Old 07-23-2010, 09:30 PM   #1
Locutus's Avatar
Chassis: Super Coach II, 36 Ft. RE
Engine: Cat 3208T, MT643
Locutus' Skoolie Conversion: 1990 Crown Super Coach II
And so it begins.
I bought a 1990 Crown Super Coach II at the Stokes Auction in Gig Harbor, WA last Saturday, 07/17/2010. Overall length 36FT, usable interior length is 29' 7", as measured from the back of the driver seat to the front of the upper engine shelf. It sports a rear Cat 3208T engine, Allison MT643 Transmission, 110K miles. Tires look pretty new. Here's how it looked while sitting at the auction site:
For about two or three months prior to making the purchase I was busily preparing a parking spot at the side of our house, which involved many loads of fill, hard physical labor, and landscaping. I wanted an attractive site to park it with RV electrical hookup. The electrical is the final piece of that puzzle and will be completed next week with the help of a friend from work.
I took the bus down to Power Shifts Northwest in Woodinville today, to have the Tranny checked out. It got a little hot on the drive home on Sunday, with the gauge climbing to 230 degrees F, thereby setting off the temperature alarm. So Harry's going to troubleshoot that tomorrow. This gave me an opportunity to take some photos of my landscaping handiwork for your viewing pleasure. You likey?
The bus' engine seems solid, the tranny shifts perfectly. Aside from the temperature issue there's only one other major problem to address: The listing to starboard. I need to find a reputable shop that won't gouge me, who has experience working on bus air suspensions. One or more of the airbags may need replacing, or maybe lines, or seals or a combination. I think the front leaf spring may be suspect too, or else why would the front be leaning the same amount as the rear?
Anyone know of a good air suspension shop in the Kirkland, Washington area?
Locutus
(Latin) loquor loqui locutus dep. [to speak (in conversation); to tell , say, declare, talk of].
Children drink kOOlaid, adults drink T.E.A.
Gallery: https://www.skoolie.net/gallery/v/Skooli ... +Coach+II/
Locutus is offline   Reply With Quote
Old 07-24-2010, 11:05 AM   #2
Locutus's Avatar
Re: Locutus' Skoolie Conversion: 1990 Crown Super Coach II
John,
I'd love to go to BGW, if I can get away. Pretty far to bring the bus though. Is it held in Southern California?
As for my conversion plans, here's a brief rundown.
I'll be doing the conversion as a self-contained boondocker, plus 30 amp shore power when available. This means large holding tanks, hopefully 200 or 300 gallons fresh water. Ideally, the furnace, water heater and genset will be diesel/WVO powered like the engine (Frybrid conversion). I'll still need a small propane tank for the range though. I'd like the fridge to be an apartment sized household model, and independantly powered with it's own solar + battery power loop. To keep roof holes to a minimum I'm thinking an underfloor ducted AC setup. I also want a washer and dryer, and compact dishwasher in the kitchen. A microwave goes without saying, of course. I'll probably set up a master bedroom with under bed fresh water tank in the rear of the bus, although I'll need to counterweight that forward of the axle with something else, say, batteries or WVO tank. If there's room, I'm planning a double bunk along one wall, with storage or the bathroom opposite. There's lots of room underneath the floor, so I'll be installing as much infrastructure as possible there: holding tanks, batteries, furnace, genset, water heater, etc. I also want to enclose anything that will hold water in insulation with the furnace ducting heat through the enclosure. This will allow year-round use, even in the mountains when we go skiing. With the ceiling center hight at 6' 4", I dont think I need a roof raise, but only if I don't build up the floor more than an inch. This means under floor insulation, probably spray foam covered with undercoating. I may also build one or two small slideouts: one for the couch and maybe one for a closet in the master bedroom. Since the bed will probably have the FWT under it, it makes more sense to move the closet than the bed. The ceiling panels are riveted so I'll be leaving those alone, although I may cover it with a thin insulative layer, maybe commercial adhesive carpet or something.
But, I also want to be able to finish it during my lifetime, so we'll see how it goes.
Locutus
Old 07-24-2010, 02:40 PM   #3
Locutus's Avatar
John,
Bummer on the furlough, dude. It always seems that you either have money but no time, or the opposite: time but no money.
I'm blessed in that our household has two incomes, plus my budget for the bus will come out of what's left of my inheritance. So with careful planning and shopping, money shouldn't be the issue. But I'll have to carefully budget my time!
Locutus
Old 07-26-2010, 08:48 AM   #4
browncrown's Avatar
Rated Cap: 79 at Birth
Welcome and congrats on your new bus...that model Crown is a nice vehicle.
BC
My Conversion Thread: https://www.skoolie.net/forum/viewtopic.php?f=9&t=3065
Old 07-27-2010, 04:43 AM   #5
Engine: DTA360
Rated Cap: 16
Nice looking bus...
I'm in the Puyallup/Graham area... We've been looking at buses for a bit...
This should be a really cool project for you...
I'll be keeping an eye on your build...
Congrats...
dirtygoat is offline   Reply With Quote
Old 07-28-2010, 01:57 AM   #6
cheezypsnookle's Avatar
Coachwork: Bluebird tc2000
Chassis: 3401-3502 ???
Engine: cummins 5.9
locutus reminds me of tng..{ star trek the next generation} it was picards borg name + insert skoolie resistance is futile quote here+.. anywho welcome and grats on the purchase
cheezypsnookle is offline   Reply With Quote
Old 07-29-2010, 02:23 PM   #7
Locutus's Avatar
I got the bus back from Power Shift's Northwest yesteday. Just a basic tranny service: new fluid and filters. No indication of anything wrong internally. However, I'm concerned about the 230 degree (F) cruising temperature and resultant warning alarm. This happened about 20 minutes into the freeway drive home from the auction site.
Harry (at PSN) says I probably need a larger tranny cooler. But his estimate is in the neighborhood of $600-$700 (plus tax). Of course I balk at the idea of spending almost half as much for this as I did for the whole bus!
Any ideas for a cheaper retrofit or other fix? (For example, perhaps I could rig 2 or 3 smaller, cheaper coolers in series to have the same effect as one larger one.)
Harry did pinpoint the suspension leak problem, in one of the levelers. He suggested replacing both. I'll probably have that done at Moe's Truck Repair in Kirkland in the near future. Depends on the cost whether I have them do it or attempt it myself. At any rate this MUST be done before I start the conversion (other than demolition) because I need a plumb and level bus body for construction, or else all the partitions, bunks cabinets, etc, will be out of plumb.
One other point that came up at PSN: the hydraulic radiator fan is always on when the engine is running. This is a modification that was done at some point to keep the engine temperature cooler, and explains why it took 20 minutes for the engine temperature gauge to reach 180 degrees. If I do a WVO conversion I may have to change it back so that the engine reaches full operating temperature sooner, so as to bring the WVO up to useable temperature sooner as well. The Frybrid system uses engine coolant heat exchangers to heat the WVO to 160 degrees before switching from diesel to WVO.
Locutus
Old 07-29-2010, 09:28 PM   #8
bus-bro's Avatar
Engine: 3208 na boat anchor
I wouldn't worry to much about being plumb and level for your build. Refrence to the floor. Build some big 3x4x5 triangles to square things up.
Old 07-30-2010, 05:40 PM   #9
Locutus's Avatar
POWER ON!
Yesterday I completed the Power and cable hookup. It includes both 30 amp and 20 amp service, plus coaxial TV cable.
Locutus
Old 07-30-2010, 07:42 PM   #10
M1031's Avatar
Coachwork: Ward
Chassis: Ford B600
Engine: 6.6L Turbo Diesel
Rated Cap: 26
I love that idea! I've done something similar at the farm. However, I did not think about the cable tv. I smell another project coming on....
M1031 is offline   Reply With Quote
Old 07-30-2010, 08:44 PM   #11
Locutus's Avatar
Yeah, I figured as long as I was digging the ditch anyway, I may as well run a line for the cable too.
Locutus
Old 09-15-2010, 08:43 PM   #12
Locutus's Avatar
I got the bus back from the truck repair shop today. Suspension work. Two airbags, two leveling controls, freight, labor and tax came to just shy of $1000.
So with the purchase cost, tranny tuneup and this latest expense, I'm into the bus for about $3500. But it shouldn't need any more mechanical work for quite a while. I might add an additional tranny cooler at some point in the future, probably not until after the conversion is finished.
The shop owner previously worked for NC Machinery (the Caterpiller dealer) for something like 17 years. He's very familiar with 3208s and has overhauled hundreds of them. He discovered that it's a remanufactured 3208, but he says that's probably a good thing because 1: it probably has fewer miles on it than the 110K that's on the bus, and 2: for the few years surrounding and including 1990, the 3208s had bad smoking problems (white smoke). The later remans had corrected this problem. And in fact my 3208 doesn't smoke in the slightest.
On another note, I'm really starting to lean toward stripping my RV as a donor for the conversion. I think this will be the easiest and most cost effective solution. Nearly everything I need for my conversion is already in my RV. And for it's age, the interior is pretty nice and everything works. I may upgrade a few things (larger tanks, batteries, etc.), but shouldn't need much else.
Locutus
Old 09-16-2010, 12:31 AM   #13
bus-bro's Avatar
Locutus, is your 3208 turbo'd or NA? I had heard that the on NA (naturally aspirated) engines the top part of the bore wore because of the high pressure of the compression piston ring (these being two ring pistons). The original bore wasn't tough enough to handle this, and that new harder liners were installed to handle this (& yes, I know it's a parent bore engine).
My question that the above refers to is that: does a REMAN Cat 3208NA have these new liners installed as a routine part of the rebuild? I would think that would address the white smoke problem.
Old 09-16-2010, 09:35 AM   #14
Locutus's Avatar
Bus-Bro,
Mine's a turbo. Can't answer your spectulation.
Locutus
Old 10-10-2010, 06:00 PM   #15
Locutus's Avatar
Nothing done lately on the Crown bus project, other than trying to get the air leveling system leak-free. My mechanic has been working on it but it still leaks slowly on the starboard side. Takes two days to deflate now instead of two hours. That's an improvement, but still not satisfactory. I'll try to get him out here again this week to see if we can finally nail down a solution.
Meanwhile, I've been trying to finish up another project: A home-built velomobile fairing to fit on my electric-assist trike. For full details on this project go here:
http://forum.atomiczombie.com/showthread.php?t=2295
Here are a few teaser pictures:
Locutus
Old 10-11-2010, 12:21 AM   #16
Locutus's Avatar
Originally Posted by Iceni John
That looks like a fun tadpole. What make is it? Yellow is a smart color for a fairing - is it made from Coroplast? Many moons ago, when I lived in Norwich in England, I often used to see Mike Burroughs scooting through town on/in one of his original Windcheetahs, which was one of the first effective all-weather recumbent trikes. They were also damn fast, and they set many distance and endurance records. I almost bought one some years ago when I was working in the bike biz here in SoCal - I would still love to have a low fast tadpole some day, but I may end up making my own version of a Windcheetah (but without the single-sided rear hub).
John, just back home after working on the tank frames under The Mistress
Hi, John.
I built the trike myself. It's based on the Street Fox plans that can be purchased online at http://www.atomiczombie.com. I made several modifications to the basic design, including front disc brakes and underseat steering. I then added an electric hub motor and NiCd batteries. The fairing is conected to the frame by a single hitch pin, which doubles as a hinge, and which makes it a snap to remove for fair weather riding. I constructed the fairing as a stand alone, so that all controls, lights, mirrors, etc. stay on the trike when the fairing is removed. And yes, that's yellow 4mm Coroplast.
How is the tank mounting coming along?
Locutus
Old 10-11-2010, 03:58 PM   #17
Locutus's Avatar
John,
Sounds pretty complex. Be sure to take lots of photos of your process and post them on your conversion thread.
Locutus
Old 03-06-2011, 05:53 PM   #18
Locutus's Avatar
I finally got around to taking out the seats, so here are the obligatory photos. I'm temporarily keeping two seats for a temporary dinette. I'm going to slap together the requirements for retitling as an RV, then I'll take it all out after I pass inspection and do the real conversion.
Locutus
Old 03-08-2011, 03:20 PM   #19
Locutus's Avatar
John,
I'm actually planning to remove the side windows and skin over with sheet metal, then cut openings for RV windows. But I was looking closely at the stock windows yesterday and couldn't figure out how they're installed. Do you know how to remove this type of window?
Locutus
Old 03-09-2011, 08:13 AM   #20
Seeria's Avatar
Three Crown Super Coach II's for sale Crown_Guy Classifieds | Buy, Sell, Swap 11 01-03-2015 01:30 AM
Looking For 1970-1990 Crown Super Coach in/around WA frank-id Classifieds | Buy, Sell, Swap 0 11-15-2010 12:28 AM
Thomas Saf-T-Liner, or Crown Super Coach II. Which one? Locutus Conversion General Discussions 28 07-19-2010 11:35 AM
1990 Crown Super Coach II Locutus Classifieds | Buy, Sell, Swap 3 06-23-2010 01:44 PM
1971 Crown Coach Conversion chakra Classifieds | Buy, Sell, Swap 1 05-06-2005 01:56 PM
