Old 06-05-2013, 05:42 AM   #341
Re: La Tortuga...update 05-26-13 (front ac install)
It was a step up from our metal tent
hopefully get time to get bus bled and primed this weekend, and I cant wait to be parked beside the river
Old 06-06-2013, 10:11 AM   #342
Just a small update
First inspection plate off, oops they only missed hole location by 5 inches
So I found the sending unit, I will pull and clean and check resistance for possible gage replacement
next inspection plate(looking for an electric in tank pump)
mmmmmm they forgot to saw all the way through???
ugh nope, they glued it back in.....the hole to nowhere
So I just need some time off from work...
Old 06-07-2013, 10:19 PM   #343
Shadoll's Avatar
Year: 1979
Engine: 8 cyl gas
Rated Cap: 60
*lol* I have that same shirt.
Linda Kay
trans·mog·ri·fy Verb: Transform, esp. in a surprising or magical manner.
Shadoll is offline   Reply With Quote
Old 06-08-2013, 02:38 PM   #344
JakeC's Avatar
Running yet?!
Brutus
Old 06-09-2013, 02:40 PM   #345
Originally Posted by JakeC
Running yet?!
SO she LIVES
what a journey, it's been to get re-primed and running with this simple 5.9
This is long and I hope it will help someone else in the future
lets back up 2 weeks to when this started
We got home, and after letting oil/turbo etc cool; I turned switch off and it ran on for about 5 seconds, I thought it was weird, oh'well she shutoff and I could always just move lever on intake
I then proceeded to change out the fuel filter, I had no luck getting it primed, even after filling the filter and pushing the stupid little primer pump....so I quit and grabbed a beer this is where the story left off
worked all week,etc...
So friday after work Lisa and I grabbed a glass of wine and went to the bus to prime and get her started
I still had the lines cracked open, so I pumped the primer pump and hit the key...CLICK.....nothing..I said I left the key on I guess and need to charge the battery
I checked voltage and I had good voltage, headlights and horn worked so I thought
1)not enough amps
2) or starter/solinoid is bad
So I grabbed a srewdriver,had her turn key on(click main solinoid) and proceed to bypass solinojd on starter.she spun right up......mmm...plenty of battery
So I grabbed my meter and put it on the solinoid lug coming from the key, Lisa turned key "click" no 12V at lug...but it's clicking.WTF??????
Lisa said it's not clicking at the starter is it?
I grabbed the starter solinoid and had her hit the key "click" but didn't feel it...so we got to looking
tucked away was another soliniod......and the main feed was broken (the last pc of green copper wire just broke, maybe 2 strands left,
So I cut wire and crimped on another ends and attatched it
Guess what? The starter now engaged via dash key....woop,woop
So I preceeded to pump while she would crank.....even had a dodge tech on the phone(friend)
The battery was about dead now and still no fuel out of the lines...argh....bed time now after hooking up battery charger
So I had Lisa bring home a fuel pump and I was bound and determined to get her running today, only issue was no real way to get to the lines to splice into them.
I noticed an "extra" line coming from the tank and hanging below the "crash cage"...I rolled out and went to filler neck...woop...woop...a non vented cap!!! so that was a vent line
So I now was able to pressurize the tank!
okay I am in business, turned pump on and it went to about 10 lbs or so....jumped under bus, and filled pre filter....next was filter at engine, and I had fuel coming out of the top bleed hole on filter going to pump..in business
I cranked over, 15 more seconds,repeat no fuel from lines on injectors....I said I am not getting fuel shut off must not be working??I could hear the solinoid and "feel" it clicking
Problem was
It was clicking but not pulling the lever up to allow fuel into pump
I could turn the key one, shutoff would click, and you could push lever up and it would hold....
fuel shutoff solinoid,round thing with wire out of top
So I researched and found some diagrams and instructions,when cranking it gets voltage to "pull" the lever up,while running it is in "hold" mode,when key turns off it releases and a spring pushes lever down and engine stops
So the "pull" function during cranking wasn't working
So I tracked wires from the "secondary" solinoid that goes through a nother fuse to the "pull" side of the shut off...............see...........
so I replaced the fuse.
pumped primer 50 times and turned the air compressor back on.....walla I had fuel at lines in a bout 15 seconds
I tightened lines and she puffed alittle smoke but not enough speed to start
So I moved my truck in closer...it was tight
I let it charge for 15 min and VROOM.....the beast spit forth fire and brimestone......
Sorry so long
Old 06-09-2013, 08:28 PM   #346
roach711's Avatar
Rated Cap: 19
Re: La Tortuga...update 06-09-13 she starts!!!!!!
Nice write up! I always wondered how the older diesels were shut down without an ignition system.
The Roach Motel
Old 06-10-2013, 11:55 AM   #347
JakeC's Avatar
Wow, what am ordeal!! I like my mechanical valve I have to pull to shut off fuel
Brutus
Old 06-10-2013, 02:03 PM   #348
I was afraid it had the small shutoff that the 1ton and below trucks had, thank goodness it didn't, I will probably change it to cable in the future...always like it with 2-1/2 trucks
.I will say this, I am glad I got to learn about this in my backyard and not on the road
Old 06-10-2013, 08:12 PM   #349
JakeC's Avatar
No kidding! That would have been a completely different experience on the side of the road.
Brutus
Old 06-11-2013, 10:36 AM   #350
browncrown's Avatar
Rated Cap: 79 at Birth
Thanks for all the good information and really glad La Tortuga is up and running again
BC
My Conversion Thread: https://www.skoolie.net/forum/viewtopic.php?f=9&t=3065
Old 06-11-2013, 11:38 AM   #351
Me too,I gotsta see a man at the river
Old 06-11-2013, 04:31 PM   #352
rjz5400's Avatar
Chassis: Thomas? Safe-t-liner
Engine: 6bta5.9
I did get to pull my FSS on the side of the road, bus full of friends on our way to a rally 6 hours away.
I had just driven it long enough to get to full operating temperature. It was in june, in NC so yea that was fun. It is really tucked in there too, if you have to remove the solenoid to take out the plunger as I did.
Glad yours was a power supply issue and not a rubber tip failure or a sticking plunger like mine!!!
rjz5400 is offline   Reply With Quote
Old 06-11-2013, 06:39 PM   #353
No doubt,if you notice what you have is what I was worried about...(inline FSS that sends rubber into the pump...not good).....mine has a solenoid that moves the mechanic fuel shutoff "lever"
To get rid of what you have you would replace it with what I have or just a pull cable.
If mine malfunctions,all I have to do is pull wire connector apart and pull the lever down to kill the fuel to pump
Old 06-12-2013, 12:41 PM   #354
rjz5400's Avatar
Engine: 6bta5.9
Gotcha, I do also have that mechanical shutdown lever on the Bosh VE pump. It is manual currently.
WHen i pulled that plunger out I never put it back, I just always walk around back and push the lever with a rod. I should instal a cable i geuss.
I like going back there though. I see any developing leaks, loose belt, and I forces me to give it a "cool down" and usually i just leave it running on short stops off the highway. this lets the turbo bearings especially cool off and stay lubed for the next time I start it.
If you go performance or have other trouble shooting issues I use
http://www.dieseltruckresource.com/
great WIKI and plenty to search through
OK Carry on.
Old 06-12-2013, 02:51 PM   #355
OK Carry on.
Sweet...saved
Old 06-16-2013, 06:16 AM   #356
somewhereinusa's Avatar
Chassis: AARE
Engine: 3116 Cat 250hp
Originally Posted by Malkieri
So I know this is a silly question..... BUT I'm going to ask anyway. Does anyone else think "Mutant Ninja Turtle city" when you see Bansil's location??
Ok so maybe its just me .... gotcha.... going back to put on my helmet and rock in the corner.
Sorry, can't say that I do. My kids were already grown when that craze came along.
Old 06-16-2013, 11:36 AM   #357
Not us....is it good or bad.........
When you can get away by giving your loved one a set of in the package TMNT's!!
For either b-day,anniv or christmas?
Old 06-16-2013, 11:51 AM   #358
see
or a limited edition yugio? card(I think )
or how about hand made jewelry? I picked up a fossilized turtle shell, some brass wire wa..la...
gotta love a wife that you can wooo and wow with nature ......oh and there is food and wine involved also
Old 06-16-2013, 12:18 PM   #359
travelinwithus's Avatar
travelinwithus is offline   Reply With Quote
Old 06-17-2013, 11:20 PM   #360
Shadoll's Avatar
Year: 1979
Engine: 8 cyl gas
Rated Cap: 60
OK.. now I'm wondering how I can incorporate my extensive penguin collection into the blue bus... ice? Whole change of interior design.
Linda Kay
The Voyages of La Tortuga bansil On the Road | Travel, Trips, Camp Sites, Tailgates 8 09-21-2013 10:12 AM
Screw This Town!!!!! (Updated AGAIN) lapeer20m On the Road | Travel, Trips, Camp Sites, Tailgates 10 12-24-2009 04:18 PM
Space Saving A/V Entertainment Idea (UPDATED) slov Conversion General Discussions 9 02-05-2009 02:31 PM
Smoke 'em if you've got 'em!!! (Bus Burnouts) (UPDATED) phillbus914 Everything Else | General Skoolie Discussions 1 09-18-2008 01:47 PM
Updated pictures in the Gallery Bidin Time Skoolie Conversion Projects 2 06-08-2006 08:04 PM
