Old 09-23-2012, 06:12 PM   #101
Year: 87
Chassis: International s1700
Engine: 6.9 internatiional
Re: El Tortuga
Its looking good, your counters are looking nice
proconsul100 is offline   Reply With Quote
Old 09-27-2012, 07:40 AM   #102
Re: El Tortuga
Stopped by Cline Holder yesterday (contractor supply)
Walked in and saw all the "electricions" and thought this should be fun...I wondered which one would be an ass and make fun of my requests.
Heck would they even deal with me with the small order i was looking for?
I kinda wandered around looking until a sales guy said "can I help you?"
"I hope so, I'm not an electricion tho'"
"that's fine whatcha need?"
I proceeded to tell him I had been to lowes,ebay amazon etc and the panels were to big and $$
I said "I am looking to have 30 amps or so in my...ugh.... skool bus"
He smiled and said "that's cool I have a skoolie also, a 1973 GM short bus!"
He had converted it about 20 years ago and has put thousands of miles on it, he just got back from the beach last week.
He was explaining some things he did and said you need to stop by and I'll show you it.
He hooked me up!!!!!
I got all of this for under $50 it's a 100amp panel and 2 double breakers(that can be had anywhere...most common)
14 fittings for the box to emt,14 emt connectors,4 90* elbows a couple boxes and covers....
He said if you need anything else come back and see me!!!
Woop another awesome contact
Old 09-27-2012, 11:07 AM   #103
Re: El Tortuga
Bansil, great score--we SKOOLIES seem to turn up in all sorts of "real lives" don't we?
Old 09-27-2012, 11:34 AM   #104
Re: El Tortuga
No Doubt!!
If one of the other guys would of helped me I probably would of walked out empty handed ...here is an example: the box was less than a 12pack of "run of the mill" beer
and he didn't give me anything...it was all run through the system and printed out on an invoice....just not sure who's discount I got maybe Trumps
Old 10-01-2012, 06:25 AM   #105
Re: El Tortuga
found a few hours this weekend to work on the bus...3 weeks before first big trip
had to fix steps ( I still think we will remove these this winter/spring)
holes
cut out and bent
lip welded on
mounted up
I attached a 2x4 to the wall studs to mount counter
Removable counter top to facilitate cooking with pots etc.
raised position
doors on
1 fire ext mounted
storage/lockbox and arm rest...still need to put a hasp on it
Old 10-01-2012, 06:35 AM   #106
Re: El Tortuga
also started on some simple wiring...
we like the industrial look and this will all be painted in the future..probably like old copper
a few recepticles for fridge, one outlet will be 12v invertor and other will be shore power(I will just unplug etc)
up to junction box
across ceiling (plenty off head room)
more to follow..
Old 10-01-2012, 12:03 PM   #107
browncrown's Avatar
Rated Cap: 79 at Birth
Re: El Tortuga
You were busy this weekend...step repair looks great Where is your trip going to take you?
BC
My Conversion Thread: https://www.skoolie.net/forum/viewtopic.php?f=9&t=3065
Old 10-01-2012, 12:41 PM   #108
Re: El Tortuga
Thanks...300 miles south to Uwharrie Nat Forest,we have our annual Halloween 4wheeling trip
The fun part will be the first 1 and the last hour...long grades into and out of Boone,NC...
Old 10-10-2012, 06:08 AM   #109
Re: El Tortuga
No more getting squashed by the back door or tieing open!
I recycled the sign clips by screwing 2 of them into the door upside down to hold the rod I made
still need to paint etc...one more thing done
Old 10-10-2012, 06:25 AM   #110
Re: El Tortuga
I had to remove the door to repair the floor.
!!!!!CAUTION!!!!! the door is very frikin heavy,it was a real surprise when it came loose
Big hole
I removed the hinge and reversed it
I drilled a bunch of holes in the hinge so it lined up with tapped holes in the door.
After building up the "ground" with cinder blocks and wood,I wrestled the heavy beast back up and mounted it to the bus
test fold so I could hold it and put screws in
need to take more pics this weekend of it somewhat finished....
Old 10-11-2012, 05:40 AM   #111
Re: El Tortuga
got some more work done on the door last night..in the dark
made a "tie rod" ext for the door
closed
And OPEn..just like the $1,000,000.00 coaches
still have tweaking,gap filling, weather stripping etc,but it works
big opening actually easier getting in and out
Old 10-11-2012, 09:49 AM   #112
Re: El Tortuga
Way better, nice job.
Old 10-11-2012, 01:16 PM   #113
Re: El Tortuga
Thank you Sir~
I am experimenting with everything trying to get it usable and then make it comfy
Old 10-15-2012, 06:01 AM   #114
Re: El Tortuga
Got some done,started off by pulling wire, 12ga stranded just like we us at work on machines
I hooked up 50 amp service, why?
Because the cord was only $20 more than 30 amp and since most of the NP we stay at are 50 amp this gives the option of running 2 ac's plus or 2 heaters plus.
We have 2 zones in the bus basically.
The bedroom and kitchen area so I wanted to make sure that we had power to it on 20/30 amp and the 50 hookup gives the advantage of just having more if needed.
I leg of 120 goes to the breakers that power bedroom and kitchen
1 leg of 120 goes to other breakers for dinete and front
with the 30 amp adapter it ties both 120's together so all circuits are powered (you just have to mind total amps needed/used) this allows all receticles to be used throughout the bus just as if we were plugged in to 30 amp.
This upcoming trip will have us plugged into 50 amp sevice so we can have a heater going in the bedroom area and in the kitchen area with plenty left over to run everything else (rotisserie,coffe pot,blender microwave and fridge)
I also added a 12v aux circuit to the front of bus to provide power to a few aux fans if needed as well as the extra lights that will be added this winter when I do some tube work to the front.
Old 10-16-2012, 12:33 PM   #115
browncrown's Avatar
Re: El Tortuga
The work you did on the front door is awesome...great job
BC
Old 10-17-2012, 05:38 AM   #116
Re: El Tortuga
Thankyou, it's fit form and function are great....it needs some help in the cosmetic dept tho' ...that will come with time.
Old 10-17-2012, 11:25 AM   #117
roach711's Avatar
Rated Cap: 19
Re: El Tortuga
I like the ammo box by the passenger seat. Very handy for quick reloads while repelling zombies.
The Roach Motel
Old 10-17-2012, 11:59 AM   #118
Re: El Tortuga
you can never have too much 7.62 handy
Old 10-17-2012, 02:26 PM   #119
thommassey's Avatar
Chassis: All American RE
Engine: 3208TA Cat 250HP
Re: El Tortuga
How did you stabalize the center of the door so it would not hinge in the middle anymore?
TUMBLEWEED (AKA Rufus) build:
viewtopic.php?f=9&t=11121
PICTURES : https://s1338.beta.photobucket.com/user/ ... M-HP/Rufus
thommassey is offline   Reply With Quote
Old 10-17-2012, 03:11 PM   #120
Re: El Tortuga
I didn't take pictures because it "looks" ghetto .(pure luck they aren't in the pictures)
Since I was just seeing if it would work I grabbed 2 pcs of 1/4 x 1-1/2 I had about 14" long drilled thru holes and just used self tapping screws(4 or so per door half-staggered) to make door not move(1 on the top and 1 on the bottom) it is very rigid for how quickly it was done
see:
My doors were pretty trashed (saved $500) since I was planning to seal it up and move the door anyways.
so far I like the door so I will actually re-do this
Door opens very wide now,and with a quick pull of the door pin it swings out past 90* to the mirror
I will paint the lower windows black before covering the inside (we really want to keep the stock bus look from the outside, but have it function differently)
***edit...I will post a pic in the morning...***
So hinges will be exsposed and sealed/weatherproofed from the inside
The Voyages of La Tortuga bansil On the Road | Travel, Trips, Camp Sites, Tailgates 8 09-21-2013 10:12 AM
Screw This Town!!!!! (Updated AGAIN) lapeer20m On the Road | Travel, Trips, Camp Sites, Tailgates 10 12-24-2009 04:18 PM
Space Saving A/V Entertainment Idea (UPDATED) slov Conversion General Discussions 9 02-05-2009 02:31 PM
Smoke 'em if you've got 'em!!! (Bus Burnouts) (UPDATED) phillbus914 Everything Else | General Skoolie Discussions 1 09-18-2008 01:47 PM
Updated pictures in the Gallery Bidin Time Skoolie Conversion Projects 2 06-08-2006 08:04 PM
