Old 11-14-2012, 02:18 PM   #161
Re: El Tortuga...update 11-13-12!
Thanks everyone, now I only have 500 SQ FT more to paint
and then the graphics get painted or stuck on
Old 11-19-2012, 02:32 PM   #162
my $20 score at the "antique barn"
it is very loud
Old 11-19-2012, 04:27 PM   #163
GreyEagle's Avatar
Didn't know you had that much air......
nice score, will look nice on the bus.........
GreyEagle
Roll - On...
GreyEagle is offline   Reply With Quote
Old 11-19-2012, 06:44 PM   #164
You didn't notice what all was behind "the horns" ....
Old 11-19-2012, 08:21 PM   #165
HA HA--spotted it right away. Not only will the horns scare the sshaat out of 'em the smell will convince them that it really did! I think I like you---not a nice bone in your body---only kidding. Jack
Old 11-20-2012, 12:26 PM   #166
Shadoll's Avatar
Year: 1979
Engine: 8 cyl gas
Rated Cap: 60
it is very loud
I have these on my bus, haven't sounded them yet. (The guy asked me shortly after I got it if I'd tried the horn yet. Guess I never thought of it.) I chipped one when I hit the branch parking it, my first casualty.
Linda Kay
trans·mog·ri·fy Verb: Transform, esp. in a surprising or magical manner.
Shadoll is offline   Reply With Quote
Old 11-20-2012, 01:06 PM   #167
I ordered a solinoid yesterday of the Bay
I have a few left over fittings,I hink I will just hook into the aux tank right now and move it to my air tool/tire inflatting aux tank this spring when I get it mounted
Old 11-21-2012, 04:24 PM   #168
somewhereinusa's Avatar
Chassis: AARE
Engine: 3116 Cat 250hp
Before you put them on you might want to check for "bugs" mine didn't work and they were packed with bugs at the small end.
Old 11-21-2012, 07:03 PM   #169
I pulled the air supply for the door piston and stuck it in the port; 135# of air .... thank god I was smart enough to put on ear plugs first it was very loud....
No bugs came out...kinda depressed after reading about all the "ejected bugs" on the internet
I now know this is not a horn to play with (much ) cause it wuld scare the crap out of someone and make them panic, thinking they were gonna be crushed
Old 11-22-2012, 10:24 AM   #170
Many years back I rode a 1975 BMW motorcycle just about everywhere. After a few close calls with car & truck drivers who assumed any space my bike didn't occupy in my lane was theirs to use, I installed a set of Fiamme electric air horns that sounded for all the world like an eighteen wheeler. From then on, anyone creeping too close got a blast that scared the Bejeezus out of them and they whipped back where they belonged. By the time they figured out they weren't about to be crushed...I was safely gone. A horn is a warning device. A LOUD horn is a great warning device.
Old 11-26-2012, 06:45 AM   #171
after driving the bus wensday to pick my son up from college and I needed to bring home some 20/24 foot metal,I relised the headlight output sucked badly.
This was the first time to drive at night with the bus,I have had an intermitten issue with dash lights going out since I have had it.
The lights where yellow looking and not bright.
I started looking for a bad ground, I pulled the lights notice anything?
you can see the element!!!
this was the worst one, no mirror surface left!!!!!
I pulled the headlight switch out and found this...burnt wires
The main 12v in was burnt, after taking switch apart and finding it melted inside...a new one was needed,I replaced the switch.
I also cut out about 12 inches of the power wire,soldered a new lead in
and after adding up the headlights on high beam 2 @ 60 watts and 2 @ 55 watts I was at about 18.5 amps,then if you factor in the 12 marker/parking lights I was actually well over the rated load carrying for 12 ga wire.
so I wired in a seperate 12v 20 amp circuit for the park and marker lights with a simple switch.
now I only have headlights on the circuit and should be good from here on out.
Old 11-26-2012, 11:59 AM   #172
Good fix. You might want to put a little dieelectric grease on the new headlamp terminals. It helps stop the development of a high resistance short as the terminals begin to corode due to moisture. I have seen many car fires which were started by high resistance shorts in the lighting system. My two cents worth. Jack
Old 11-26-2012, 01:04 PM   #173
yup,I need to get some more...it comes in such little tubes I always lose them after using just one use
I was just amazed at how much crap they were pulling off just a 12 ga wire
Old 11-26-2012, 01:06 PM   #174
GreyEagle's Avatar
Nice job......... It'll be nice to be able to see at night...
GreyEagle
Roll - On...
Old 11-30-2012, 04:29 PM   #175
where to start...big plans to knock out the horn install and an aux tank for tools and tire inflation.
Mmmmmmmmm...how did it go you ask.....well it started at 21 degrees.
blagh,blagh,blagh...I grab the horns,valve and tubing,no worries...yugh...right
the threads were not 1/4 NPT like they looked, so fitting didn't screw in...no big deal we'll just drill it out and tap it.
nope....to do this you have to take them apart so you caan blow out the chips etc.
screws had reacted(badly) being dissimilar metals as they do....
so I entered the building of doom and found this.
4 broken bits later(they were to "hard"...yes there are 3 in the pic...I threw one )
so I had one left that would not come out...argh....so I grinded it off flush.
which ment I had to drill and tap 3 holes 6-32
so now to work on air inlet.
once again I entered the domain of satans flying dive bombers (thank god it's cold out )
okay hole is drilled 7/16...crap where is my tap???
to town I went 45 min later part is clamped to something heavier than my lap and hands...
ooohh look, threads..
that is porosity not a torn thread
oh did I mention I had to drill some mounting holes for it??? nope...two .343 holes for a couple 5/16 bolts
i just sprayed it down with brake cleaner...blew it off and sprayed it with Almond real quick.
I brought it inside to dry...and I'll be damned...dropped it in spare bedroom...arggghhh...it's okay tho'
The cat hair stopped it from getting on the carpet....
let's see what tomorrow brings!!!!!!!!!
Old 11-30-2012, 06:52 PM   #176
Re: El Tortuga...update 11-30-12!
Hey Bansil, laughing with you not at you. Isn't that the way those things go just when you think you've got things under control? Can't help but wonder what those threads were originally. Anyway, nice save and now you can blow your own horn--so to speak. Jack
Old 11-30-2012, 07:37 PM   #177
GreyEagle's Avatar
Sure glad someone had a GREAT! Day.......
Keep us posted. This is entertainment at it's best. Getting to laugh with you..... Congrats..
GreyEagle
Roll - On...
Old 11-30-2012, 08:35 PM   #178
travelinwithus's Avatar
Thanks for sharing, made my day better.
travelinwithus is offline   Reply With Quote
Old 12-01-2012, 04:48 AM   #179
You are all welcome
Jack they were a straight 7/16-20,I'm guessing it had a npt threaded stud so a nut would tighten down as a mounting bolt,and then the hose connection was threaded in.
And since I really didn't want to make another weird stud,I just made my own mounting holes and npt port.
Old 12-03-2012, 08:17 AM   #180
The rest of the story
I drilled holes to mount the horns
I made a bracket for solenoid
and mounted it up front
here they are!
I like them,
my wife said"so you mounted them outside,not hidden underneath...you just had to make it more redneck hugh?.. .. "
REDNECK???...Honey it is a Skool bus...
We both started to laugh..
The Voyages of La Tortuga bansil On the Road | Travel, Trips, Camp Sites, Tailgates 8 09-21-2013 10:12 AM
Screw This Town!!!!! (Updated AGAIN) lapeer20m On the Road | Travel, Trips, Camp Sites, Tailgates 10 12-24-2009 04:18 PM
Space Saving A/V Entertainment Idea (UPDATED) slov Conversion General Discussions 9 02-05-2009 02:31 PM
Smoke 'em if you've got 'em!!! (Bus Burnouts) (UPDATED) phillbus914 Everything Else | General Skoolie Discussions 1 09-18-2008 01:47 PM
Updated pictures in the Gallery Bidin Time Skoolie Conversion Projects 2 06-08-2006 08:04 PM
