Old 03-17-2012, 12:02 PM   #21
Year: 94
Coachwork: b/b
Chassis: tc2000
Engine: 5.9
Re: legault family
hell use my adress,and than they can kiss your butt......the insur co are just jerks
keith is offline   Reply With Quote
Old 03-21-2012, 11:53 AM   #22
Year: 97
Coachwork: blue bird
Chassis: ct2000
Rated Cap: 44
Re: legault family
so I started the windows. I hope that you guys dont read how I did this and tell me I screwed up lol. To start i removed the windows and disassembled them. I took 7/8 osb and attached primed metal flashing to it. then I placed the wood in the frame, where the windows would go. heres a pic of the test fit
when i put this in the bus. I hated it, if felt like there was just to many places that needed to be caulked and that it was going to leak. So I kept the idea of the metal attached to the wood backer. But I placed the wood into the the opening on the bus where the window would have been. I caulked all the edges. I tube of caulk per window. then I used 1x4 all around the window to hold the wood in place.
Once in place this seemed to give a cleaner line, and less to caulk on the outside. it seems to be pretty strong too. no flex on the wood. this is the finished window
legault83 is offline   Reply With Quote
Old 03-21-2012, 11:56 AM   #23
Year: 97
Chassis: ct2000
Rated Cap: 44
Re: legault family
This is alook at the windows I have done so far.
Old 03-21-2012, 09:49 PM   #24
jkindt's Avatar
Year: 1981
Chassis: Ford B-600
Engine: Ford 370 Propane
Rated Cap: 48
Re: legault family
That's how it's done! I filled many of my windows using 1/2" plywood laminated with smooth FRP. Then primed the same color as the bus, using a UV blocking automotive primer to protect the FRP. Sealed in place with quality butyl rubber caulking, then ran a bead of exterior caulking around the seam inside, then covered with 1/2' rigid insulation, sealed with sealing tape, and covered with my interior panelling. Works great!
Old 03-21-2012, 10:02 PM   #25
browncrown's Avatar
Rated Cap: 79 at Birth
Re: legault family
Windows looking fine!
BC
Old 03-22-2012, 10:40 AM   #26
lornaschinske's Avatar
Rated Cap: 89
Re: legault family
We only used wood as a backer on the windows that would have vents thru them (needed to attach the vent to something). I also used a whole tube of caulking per window. Where did all that caulking go? I'm pretty sure our windows won't be leaking.
Fulltime since 2006
Old 04-09-2012, 05:36 PM   #27
Year: 97
Chassis: ct2000
Rated Cap: 44
Re: legault family
Havent had a chance to post in a bit. I have finished the windows that will be blocked out now. So Im waiting for the new rv windows to come in and i can get all that in place. Im going to start the framing and I have a quick question for everyone.....is there a reason i cant use regular insulation on my outside walls? it just seems like everyone eles uses the insulation board.
Old 04-10-2012, 08:18 AM   #28
Diesel Dan's Avatar
Engine: DT466/AT545
Re: legault family
I think people have said that if any moisture got into the regular insulation it would hold that moisture and cause the metal walls to rust.
Gallery:
Conversion Thread:
viewtopic.php?t=4959
the family wagon family wagon Skoolie Conversion Projects 121 07-18-2016 12:32 PM
Family Tardis MistRiver Skoolie Conversion Projects 44 09-23-2014 08:57 AM
Family looking for long bus bansil Classifieds | Buy, Sell, Swap 9 02-28-2013 06:56 PM
why dont family believe?? bansil Everything Else | General Skoolie Discussions 2 11-25-2012 03:44 PM
Our First Bus... family Skoolie vwdude Skoolie Conversion Projects 14 06-13-2012 08:33 AM
