so while I was under bus looking at exhaust I saw this
yup that is 1/2 plate bent
and looky at the top mounts,cracked and broken and flopping in the wind
soaked with pb blaster...wasn't coming loose
so I started to cut it off
shock off
buggered,cracked and the thru shaft welded with bubble gum...more cutting to do
this had been welded
any ways atleast 3 times
hole in frame is wallered out but it is still nice and flat!
So I will make new mounts and replace shocks this weekend
now why did it shear off the mounts you ask???
distance between the centers of the mounts was 17 inches
space between bump stops and frame is 2-3/4 inch plus about an inch of compression...so that means the lower mount can move up about 3-3/4 inches
so 17.00 - 3.75 = 13.25 compressed shock length(close enuf)
now when I compressed shock that was mounted guess what??????
16.75 inches
so back to last wanderings of a mental state.....what kind of idiot mechanic does this crap??? not once but 3 times atleast....now I now the "clunking" I have heard and the bone jarring ride might have had a reason behind it...not to mention State Troopers who inspected the bus for safety,since it was a school bus...
argh!!!!!!!!!!
So at lunch I started to widdle on some steel...
oh and the shocks I got are 13.25 compressed and 21.25 extended with the 3/4dia bushings so I will have up and down travel now
