Old 07-02-2012, 11:37 AM   #41
Re: El Tortuga
Everything will be simple and functional...that's about it
We now have a place to eat out of the weather
so far I have about 15 hrs into the project,
which includes:
6 hrs to pull out the first part of seats (in back) and paint back bedroom windows black,remove wire covers and all the other crap screwed to the walls
5 hrs to remove rest of the seats and build and install dinette
4 hrs to clear coat table and build one bed base
I just don't have time right now and we want to enjoy the road/places we go
Everything being installed right now on top of the old floor can be removed in an hr or two and be re-used this winter when we rip out the floor and windows
Even the bed room walls will have about 10 screws(1/4-20) to be unscrewed and they will come right out.
If we feel like it everything can be moved as we get a feel for it.
Basically we live outside so the cooking/dining etc will be used to get out of the weather(like a normal RV...you don't cook inside unless there is a good reason to )
Lisa wants a comfortable bed,a bathroom that doesnt require going outside and a fridge for cold wine and food....everything else is gravy
Old 07-02-2012, 12:00 PM   #42
GreyEagle's Avatar
Re: El Tortuga
Sounds like a simple plan, makes life simple and sweet......
GreyEagle
Roll - On...
GreyEagle is offline   Reply With Quote
Old 07-03-2012, 10:21 AM   #43
Accordion's Avatar
Year: 1973
Engine: CAT 1160 V-8 Diesel
Re: El Tortuga
That is a nice looking table.
Old 07-03-2012, 11:26 AM   #44
sdwarf36's Avatar
Coachwork: Champion
Chassis: Ford e-450
Engine: 7.3 Powerstroke
Re: El Tortuga
Do NOT get crazy about adding up all the hours you have /will have in the bus-you'll find out how little your time is worth.
Old 07-03-2012, 11:52 AM   #45
Re: El Tortuga
...that's way true....just was thinking I've had it almost 2months and haven't had time to spare.....I have 4 days off starting 2morrow and if I'm lucky I will have maybe 10 hrs to spare .
There are times I wish we were not good parents/kids and providers
Old 07-04-2012, 07:50 PM   #46
Re: El Tortuga
I have used same online name since the internet began
You can see this thread under other vehicles on the planet....welcome aboard
Old 07-09-2012, 06:32 AM   #47
Re: El Tortuga
Got alittle work done,bedroom is coming along.
The beds and walls and everything is attatched to a header board down side of bus,this is so everything can be easily removed this winter when we do the floors,a few small angle brackets keep everything squarish
back to front
a quick wall to contain the cold AC in the bedroom area
front to back
and storage for things we don't need all the time and for driving to campspots(water,grill toilet etc...so they don't roll around)
under bed storage
So far the modular design has worked,I moved the bedroom wall and beds forward 14" to accomidate the kayak storage(removed about 25 screws moved stuff and re-screwed them
Old 07-13-2012, 03:18 PM   #48
Re: El Tortuga
so I have been working on El Tortuga today
decided to get kayak mounts installed over the beds in the "master suite"
I made 4 mounts at work
I installed them into the roof bows...why I made 4 when I needed 8 for the straps I don't know
So I went to local hardware store and grabbed 4 threaded rings.
I drilled .391 holes
and installed 4 riv-nuts
and installed rings
Here are how the straps will work (1 kayak on each side)
Once it stops raining I will put kayaks up so I can install a padded rail on the ceiling.
Here they are in the "stowed" position w/o kayaks
I stopped at lowes last night on the way home to get some reflective bubble wrap and peel and seal.
I wandered by the return/damaged area to see if they had anything to use in the bus(they hadn't yet)...score!!
a set of custom length bi-fold doors,returned never used
they are cheap house quality but will work great for a temp door to bedroom and 2 hanging closet doors.
I unfolded one set and they where 3-1/2 in to narrow...no worries I cut a PC of 1x4 and using 1x4's on the back made a one PC door,and reused the folding hinges to make a normal opening door
That is my $8 door...couldn't buy the wood for that price
It fits our natural 1x4 theme perfect ...some paint and poly and it'll be done...oh and a door stop,and latch and handle of some sort
Maiden trip is next month for an ECORS race at The Devils Playground....lots to do before then
Old 07-13-2012, 09:33 PM   #49
Re: El Tortuga
My lunch at Mickey D's cost me more than that--that's just wrong? The doors are a great find and look like they belong.
Old 07-13-2012, 11:33 PM   #50
bus-bro's Avatar
Engine: 3208 na boat anchor
Re: El Tortuga
Yea to riv-nuts! Thanks.
Old 07-16-2012, 02:56 PM   #51
Re: El Tortuga
well we decided to introduce Veronica to the turtle saturday night.
So we set the stage for some quality family time
First time she has been outside since Nov 2nd when she showed up at the doorstep of her human servants
She was really freaking out with all the new smells.
She absolutely loved the big flat dash,
she found a bug and chased it back and forth for 10 minutes until she got distracted
I pulled the dash apart looking for an intermitant short with the low air buzzer and a few of the gages.
I found a broken pin that was caused when someone took the pin out to "add" another wire to it.
What to do on Saturday evening with nearest store to far away?
I ended up tinning the wire end and slip it inside of the remainder of the pin( it still had the tangs attached,worked great and clicked right back into place!
Old 07-16-2012, 03:12 PM   #52
Re: El Tortuga
I also found several of the wire terminal studs had worked loose and were touching,so straighted them up and retightened.
I assembled dash back together and now only gage that is flakey is still the fuel gage...no worries most of our vehicles have messed up gas gages
Old 07-16-2012, 03:14 PM   #53
GreyEagle's Avatar
Re: El Tortuga
So????????? What do you do in your spare time?????
GreyEagle
Roll - On...
Old 07-16-2012, 08:33 PM   #54
Re: El Tortuga
I've also had fuel guage wows over the years. Specifically, how does your guage "act"? Jack
Old 08-01-2012, 08:13 PM   #55
browncrown's Avatar
Rated Cap: 79 at Birth
Re: El Tortuga
Bansil, the bedroom doors look great...very nice!
BC
My Conversion Thread: https://www.skoolie.net/forum/viewtopic.php?f=9&t=3065
Old 08-06-2012, 05:54 AM   #56
Re: El Tortuga
Browncow...Thank you
latest updates,so little time.
not much has been done...I did get the mirror mounted,recycled not bought
doesn't stick out much
insulated back upper wall and mounted fishing pole rack
Test fit the Kayak's..nice and snug!
plenty of room above bunks
started on armour (s/p) it holds plastic bins with clothes and shoes etc.
Old 08-06-2012, 08:11 PM   #57
sdwarf36's Avatar
Coachwork: Champion
Chassis: Ford e-450
Re: El Tortuga
If I could critique you set up (from a fellow kayaker) unless you plan ahead on cleaning your 'yaks, you going to have big drippy -sandy things right above your bunks.
Old 08-06-2012, 08:30 PM   #58
browncrown's Avatar
Re: El Tortuga
Never thought of using the inside mirror like that...excellent recycle
BC
Old 08-07-2012, 04:08 AM   #59
Re: El Tortuga
Good catch!the plan is an "outdoor shower" hookup,for a quick spray down.an old towel to dry off residue...hopefully it'll work out
Old 08-18-2012, 05:06 PM   #60
Re: El Tortuga
so...as the sun sets we have an update....the nostrils are clogged due to shiat that is illegal in cali..
say what!!!!!AHAHAHAH
so I decided the most important thing to do now....was to make it a pain in the arse for NC to pull me over next month....so i applied a more none school bus look...or started
Mr. Miegeeeeeeee don't have shiat on me...(insert : cool ninja sounds )
after countless wax on wax-off with cleaners and scotche brite....I gave up and said "......"
so: El Tortuga...is almost not ...ugh...yellow
so after grinding,sanding and removal of alien snot......I scuffed and sprayed the rails and big rivets
then sprayed and let sit while sipping wine ohhh!! and then I masterleeeee! applied the (add cool french word here)
the base coat...with a genuine foam roller
so ....mmmm....she is not yellow as a whole....2 morrow...arrrrrr...need wine...
The Voyages of La Tortuga bansil On the Road | Travel, Trips, Camp Sites, Tailgates 8 09-21-2013 10:12 AM
Screw This Town!!!!! (Updated AGAIN) lapeer20m On the Road | Travel, Trips, Camp Sites, Tailgates 10 12-24-2009 04:18 PM
Space Saving A/V Entertainment Idea (UPDATED) slov Conversion General Discussions 9 02-05-2009 02:31 PM
Smoke 'em if you've got 'em!!! (Bus Burnouts) (UPDATED) phillbus914 Everything Else | General Skoolie Discussions 1 09-18-2008 01:47 PM
Updated pictures in the Gallery Bidin Time Skoolie Conversion Projects 2 06-08-2006 08:04 PM
