another 65 years (that's how old my floor is).
04-06-2012, 09:31 AM
or screw metal plate over after calk
04-06-2012, 10:21 AM
Year: 94
Coachwork: b/b
Chassis: tc2000
Engine: 5.9
oh brittney that eng u have is 3208,,,not a 3802 and that the best eng that cat makes,,, sorry about my input,,,,lol
