Old 05-25-2013, 09:40 PM   #311
Diesel Dan's Avatar
Engine: DT466/AT545
Re: La Tortuga...update 05-25-13
I love the way you installed that AC! Very creative, outside the box thinking. Also, the exterior light is really cool looking.
Gallery:
Conversion Thread:
viewtopic.php?t=4959
Old 05-26-2013, 10:16 AM   #312
browncrown's Avatar
Rated Cap: 79 at Birth
Bansil, excellent install on the air system!!!
BC
Old 05-26-2013, 10:51 AM   #313
syke's Avatar
Chassis: All American RE
Very nice AC install. Bus is looking great
Ryan
Bluebird All American RE: Great White Buffalo (gone but not forgotten)
Our build thread: viewtopic.php?f=9&t=10065
syke is offline   Reply With Quote
Old 05-26-2013, 11:45 AM   #314
Thanks all
Been out in bus this morning~
well it's supposed to rain so i modified the light covers this morning
marked
cut out with 4-1/2 grinder with .04 cut off wheel
remounted
The 3" tubes are about 9-1/2 sq in, and my cut outs are almost 8 sq in and with the 2+ in behind the lens air flow should be fine
And it still looks stock in an old skool bus kinda way
hopefully get roof vent and drip pan done next weekend
Old 05-26-2013, 05:27 PM   #315
lornaschinske's Avatar
Rated Cap: 89
Re: La Tortuga...update 05-26-13 (front ac install)
It's 100F. We have a small 5K BTU 115vAC "window" air conditioner built into the food cart doing NOTHING. I think we will be installing it into the rear bulkhead of the bedroom over the emergency door. I don't know why they call them "window" air conditioners. We've owned several and they were NEVER mounted in a window. Two were mounted into the sidewall cabinetry of the pop-up (at different times)! For under $200 we can buy an 8K BTU (Sam's Club's GE is $10 cheaper than Wal-Mart's same GE) and stick it over the windshield in the front of the bus. Tomorrow it's supposed to have a high of 99F. but it's supposed to cool down starting on Wednesday... high of 91F down to 86F on Monday. Tuesday is supposed to be 97F with a 20% chance of precipitation. What that means is scattered "not quite rain showers" where most of the rain evaporates in the dry "convection oven" heat before it ever hits the ground.
I'm living in a place where they have "mud storms" (light rain mixed in with a dust storm) and it "almost" rains.
I think I will go take a shower and evaporate.
Fulltime since 2006
Old 05-26-2013, 07:23 PM   #316
I went with 5k units for power draw,I can run both units,fridge a box fan for circulation and still use my saw's and grinder....all on a 20 amp breaker (house) the "perfect" storm of all 3 compressors kicking on when I fire up the grinder could trip it...
Old 05-26-2013, 10:19 PM   #317
Engine: 466DT
I just tried to read most of your thread. I think the last time I looked, it was only a few pages. That took awhile I really like how it has come along. I had been thinking about doing the same kind of thing with my front door. Now I know for sure, I will put it on my list of things to do. Nice work. Also, I really like how you did the front AC. I keep looking at the pictures and I can't figure out where you are draining it though? Any pictures of that? Keep up the nice work.
Hvbuzz is offline   Reply With Quote
Old 05-27-2013, 03:58 AM   #318
Nope not yet,I am going to add a drip pan under it behind the 2x4 shelf....we'll see,one step at a time
Old 05-27-2013, 09:19 AM   #319
Hey Bansil --- Depending on where you are, the "drip" thing can be minor or major. Here in coastal Texas, the mini-split unit that cools my office can easily put out over 10 gallons of "drip" a day where a comparable unit in a climate like New Mexico might produce only a couple of ounces. I built a large permanent drip pan under the 8K in my bus along with a half-inch drain line just to handle Southern humidity. And it is a good idea to make any drain lines easily accessible for cleaning since they are very prone to bumper crops of algae inside that can quickly plug them up. A healthy blast of compressed air will usually do the trick. Ahhh...life in the Tropics.
Old 05-27-2013, 11:08 AM   #320
Rated Cap: 89
The AC unit we have has a good sized drip hole in the built in drip pan. We will simply add a tube to it the same as we have for every other "window" AC unit we have built in. We've never had a problem with algae build up. And we were running the AC units in high humidity areas (90% and up). It's amazing how much water a little AC unit will put out.
Fulltime since 2006
The Voyages of La Tortuga bansil On the Road | Travel, Trips, Camp Sites, Tailgates 8 09-21-2013 10:12 AM
Screw This Town!!!!! (Updated AGAIN) lapeer20m On the Road | Travel, Trips, Camp Sites, Tailgates 10 12-24-2009 04:18 PM
Space Saving A/V Entertainment Idea (UPDATED) slov Conversion General Discussions 9 02-05-2009 02:31 PM
Smoke 'em if you've got 'em!!! (Bus Burnouts) (UPDATED) phillbus914 Everything Else | General Skoolie Discussions 1 09-18-2008 01:47 PM
Updated pictures in the Gallery Bidin Time Skoolie Conversion Projects 2 06-08-2006 08:04 PM
