Old 01-16-2014, 02:55 PM   #21
Locutus's Avatar
Chassis: Super Coach II, 36 Ft. RE
Engine: Cat 3208T, MT643
Re: Locutus' Skoolie Conversion: 1990 Crown Super Coach II
A question for you mechanically inclined (AKA grease monkey) skoolies...especially you Crown Coach guys (and gals?):
My 1990 Crown Super Coach II has airbag rear suspension, but leaf spring front suspension. The front end tends to bounce more than I would like while driving. I'm considering having the front suspension replaced with an airbag retrofit. What do you think about the practicality of such a project? Is it even possible? Are we talking big bucks? Have any of you ever done this with your skoolie?
If Crown was still in business I could contact their tech support but of course Crown as an enterprise is long gone, more's the pity.
Locutus
(Latin) loquor loqui locutus dep. [to speak (in conversation); to tell , say, declare, talk of].
Children drink kOOlaid, adults drink T.E.A.
Gallery: https://www.skoolie.net/gallery/v/Skooli ... +Coach+II/
Locutus is offline   Reply With Quote
Old 01-16-2014, 05:42 PM   #22
Stu & Filo. T's Avatar
Coachwork: Crown / Pusher
Originally Posted by Locutus
John,
I'm actually planning to remove the side windows and skin over with sheet metal, then cut openings for RV windows. But I was looking closely at the stock windows yesterday and couldn't figure out how they're installed. Do you know how to remove this type of window?
On my 88 Crown I had to take the driprail off so I could tilt the top of the window frames out then slide the glass out then remove the window slide rails, there's also 2 screws holding the window rails in, that driprail is one long piece the entire leghth of the bus
Old 01-16-2014, 08:28 PM   #23
Locutus's Avatar
John,
Holy Crud. There's gotta be an easier way. What happens when a window breaks in service? I don't it's good design if you have to remove a bus-length drip rail just to replace a broken window.
Locutus
Old 01-16-2014, 08:41 PM   #24
John,
There Crown windows they don't break
No seriously there were places where there where new screws installed & looked as if it was resealed , I tried getting them out other ways & thats what I came up with which is also good because now when I reskin I'll be able to but the sheet metal covering the sides under the sheet metal on the roof with about a 3in overlap then reinstall the drip rail
Old 01-27-2014, 09:21 AM   #25
Locutus's Avatar
I'm thinking of getting this on-demand water heater for the bus.
http://www.precisiontemp.com/rv-and-tra ... -trailers/
Price makes me gag though. Still, it would be much better for cold weather use (read: ski trips) than a conventional RV hot water tank.
I would also like a refrigerator like this marine unit:
http://www.westmarine.com/webapp/wcs/st ... uZ7mBDTmig
Again, price is an issue, but because it's AC/DC only (no gas) I wouldn't have to cut a vent hole in my nice arched bus roof. It's compressor driven so the DC power draw is only 3.5 amps on 12 volts DC. And because it's designed for marine use, it's more tolerant of out-of-level conditions. With enough solar panels and batteries, operating cost would be essentially zero.
Locutus
Old 01-27-2014, 04:06 PM   #26
What did you find out about your window removel?
Old 01-28-2014, 12:27 PM   #27
Locutus's Avatar
Nothing yet. Remodeling the basement of my house at the moment. When that's done I can work on the bus.
Natster, I'm interested in how you set up the water heater for hydronic cabin heating. Details please? Perhaps I could set up a second RV-550 NSP for this purpose.
I was looking at another brand similar to the eccotemp. One reviewer complained that outside freezing air came down the exhaust and froze the copper coil, bursting it. Sort of turned me off from this type of heater. The RV-550 NSP has built-in freeze protection that automatically heats the unit when temperatures below 38*F are detected. Propane and 12 power have to be left on for this to operate, however.
Locutus
Old 01-29-2014, 09:59 AM   #28
Locutus's Avatar
Pretty cool setup that guy has with his home heating. Total cost was around $5000.00 so I don't think it would be cost effective for an RV. You'd still need all the same components except less Pex and perhaps only one heating zone. So maybe $4000 instead of $5000. Another thing is that in an RV, most of the floor is covered by cabinets and furniture. So unless you route heating Pex in the walls too, I don't see how it would work well in an RV.
I've been looking at many heating options, ruling out any that consume cabin oxygen and introduce water and CO2 into the cabin atmosphere (i.e. catalytic or vent free propane heaters). Empire and Wilson make some good made-in-USA direct vent heaters which I'm considering, and their cost is comparable to a typical Atwood or Suburban RV Furnace. Their main advantage is that they require no electricity to operate, which is important, but their disadvantages are that they take up floor space (footprint and required clearance) and the exhaust would protrude out the side of the bus about six inches. So I'm starting to swing back to a standard RV furnace even though they consume a lot of 12V electricity and are less efficient with propane. I suppose I could increase the size of my battery bank and solar array to compensate.
Edit:
perhaps a more economical way to go about it would be to pump the water through automotive heater cores fitted with 12 volt computer cooling fans. These might make excellent heat exchangers for a fraction of the cost. Maybe $50 to $100 per heat exchanger. Obviously this would have to be a separate loop from the domestic hot water supply, as in the author's article. But with the cost of all the extra hardware, it might be cheaper to use two separate heaters rather than one for both functions.
Locutus
Old 01-30-2014, 10:52 AM   #29
Diesel Dan's Avatar
Engine: DT466/AT545
I'm sure the water heat in the floor would be the most comfortable option, but yes, you would pay a premium for that in both parts and labor. And I would worry about leaks, and the fact that if it did develop a problem, you may have to tear out your whole conversion to fix it. I spent the day in my bus the other day, and it was 25F outside. My portable propane heater kept me from freezing, but it was like 90 degrees at the ceiling and it felt like 50 degrees at the floor. My floor is barely insulated at all, so that is a large part of the problem, but I have to admit I was fantasizing about how wonderful it would feel to have in-floor heat.
Gallery:
Conversion Thread:
viewtopic.php?t=4959
Old 01-30-2014, 06:52 PM   #30
Hey Dan...Ceiling Fan!
Old 01-30-2014, 09:22 PM   #31
Sure works in my house with 12" ceilings!
Old 02-03-2014, 10:17 AM   #32
Locutus's Avatar
Air conditioning.
Powering it while driving.
No new hole in roof.
Tight budget.
There's the problem in a nutshell.
I've been going round and round on this. At first I thought it would be okay to power it with a generator while driving. But there are several issues with this, not the least of which is safety.
I'm also looking into the possibility of powering the A/C with the alternator. That would require an inverter. But big inverters are expensive, and there is the question of whether the (150 amp) alternator in my bus puts out enough juice. A 150 amp alternator translates to only 15 amps at 120 volts AC current. That's with 100% conversion efficiency, which is impossible of course. A friend of mine suggested running two alternators. Not sure how I would set that up.
I'll have four power sources available depending on the situation: shore power, generator (maybe), solar, alternator. The big appliances I'm figuring will not be run from the battery. That will be A/C, laundry, dishwasher, microwave. Fridge will be an AC/DC compressor unit, not a propane fridge. Furnace and hot water will be propane only. I'll be able to get by with a 30 amp circuit for these, plus a 15 amp circuit for the outlets.
So I think the outlets will probably be the only circuit that will need an inverter, and maybe only a MSW inverter at that. For sensitive electronics I may use a smaller sine wave inverter dedicated to those items.
The only big appliance that will need to run while driving is the air conditioner. So how to power it while driving, and how to wire it are the problems I'm trying to solve at the moment, as well as what air conditioner to install.
I don't want to cut any holes in my roof. So I'm thinking of maybe a ductless mini-split unit like this one:
http://www.homedepot.com/p/GREE-High-Ef ... /204764248
These are efficient and much quieter than a rooftop or window unit, since the compessor is mounted outside. (On a bus, that would be a vented basement compartment.) Kind of pricey though, and again, there's the budget.
Or maybe I could mount a rooftop air conditioner underneath the bus, routing ducts to the inside. Has anyone ever tried this?
The third option is a window unit mounted inside, in a box vented to the outside so that the unit doesn't stick out of the bus.
Of course the cheapest option would be to do without. I wouldn't need a generator or any other special set up to power it in this case. In my area A/C is rarely needed. My house has no A/C either. However, one of the planned uses for this bus is to take summer trips to hotter, drier areas, like eastern Washington for shorter trips, and the greater Desert Southwest for longer trips. A/C will be a prerequisite for comfort in these situations.
What do you all think would be the best, and/or most cost effective solution? I've ruled out swamp coolers because I'm trying to eliminate any added moisture to the cabin atmosphere. How would you wire your solution? What special hardware would you use? (Here I'm referring to generator, alternator, inverter, controller, transfer switches, relays, etc.)
Locutus
Old 02-03-2014, 11:10 AM   #33
Loctus, there are several comprehensive posts re mini splits on Bus Conversions.com. For the most part they seem to have been problematical due to the flexing the coolant lines undergo. Like you I didn't want to have the a/c sticking out of the bus so I had planed on using a free standing heat pump to both heat and cool. In the end opted for a conventional propane heater and an 8000 BTU window a/c which I vented through the floor of my shortie. The reason I gave up on the heat pump is that the heat portion relies on there being enough heat in the outside air to allow for transfer and that ability ceases at temps below 40 degrees F. Hope this helps.
Old 02-03-2014, 11:38 AM   #34
Locutus's Avatar
Nat,
Sterling power has an alternator to battery charger, and a 200 watt alternator I could add, but they're $$$.
http://sterling-power-usa.com/alternato ... arger.aspx
http://sterling-power-usa.com/alternator.aspx
A propane generator would have less toxic exhaust but I'm a little leery of traveling with the propane valve open. Diesel generators are too expensive for me. I'm thinking maybe the Champion 3500 watt propane unit at about $450 might be okay.
Trunt,
Thanks for the tips on the mini-spilt issues.
I do have an emergency escape hatch in the roof that could perhaps be retrofitted with an RV A/C unit, but it's in the back end of the bus (about 6 ft from the back). I'd have to duct it's output towards the front. With a ceiling center height of 6' 5", that doesn't give me much vertical room. If I could duct along the sides instead of the middle, that might be a viable plan.
Locutus
Old 02-19-2014, 09:59 PM   #35
LuckyChow's Avatar
Coachwork: Phantom
Chassis: Gillig
Engine: Series 50
Yes, most of our transit and commuter buses (MCI's) use a Delco 50DN alternator. Typically they are 24v, 275 amps. They are oil cooled, with the oil supply coming from the engine. This is the alternator that is on my bus as well.
Twelve years from now, this scenario may be different. Electric bus air conditioning is just now becoming available to order on new equipment. Buses with this option typically are spec'd with a 24v 500 amp alternator. It is an option on our new bus procurement (at work), although we are not likely to order it yet due to the increased capital cost. However, I expect electric a/c to become the standard at some point. The long term reduced operating cost is a big factor and the units already in the field are reportedly doing very well with greatly reduced maintenance. Maintaining the a/c system is one of the larger year-to-year cost for operating a bus fleet.
LuckyChow is offline   Reply With Quote
Old 02-20-2014, 08:48 AM   #36
Locutus's Avatar
Luckychow thanks for that info.
Such a system is probably well out of my budget though. As I've looked further into A/C possibilities, I'm starting to think that the simplest and most cost-effective option for my purposes is a single rooftop A/C unit, mounted where the escape hatch sits currently. If I install the right ducted type of unit I can then duct the cooling forward to the rest of the bus. (The escape hatch is about 6 feet from the back end of the bus.) No new hole will be needed if I mount the A/C there, and it won't take up cabin space like a window or portable unit would.
Another possibility I'm looking at is to have a double-use space near the middle of the bus for both a portable A/C unit and a wood stove. The wood stove would be a small unit like the Little Cod, and mounted such that it could be removed for the Summer months and a portable A/C unit installed in its place. Both would then vent out the adjacent window, each with its own window vent mounting plate. The Idea being that I wouldn't need the wood stove in the summer, nor would I need the A/C the rest of the year.
Last week I received my four DM-158 solar panels. They will be mounted flat, in front of the escape hatch. That's up to 632 watts of solar power. Should be enough to keep the batteries charged and run the smaller appliances and lights (not the A/C).
Locutus
Old 06-03-2014, 11:14 AM   #37
Locutus's Avatar
Major score on a generator last Friday. Only $35 off Craigslist for a used 5000 Watt unit similar to this one:
No wheels or handle, but it does have a nice Subaru engine. Seems to run fine. Needs some maintenance and cleanup. New units like this cost about $700.00
I would have liked to find a RV Onan with remote start and all, but at $35.00 I couldn't pass this up. At this price I think I can live with the pull start for a while. I'll probably use it very little anyway, considering I have over 600 watts of solar panels to install.
Locutus
Old 12-15-2014, 10:12 PM   #38
Locutus's Avatar
Well, 4 1/2 years after buying my bus and not getting much done besides removing the seats, I'm thinking about maybe selling it and going a different direction.
Reasons--
Too much work.
Too much money to make it the kind of RV I would like.
Too much time.
Not the right skill set.
Laziness
The magnitude of the project is a bit overwhelming, and my skill set is best utilized at a desk computer, not in building things. I could buy a trailer and tow vehicle for less than what it will cost for this bus project. Plus I'm considering going a wholly different direction altogether--getting an ocean-capable sailboat about 35 to 40 feet long and sailing the inside passage to Alaska, and perhaps later to the South Pacific.
I dunno. Haven't decided yet. Any of you guys or gals interested in a 36 Ft Crown Super Coach II with rear diesel Cat 3208 and Alison 640 transmission, with 110,000 miles on it?
Locutus
Old 12-16-2014, 03:08 PM   #39
I am, where are you located? And how much would you want for it
jmar896 is offline   Reply With Quote
Old 12-16-2014, 03:38 PM   #40
Locutus's Avatar
I'm in Kirkland Washington. Jmar please check your PM.
Locutus
Three Crown Super Coach II's for sale Crown_Guy Classifieds | Buy, Sell, Swap 11 01-03-2015 01:30 AM
Looking For 1970-1990 Crown Super Coach in/around WA frank-id Classifieds | Buy, Sell, Swap 0 11-15-2010 12:28 AM
Thomas Saf-T-Liner, or Crown Super Coach II. Which one? Locutus Conversion General Discussions 28 07-19-2010 11:35 AM
1990 Crown Super Coach II Locutus Classifieds | Buy, Sell, Swap 3 06-23-2010 01:44 PM
1971 Crown Coach Conversion chakra Classifieds | Buy, Sell, Swap 1 05-06-2005 01:56 PM
