Old 06-15-2012, 04:55 PM   #31
Re: El Tortuga
started the day by pulling out the battery and noticing I have work to do to the tray.
I cleaned residue off the battery,checked water level and hooked it up to charge.
Spent the better part of a half hour cleaning and reaming/cutting the clamps they were nasty and not making good contact
the moisture you see wasn't water/acid it was some sticky crap sprayed on to stop corrosion and just like all that stuff the outside that was sprayed was fine,everything under it was corroded
I needed to make room for 2 cots and stuff
for a trip in 2 weeks
pulled off seat covers,foam
then made sparks
unbolted from the side rails
and throw out back door
so we now have a place to sleep and strap down a fridge
I needed to get some air moving more efficiently so I grabbed the box fan and and dropped the window mmm..not enough air so I grabbed the red handle of the emergency exit window and then opened it...I didn't fall out
It was made for a $10 box fan
and and the last picture...no..It's not a wound
I found the 2 seats where the blue and purple fairies sat and am covered head to toe in glitter!!! it has stuck good due to sweat
Old 06-15-2012, 05:16 PM   #32
yankeflyer's Avatar
Chassis: Safe T Liner
Engine: 3208 turbo
Re: El Tortuga
save that steel - it will come in handy later.
yankeflyer is offline   Reply With Quote
Old 06-15-2012, 05:28 PM   #33
browncrown's Avatar
Rated Cap: 79 at Birth
Re: El Tortuga
Dang, you have been busy today Looks like you're making some good progress.
BC
Old 06-15-2012, 08:30 PM   #34
Accordion's Avatar
Year: 1973
Engine: CAT 1160 V-8 Diesel
Re: El Tortuga
El T.
Taking out the seats is indeed an arduous task. Building the inside of a bus is very rewarding because you make it to fit your needs.
I love fruit punch Gatorade.
Old 06-26-2012, 05:57 AM   #35
Re: El Tortuga
I was able to sneak a few hours of work in the last week
and started removing the wire covers etc to access the wireing and to make walls smooth
I know why the bus has a 190amp alt now
Sealed beams for all the flashing lights 8 lights at 100 watts 65+ amps!damn dont need to worry about snow and ice building up on them....havent even looked at the normal turn and brake lights yet
So my "simple" idea of replacing the bulbs with LED's and rewiring to use them for hazards and high brake lights has been put on hold until I can find a suitable fix(ie:cheap )
I do want to keep them for visibilty
Old 06-27-2012, 12:57 AM   #36
Coachwork: ElDorado
Chassis: Chevy P30
Engine: 7.4 liter 454 Chevy
Rated Cap: 24
Re: El Tortuga
would that sheet metal in the seats be large enough to cover your windows if you wanted too?
Bullwhacker007 is offline   Reply With Quote
Old 06-29-2012, 07:10 PM   #37
Re: El Tortuga
Nope way to small and flimsy...
I proceeded to work on the mettalic Taco all day.....OMG!....it was a little bit ...ugh frkin warm!
I got all the seats out...and then put 2 more back in and made a dinette table that Lisa wanted turned out good and was actually very easy to do...pics in the am...since we don't have any frikin power right now!! I am cooking dinner outside on my camp burner...mmm smells and tastes good.....see ya'll in the am!
Damn!weather bug says it's still 92*.....no wonder I'm sticking to the plastic chairs
Old 06-29-2012, 07:24 PM   #38
lornaschinske's Avatar
Rated Cap: 89
Re: El Tortuga
Originally Posted by bansil
... Damn!weather bug says it's still 92*.....no wonder I'm sticking to the plastic chairs
OMG! I wish it were that cool here!
Fulltime since 2006
Old 07-02-2012, 05:19 AM   #39
Re: El Tortuga
It was hot so I needed to get air out and in quickly
So I installed a quick hillbilly ceiling fan,I used a scrap pc of wire cover and 2 factory screws
After removing the rest of the seats
decide to do the dinette real quick
I reinstalled two of the seats(one from each side)
Using existing holes in seat rail
clearance for rivet
counterbored for screws
screws
table mount on wall
finished (except for rounding corners and sanding)
worked in the garden most of the day sunday...damn it was hott
I then spent a few hours on the beds
I will post pics later
Old 07-02-2012, 11:01 AM   #40
Re: El Tortuga
Sometimes quick and simple works out great--that looks like a very functional table.
The Voyages of La Tortuga bansil On the Road | Travel, Trips, Camp Sites, Tailgates 8 09-21-2013 10:12 AM
Screw This Town!!!!! (Updated AGAIN) lapeer20m On the Road | Travel, Trips, Camp Sites, Tailgates 10 12-24-2009 04:18 PM
Space Saving A/V Entertainment Idea (UPDATED) slov Conversion General Discussions 9 02-05-2009 02:31 PM
Smoke 'em if you've got 'em!!! (Bus Burnouts) (UPDATED) phillbus914 Everything Else | General Skoolie Discussions 1 09-18-2008 01:47 PM
Updated pictures in the Gallery Bidin Time Skoolie Conversion Projects 2 06-08-2006 08:04 PM
